Old Mar 16, 2011, 11:57 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Originally Posted by dkb194 View Post
I've been seriously considering the move to the V200D01 but need something that in a FP that is better in the wind. I've read that the UflyS is better. Must be FB vs FBL.
Comments please.
In my opinion the V200D01 outclasses the UFLY you will be happy the the v200d01 its worth the money if the intent is there. I can fly my V200D01 in pretty windy conditions and still be controllable...much easier to fly than the UFLY from my experience...i own both ships.
tengarang is offline Find More Posts by tengarang
Old Mar 17, 2011, 03:43 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Comments please.
I found FBL faring much better in the wind. It will quickly react to any tilts caused by sudden gusts of wind. Morover, the faster cyclic response will enable you to get out of trouble quicker.
However, you must bear in mind that the Ufly is a larger heli than the V200D01 and thus inherently more stable. I would still recommend the V200D01 because besides being FBL, it uses the same platform as the CB180Z and 4F180. That means the heli is likely to be supported for quite some time. Whereas the Ufly is a one off platform that was never that popular.
zadaw is online now Find More Posts by zadaw
Old Mar 17, 2011, 11:40 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Comments please.
FBL is less parts to wrap around an object if you crash. I've been very happy with my V120D01 (the little brother of the V200). I have a V200 on the way from Miracle Mart. $145+ shipping or for $165 and free shipping from Walkera of America.
shastamike is offline Find More Posts by shastamike
Old Mar 17, 2011, 01:58 PM
dsobbe is offline
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
Originally Posted by surfer2001 View Post
Did they ever fix the problem with the main gear stripping out?
THX, Surfer2001
See my Post #164.
dsobbe is offline Find More Posts by dsobbe
Old Mar 17, 2011, 06:29 PM
dkb194 is offline
Find More Posts by dkb194
Canada, BC, Nanaimo E
Joined Dec 2010
Thanks all. I guess I'll pony up a few $ more and go with the V200D01 or Exceed Classimo.
dkb194 is offline Find More Posts by dkb194
Old Mar 17, 2011, 08:44 PM
dsobbe is offline
Joined Jan 2011
Does the 2403 Tx that comes with the V200D01 have a low battery alarm?
(Thanks, Tengarang)
Old Mar 17, 2011, 10:41 PM
tengarang's Avatar
Joined Aug 2010
itll beep on you... so yea youll know when you get low.
tengarang
Old Mar 18, 2011, 09:03 PM
dsobbe is offline
Joined Jan 2011
To all,
I found a simple way to greatly improve the handling of the V200D01.
I noticed that if the helicopter is trimmed to hover in still air it tends to wander after a short period. Also, after moving the sticks and then reestablishing a hover, the trim settings were a little off. This was caused by the amount of slop in the O-rings (4)( on the Walkera explolded diagram) that hold the main rotor blade shaft (8) in the rotor head. These O-rings act as shock absorbers that soften control inputs. As delivered they are very loose, which is helpful when learning to fly. However, that looseness also deadens the ability to make precise control inputs and also allows gyro inputs to cause oscillation.
To compress the O-rings and remove some of the slop in the main rotor blade shaft I made two washers from .015 plastic sheet with diameters just slightly larger than the E-type circlips (9). I placed one washer between each O-ring and its E-type circlip. If you add these washers its a good idea to place a clear plastic bag over the rotor head while removing and reinstalling the E-type circlips. They have a tendency to get lost if they spring off of the main rotor blade shaft.
On the next flight I noticed that control inputs and flight trimming were much more precise and predictable. Also, the tendency of my copter to oscillate when flying backwards was gone and I could also increase the gyro gain without encountering oscillation.
I made my washers from .015 ABS plastic sheet. The only important dimension is the diameter, which is close to the E-type circlip diameter and won't contact the rotor head (11). There may be commercially made washers available that will work. If you find one, please let me know.
I found that Walthers 2-56 Brass Washers #947-1273 fit perfectly.
Old Mar 19, 2011, 04:19 AM
tengarang's Avatar
Joined Aug 2010
To all,
HI Dsobbe,
thanks for the feedback I will take advantage of your discovery and put it to good practice. Thank you sir.
In return I would like to share mine...for ALL. To get more flight time out of your V200D01, I used the Walkera #38 battery ...7.4V @ 2200mAh battery. Tons of flight time ...somehting like 15 mins..whoa. ... ... .. yes more power too.
Ingredients:
Walkera #38 batteries or similar that you know of
Walkera #38 battery holder
Lama3 skids ( there are hole mounts which I utilized to mount the battery holder for the Walkera #38)...
I will provide pictures tomorrow sometime for visualization...
Thing looks alright and performs great...flight time enhanced....by alot
You may ask why did I do this?!?! good question! I own 3 walkera #38's ...and I seldom fly these ships, leaving alot of unused walkera #38 batteries sitting around my garage without much excersize. .... i figured lets find a way to put these puppies in to good use.
Anyhow, this may or may not be important to pilots here. but I will share visuals once I get some pics in place.
take care
tengarang
Old Mar 19, 2011, 02:47 PM
dkb194 is offline
Joined Dec 2010
A couple of photos would be helpful
To all,
I am compiling a group of mods and photos help alot for some. This is one of them.
Old Mar 19, 2011, 02:49 PM
dkb194 is offline
Joined Dec 2010
V200 d01
I'm thinking of buying the V200 D01 BNF and adding the 2801Pro TX as I would like to go into Walkera CP in the future. Is this a good way to go for an extra $100.
Old Mar 19, 2011, 05:40 PM
surfer2001 is offline
Find More Posts by surfer2001
Joined Mar 2011
That is exactly what i did, V200, with 2801 Pro, the 2801 Pro can store up to 8 birds. I've already added my 4#6 to it. The directions with the 2801 come with dip switch settings most of the walkera choppers. I'm very happy i went this route because my next heli will be, a CP (Heli only) No TX, No Charger. thus savings. Also ,I really like using one TX, just for the consistant feel of the sticks. Walkera USA has that package for $285.00 free shipping.
By the way, the V200 is sweet, very easy to fly, and does well in the wind. I'm on my 10th flight with no issues.
I'm totlally new but that's my 2 cents.
Surfer2001
surfer2001 is offline Find More Posts by surfer2001
Old Mar 19, 2011, 06:46 PM
tengarang's Avatar
Joined Aug 2010
That is exactly what i did, V200, with 2801 Pro, the 2801 Pro can store up to 8 birds. I've already added my 4#6 to it. The directions with the 2801 comes with dip switch settings all most of the walkera choppers. I'm very happy i went this route because my next heli with be, heli only no TX, no Charger. thus savings. Also ,I really like using one TX, just for the consistant feel of the sticks. Walkera USA has that package for $285.00 free shipping.
Surfer2001
Hi Surfer,
Im glad your airborne status...if possible please make a video for us.
REgards
tengarang
Old Mar 20, 2011, 01:09 AM
dkb194 is offline
Joined Dec 2010
Link to Walkera USA
Surfer2001
Thanks for the feedback Surfer2001. Have you got a link to Walera USA?
Old Mar 20, 2011, 05:47 AM
HELIRON69 is offline
Find More Posts by HELIRON69
HELIRON69's Avatar
United States, PA, Chambersburg
Joined Feb 2010
You should know Walkera of America has a no warrenty, no return policy but I brought a CB 100 and my V200D01 from them. No problems with the CB 100. After about 10 flights on the 200, one of the cyclic servos failed. I got two servos from Wowhobbies for $28. Even with this it was cheaper than buying the heli from Wow. All helis are brand new and in original box. Any seller can send out a problem product. For the price, they are good but if you have a problem you are on your own.
HELIRON69 is offline Find More Posts by HELIRON69
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
