Old Mar 07, 2011, 12:20 AM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Originally Posted by dsobbe View Post
To all,
The skids have a narrow stance, making take offs and landings in grass or on rough surfaces very difficult. So, I increased the spread of the skids about 3/4". That small increase added a lot of ground stability and greatly reduced the tendency to tip on lift off.
As can be seen in the photos, just saw the gear legs in half along their center lines. Drill two .059" (No.53) holes about 3/8" deep into the cut ends to accept four lengths of 1-3/8" .058" piano wire. The piano wire doesn't add any measurable weight or change the CG. Assemble the legs and wire. Remount them, aligning the inside pre-drilled holes in the gear legs over the holes in the frame. The finished gear retains the same strength and flexibility of the original with better performance.
i invested in walkera LM3 lama3 landing gear they fit on quite well
tengarang is offline Find More Posts by tengarang
Old Mar 07, 2011, 02:06 AM
wizzard363 is online now
Find More Posts by wizzard363
flying or crashing into air?
wizzard363's Avatar
Australia, VIC, Langwarrin
Joined Feb 2011
I use 450 skids on mine , all I had to do was drill new hole in them to match the V200 frame but after getting some advice on another forum I removed the screws and attached the skids with velcro .
This allows the heli to bounce off the skids in a hard crash and helps prevent serious damage
wizzard363 is online now Find More Posts by wizzard363
Old Mar 11, 2011, 08:02 PM
js349 is offline
Find More Posts by js349
msr,CB100,UFlyS,V120-V200D01
Tennessee, USA
Joined Dec 2007
Dear friend,
I am very satisfied...As a matter of fact I did not find to need to program it...everything was set to the way I liked it. It comes with soft start and break off dialed in.
just barely some warmth...not hot like the stock ESC...great investment if you as me.
tengarang
Well I got my ESC and have it on my heli and it is not set to soft start because it starts just like it did with the stock ESC and it will not go into program mode and I have gone through the steps in the instructions several times. How do you know yours was set to soft start? Will yours go into program mode? If you can get it in program mode, did you do anything different from the instructions?
js349 is offline Find More Posts by js349
Old Mar 11, 2011, 11:41 PM
tengarang's Avatar
Joined Aug 2010
Mine was set to soft start by default...i noticed this since it was not the same as the stock ESC....strange...perhaps you can post a video and we can figure out whats going on
tengarang
Old Mar 12, 2011, 10:33 AM
js349 is offline
Tennessee, USA
Joined Dec 2007
tengarang
I don't have a problem with mine not being in soft start by default but I do have a problem with not being able to put it in program mode. Could you please see if yours will go in program mode per the instructions? You don't have to change anything just see if you get the beeps the instructions describe. I've e-mailed the seller but I really doubt if I'll hear from him.
Old Mar 12, 2011, 02:12 PM
tengarang's Avatar
Joined Aug 2010
The tones do not reflect the instructions specification upon attempting program mode activation. However following through as if it was in programming mode, I am still able to alter parameters. Ive got one on my v200D01 and 4f180. I left the v200d01 alone but I was able to program the 4f180 for non-soft start instant spike mode. All tones sound the same so it is kind of like a guessing game...could be a while to get it right....
tengarang
Old Mar 12, 2011, 03:50 PM
js349 is offline
Tennessee, USA
Joined Dec 2007
tengarang
OK, that makes a little more sense. So, do you think I need to count 5 beeps for start mode to make it soft?
Old Mar 12, 2011, 04:45 PM
js349 is offline
Tennessee, USA
Joined Dec 2007
tengarang
I've tried and tried and there's no way to know if it ever goes into program mode. When I plug the ESC into the battery, mine goes beep-beep-beep, then beep-beep, and then just a never ending stream of one beep at a time and they are all the same. And, no matter what I do with the throttle stick it doesn't go into program mode but the heli arms and is ready to fly. So something is missing here and I don't know what else to do.
Old Mar 13, 2011, 12:12 AM
tengarang's Avatar
Joined Aug 2010
Ill spend some time on my 4f180 to see if I can get to to soft start since I have instant start programmed on it now.
I will report back with what I find
tengarang
Old Mar 13, 2011, 03:14 AM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
This may help. http://www.helifreak.com/showpost.ph...66&postcount=1
Some people also use and old FM rx and tx to program the esc.
stretch1100 is offline Find More Posts by stretch1100
Old Mar 13, 2011, 11:45 AM
js349 is offline
Tennessee, USA
Joined Dec 2007
tengarang
Thanks, I'll be looking for your report.
Thanks, I don't have an old FM rx/tx but I'll see if the other procedure will work.
Old Mar 13, 2011, 01:13 PM
js349 is offline
Tennessee, USA
Joined Dec 2007
Much thanks to you stretch - this works! Thanks again!
Old Mar 13, 2011, 06:29 PM
USA, IL, Elgin
Joined Jan 2006
Anytime
Old Mar 14, 2011, 05:38 AM
dsobbe is online now
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
[[Quote]]
1. Remove all servo's and XP12 from RX
2. Connect your old Walkera ESC (WITHOUT MOTOR !!!!) to ELEV
3. Switch on TX (throttle stick down)
4. Connect 1S battery to ESC
5. Wait for binding (LED on RX steady)
6. Move throttle stick to top position
7. Connect motor to XP12
8. Connect XP12 (WITHOUT BATTERY !!!!) to RX (THRO)
[[Quote]]
I'm confused by these instructions. XP12 seems to refer to both the new and old ESC. Which is which?
If I use an old FM radio to program the new ESC, is the ESC connected to the Rx Throttle and the battery to the ESC?
dsobbe is online now Find More Posts by dsobbe
Old Mar 14, 2011, 05:40 AM
Joined Jan 2011
[[Quote]]
[[Quote]]
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
