Old Jan 09, 2013, 01:18 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Rudder Servo
Should I use a digital rudder servo? My anolog servo buzzes and gets warm and even starts to smell hot. Otherwise it does opperate correctly.
arrowshooter is offline Find More Posts by arrowshooter
Old Jan 09, 2013, 03:13 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
you should use a digital servo for the tail...especially for the tail. if youre using the v200d01 RX you should stick with a walkera brand digital servo because the frame rate is unknown and so selecting a non-walkera aftermarket servo will be difficult.
tengarang is offline Find More Posts by tengarang
Old Jan 09, 2013, 05:39 PM
Joined Aug 2012
Done. Wowhobbies has them in stock. Thanks!
Old Jan 21, 2013, 11:34 AM
Joined Aug 2012
Anyone have any ideas as to my dilemma as posted below?
http://www.rcgroups.com/forums/showt...3#post23877747
Old Jan 21, 2013, 12:19 PM
tengarang's Avatar
Joined Aug 2010
Try calibrating your esc to train it to your throttle range of your tx.
throttle stick up, plug in heli battery, hear confirmation beep, bring back to 0 throttle
that is if you already havent done so
Old Jan 21, 2013, 05:04 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
You may need to bind once 'normally' with throttle down first then unplug the heli leave TX on, put throttle to MAX and reconnect the heli for this to work since as the TX turns on it complains of a non-zero throttle and if it's started the binding, moving the sticks can stop it.
thwaitm is offline Find More Posts by thwaitm
Old Jan 22, 2013, 01:27 PM
Joined Aug 2012
The way I have been doing it is to bind with a separate receiver pack and the red wire unhooked for the esc/Rx plug. Then I put the stick to the top, plug the battery to the speed control, listen for the beeps, move the stick down, listen for the beeps then unplug everything. I have done this a number of time, but I will try this idea. Thanks thwaitm and tengarang.
Old Jan 23, 2013, 06:06 PM
Adrnln Jnke is offline
Find More Posts by Adrnln Jnke
Adrnln Jnke's Avatar
Joined Nov 2012
well, had a nice crash today. I was outside and it was nice and sunny, doing some large loops and the tail took an uncommanded turn and I tried to correct but I got disorientated and I though it was facing towards me when actually it was facing away. Come to find out I discovered the RX range limit of this little guy, about 50 - 60 yards away while about 50 - 60 ft in the air. I heard the motor cutting of and back on and finally it just dropped like a rock out of the sky. Had some extensive damage to the bird too, destroyed skids, Battery frame, main frame,1 blade, main gear, and I discovered that the antenna was only hanging on by 3 wired. I suspect that this may be the cause of the limited range. While I was inspection the RX the damn ant. popped right off, so I ordered another RX too. so that was about an $80 crash, my most expensive to date. So it will prob be about 10 -12 days before I get her in the air. I think I will have my V450D03 by then (i hope) and I'll have a nice little report on that for y'all.
Adrnln Jnke is offline Find More Posts by Adrnln Jnke
Old Jan 31, 2013, 11:28 AM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
I fly a V200D01 for more then a year. I am looking for a Master, Super, Genius CP. How do they compare to my V200D01, are they easier or not to fly ? do they have a mind of their own like my V200D01 ( flying bugs) ?
fauconnier is offline Find More Posts by fauconnier
Old Feb 03, 2013, 09:43 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
CP is way more predictable and stable. If you can fly a V200D01 and not crash it for a couple of packs then you're ready for CP.
When I say fly, I mean you know your orientations - not just hovering.
CP is a little harder to fix and significantly more dangerous however. Be sure to take the necessary care! Otherwise, have fun!!
Old Feb 03, 2013, 10:30 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
You will find Mater c/p handles better than V200D01. Why ? I have both and find Master more stable/ more weight and better gyro. Also FBL F/P have bad ground action. If you can fly V200D01 and not break it you can fly c/p. Super c/p would be ok but Master ia a great deal and no more than mico100 sized birds.
Bad divot for M C/P are weak servos, but they have new metal geared one to replace. Super is cheaper to start with. Bigger is better.
dankar04 is offline Find More Posts by dankar04
Old Feb 03, 2013, 02:28 PM
fauconnier's Avatar
Joined Jul 2012
Thank you thwaitn and dankar04, great to read that . It took me so much time, effort, repairs and money to fly my V200D01, I couldn't imagine that flying a beginner CP could be worse !
Old Feb 06, 2013, 04:23 PM
Joined Aug 2012
I have been talking to Wowhobbies about my issue and these are the answers I got:
1) You can not set end point with WK2403 due to random bind Tx.
2) The end points are set by Walkera. It can not set end points due to random bind.
Does this make any sense at all? Getting kind of frustrated because there is no smooth start or stop.
Old Feb 06, 2013, 10:30 PM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Sounds like you've done what you can. Maybe you need to try a different ESC or motor...
Old Feb 06, 2013, 11:58 PM
Joined Aug 2012
I agree, I will probably find a suitable Walkera ESC and go from there. Thanks.
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
