Old May 30, 2012, 01:29 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Sold my V200D01 with the belt mod to simplefly. His last PM was: all great. and awesome. Thanks
Crash Survivor is offline Find More Posts by Crash Survivor
Old May 31, 2012, 01:39 PM
Owner1 is offline
Find More Posts by Owner1
Owner1
United States, WA, Seattle
Joined Mar 2011
V200D01 flying fast
Decided to film an entire battery of my V200D01 in FFF. My camera man wasn't home so I had to use my POV cam so it's not HD, but it's not bad.
I've been flying my V200D01 since October, but the weather has only been good enough to seriously fly outside for the last month or so. That is to say, I'm still working on my flying skills.
Since it's a whole battery, it's pretty long, but the best bits I think are the first couple minutes, then the last 3 or 4.
Owner1
V200D01 flying fast (11 min 50 sec)
Owner1 is offline Find More Posts by Owner1
Old May 31, 2012, 01:47 PM
Scott in NH is offline
Find More Posts by Scott in NH
Joined May 2010
Nice flying O1!
Thanks for posting the vid.
I haven't touched mine as both of my 9958's are down, the weather has been unsuitable and I am too rusty to even attempt it.
The good news is I have a box of parts at home now to fix my 9958's and shake some rust off before resuming my V200 "training".
Scott in NH is offline Find More Posts by Scott in NH
Old May 31, 2012, 11:35 PM
unknown87 is offline
Find More Posts by unknown87
Joined May 2012
wow thats quick, is that stock? still waiting for parts to get mine in the air =)
unknown87 is offline Find More Posts by unknown87
Old Jun 01, 2012, 02:42 PM
Owner1 is offline
Owner1
Joined Mar 2011
Yes, it's completely stock. The only change I made was to move the battery forward 1/2" by removing the front frame support and loading the battery from the front. Also, the elevator gyro is set quite low to allow large changes in fore and aft attitude. It's a little wobbly in a hover this way, but it smooths out as soon as you start moving forward and it doesn't resist pointing the nose way down.
Owner1
Old Jun 01, 2012, 10:10 PM
Joined May 2012
cool =D thanks for the info
Old Jun 18, 2012, 04:56 AM
tterence is offline
Find More Posts by tterence
Joined Feb 2008
Just want to share that V200D01/D02 Spare Parts are in final sale. Shipping is US$5 worldwide for unlimited parts.
Thanks all and happy flying.
Terence
tterence is offline Find More Posts by tterence
Old Jul 04, 2012, 05:04 AM
dazzago is offline
Find More Posts by dazzago
Joined Jun 2011
Hi All,
Reading through the thread I can't see what the easiest way of changing of the main gear. Is it by removing the six screws for the chassis or removing the head assembly and press-fit pins?
Many thanks
dazzago is offline Find More Posts by dazzago
Old Jul 04, 2012, 11:12 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by dazzago View Post
Hi All,
Many thanks
Hi,
Remove the servo-swash links, remove the press pin in the main gear, twist and pull the head assembly & main shaft out of the gear.
Slide the main gear out the side of the fuse.
Slide the new one in the same way and insert the pin.
Reconnect servo-swash links.
Go fly.
thwaitm is offline Find More Posts by thwaitm
Old Jul 07, 2012, 07:33 AM
Router is offline
Find More Posts by Router
Router
United States, NC, Troutman
Joined Jul 2012
dsobbe, regarding the adding of the washers to the main rotor shaft.......is this in addition to the sleeve modification to the main shaft or did the sleeve modification replace the need for the washers ?
Router is offline Find More Posts by Router
Old Jul 07, 2012, 02:05 PM
dsobbe is offline
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
Your question is confusing. The sleeve modification just takes any slop out of the cyclic controls and gives them a more solid feel. No washers are added to the main rotor shaft.
dsobbe is offline Find More Posts by dsobbe
Old Jul 08, 2012, 12:27 PM
Router is offline
Router
Joined Jul 2012
Dear dsobbe, you are correct, I was confused.........I was going off poor memory and my mind was missing the "main rotor shaft" and "main shaft".
You post #308 is regarding the .015" washer on the rotor shaft to "support" the O-ring to improve the responsiveness. Did this tune prove out to be worthwhile ??
Old Jul 08, 2012, 08:43 PM
dsobbe is offline
Joined Jan 2011
No. The washer didn't improve control enough to be worth the effort.
All in all, you'll get the most improvement from my blade mod.
http://www.rcgroups.com/forums/showp...postcount=1275
It gets rid of the pitch up tendency and makes forward flight very stable.
Old Jul 08, 2012, 09:41 PM
Router is offline
Router
Joined Jul 2012
Thanks dsobbe. Yes i did see the blade modification and intend to give it a try. My balancer is away on loan so I have delayed the mod.
BTW I work for a company north of Chicago in Waukegan.......I noticed you were from Chicago, are you on the north side of the windy city ?
Old Jul 09, 2012, 12:03 PM
dsobbe is offline
Joined Jan 2011
I fly at the Suburban Aero Club (SAC) forest preserve field on Cicero Ave. just south of Flossmore Rd.
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
