Old Jul 27, 2010, 03:19 AM
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
Hobby King EPO ParkJet ARF "Floats like a kitten"
They changed the description on the product page but the description in the email newsletter said...
"It looks deadly, it floats like a kitten at half throttle and screams across the sky at WOT. The H-King ParkJet 600 is just too much fun!"
Kittens look deadly? I didn't know they float. I thought they just jump up and quickly come back down. I was also unaware that kittens have throttle, let alone variable throttle. Since this plane is "too much fun" I doubt I'll get one because it's probably illegal.
I'm not really interested in this plane but I thought the description was hilarious. It did remind me of the PZ Stryker which plenty of people have bashed for slope use. I'm guessing it's only a matter of time before one of these gets hucked off a slope somewhere.
http://www.hobbyking.com/hobbyking/s...dProduct=13763
trees is offline Find More Posts by trees
Old Jul 27, 2010, 05:29 PM
Westerly Windina
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
It probably *is* a ParkZone Stryker...
screamin' eagle is offline Find More Posts by screamin' eagle
Old Jul 27, 2010, 06:00 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
I'd like to see vids of this baby
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jul 27, 2010, 06:09 PM
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
Good point!
Old Jul 27, 2010, 11:20 PM
Airplane Killer
SumthinsFishy's Avatar
Orange County, CA
Joined Oct 2009
... a 10A esc... Excellent for anyone wanting to upgrade to a scorching 200W power system for ballistic speed...
200 W with a 10A esc would require a 5 cell lipo. Something's wrong with their math And then using the 2300kV motor it'll be spinning 46,000 RPM Better stay clear of the prop!
Dave
SumthinsFishy is offline Find More Posts by SumthinsFishy
Last edited by SumthinsFishy; Jul 31, 2010 at 03:49 PM. Reason: more mathematical silliness...
Old Jul 27, 2010, 11:33 PM
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
Use the powertrain to blend up slopeside margaritas while the ParkJet "floats like a kitten" over the slope.
Old Jul 29, 2010, 04:52 AM
Italia, Emilia Romagna, Modena
Joined Mar 2009
i think it's perfect for fast FPV!
any owners!?
arnaldo26 is offline Find More Posts by arnaldo26
Old Jul 29, 2010, 11:46 PM
Ottawa,Canada
Joined Dec 2003
Hard to believe that it's only a 2S motor system running at 2200kv.
Turbobeaver is offline Find More Posts by Turbobeaver
Old Jul 30, 2010, 12:04 AM
Australia, NSW, Plumpton
http://www.rcgroups.com/forums/showt...2#post12843913
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Jul 31, 2010, 11:25 AM
German Engineering.......
HugePanic's Avatar
Auxsburg
Joined Dec 2007
i was disappointed to see that it is soo damm small.
i (as a 50% heli-guy) was thinking "600 size" sounds like more than 1kW with 6S or more battery....
basically i was searching for dual-use of my 6s3000 lipos from my heli...
HugePanic is offline Find More Posts by HugePanic
Old Nov 06, 2010, 10:52 AM
Joined Aug 2008
A mini review (surprised to find so little info about this plane on RCG)
I received mine a few days ago.
Two flights so far, both ending in minor crashes.
I used the included contact cement. It cures to a dirty yellowish color. And isn't very strong. (Not sure if using a not-so-strong glue might be better since crash damage might be more clean on the glue joints. Anyway, I am using with 5-minute epoxy for repairs.)
There is no assembly manual.
There are 2 slots molded in the foam to accept carbon rods for wing reinforcement. No carbon rods were included. Luckily I have some lying around, I think it's 2mm. Fits well.
Proper CG is mentioned at HobbyKing reviews/forums to be just in front of the finger grips. With Spektrum AR6110 and no VTail mixer onboard, and with a 3S 800mAh Zippy 20C, my CG ends up about 10mm in front of the finger grips.
Maiden flight was difficult due to the amount of up-elev trim (about 4mm up) needed. And also due to over-sensitivity of controls.
My last crash seemed to be due to something working loose in mid-air, resulting in loss of control. Suspected to be the snap-fit elevon control horns.
Now I have to replace one servo.
And one elevon is a little torn and bent, I may have to glue thin carbon rob at the trailing edges of both elevons.
kaon is offline Find More Posts by kaon
Old Dec 12, 2010, 07:42 PM
Joined Aug 2008
video
flight video here:
(with a gentle crash at the end.)
I made it slower than stock by using an APC 4.7x4.2 instead of the included 5x5 prop.
HobbyKing EPO ParkJet ARF (6 min 50 sec)
EDIT: forgot to say that for the flight in the video, I also moved the battery aft, to get the CG pretty much spot onto the finger-holds. Seems better than before, when I had the CG about 10mm forward of the front of the finger-holds.
Old Dec 13, 2010, 02:00 AM
It's a really big number.
Brisbane Intl, Australia
Joined Jan 2001
Looks like it flies quite good - but I'm not sure the HK statement either - 'floats like a kitten' paints the wrong picture for me too.
I'm guessing they mean its 'cute' and 'gentle' to fly. Yes, kittens are cute, and they can be gentle I'm sure... But has anyone seen a cat fall in a pool? While cats can swim perfectly fine, I think the stroke they use is called 'The Insane Eggbeater'. Not gentle or cute at all.
Googleplex is offline Find More Posts by Googleplex
Old Dec 13, 2010, 12:12 PM
HugePanic's Avatar
Auxsburg
Joined Dec 2007
Originally Posted by kaon View Post
....with a gentle crash at the end...
http://www.youtube.com/watch?v=bJ6mJWQh_io
thatīs "gentle"????
Old Dec 14, 2010, 09:48 PM
Tekton Ochroma Pyramidale
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Tee Hee. I dare anyone to drop a kitten and see how well it "floats".
Fly Wheel is offline Find More Posts by Fly Wheel
Build Log Hobby king's Decathlon EP ARF, 49in. span. SabreHawk Scale Electric Planes 290 Nov 29, 2012 11:50 AM
Discussion Hobby King Spektrum-like RX hoppy Radios 15 Sep 25, 2010 10:21 PM
Video Hobby Lobby DeHavilland DHC-2 Beaver ARF w/Floats & Wheels Flyboone Electric Plane Talk 38 May 20, 2010 03:37 PM
Discussion Would Like To By A E Motor Equivalent Of An E-flite 46 In Hobby King FedericoA Power Systems 4 Sep 21, 2009 05:50 AM
