This thread is privately moderated by JMAH, who may elect to delete unwanted replies.
Old Jul 26, 2010, 08:02 PM
JMAH is offline
Find More Posts by JMAH
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Build Log
Re-build Log, Actually
Initial report:
1) Cowl may be repairable
2) Snout is bent slightly to the right
3) Fuselage cracked in three places, epoxy should suffice
4) Needs new prop and spinner, but otherwise a low-cost wreck
I've moved the receiver farther aft away from the ESC and battery; and have tucked the elevator and rudder servo wires to the sides, farther away from the antenna.
I'm hoping to fly within the week (lots going on with work that will preclude much repair work being done).
JMAH is offline Find More Posts by JMAH
Old Jul 26, 2010, 09:57 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Wow. I can't believe the motor mount did not break. Did you try the boiling
H2O to plump the foam back up?
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Jul 27, 2010, 07:13 AM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Alan
Oh, the broken motor mount goes without saying, of course! I'm going to try something new: Kroger ibuprofen bottles are made out of a fairly strong, yet not brittle plastic that could be cut down and used.
We'll see.
Jeff
Old Aug 01, 2010, 08:08 PM
Mike4192 is offline
Find More Posts by Mike4192
Mike4192's Avatar
Joined Sep 2006
I can't quite tell from the picture if you already have, but I would suggest better securing the crystal for the corona receiver. I would get glitches in flight sometimes because the crystal vibrated around a bit, even with a piece of tape securing it.
You can carefully bend the pins like so for a more secure connection.
Mike4192 is offline Find More Posts by Mike4192
Old Aug 02, 2010, 08:48 PM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Originally Posted by Mike4192 View Post
...I would suggest better securing the crystal for the corona receiver. I would get glitches in flight sometimes because the crystal vibrated around a bit, even with a piece of tape securing it.
You can carefully bend the pins like so for a more secure connection...
Great idea, Mike. I've been whining on another thread and speculating that it's a problem with channel 21 (since the other 72 mHz guys I fly with don't seem to have the problems I have).
Could just be that I need to get better contact with the crystal pins. Thanks!
Jeff
Old Aug 02, 2010, 10:03 PM
Mike4192 is offline
Mike4192's Avatar
Joined Sep 2006
It could be the receiver, I've had mixed luck with Corona receivers.
In the past, I tried their synthesized receivers but those were a nightmare, now I just have two 4ch RS410II, similar to your 6ch one. One works absolutely fine on ch 57, but the other does not. It has a whole host of strange problems I cant pinpoint such as sometimes no signal at close range, losing the signal when I touch the antenna, or just not locking on at all. And to top it off, it would act completely differently on a different channel, 36 in particular. I just abandoned it in the end.
If bending the pins work, it's likely you've fixed the problem, I doubt it's ESC interference. If not, I'd highly suggest a JR receiver, they've always been rock solid for me, which is why they are in my heli and pylon racer.
There's one seller on ebay from which you can get a RS6UL receiver (get the right shift!) with a crystal for about $30 total.
Discussion Build Log: Monogram "build'n fly" DHC-2 Beaver lw_hughes Scratchbuilt Indoor and Micro Models 9 Nov 17, 2009 08:01 PM
Build Log Re-Build Log - Vintage Slegers Skyhawk - 3 Meter Thermal Rotozuk Electric Sailplanes 9 Oct 08, 2009 12:17 AM
Build Log 1/144 Yamato (Re)Build Log (Soar Arts) Bucketfoot-Al Scale Boats 1 Apr 03, 2009 02:36 PM
Discussion 1/144 Yamato (Re)Build Log (Soar Arts) Bucketfoot-Al Scale Boats 1 Mar 31, 2009 04:40 AM
Discussion First MD500/B400 scale build...actually first scale build of any kind. Stephen Shioi Mini Helis 21 May 03, 2008 04:53 AM
