Old Oct 01, 2001, 11:04 PM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
Herr Piper J-3 Cub
Has anyone built a Herr J-3 Cub? If so what power, gearbox, prop size and battery did you use?
Rod is offline Find More Posts by Rod
Old Oct 02, 2001, 12:28 AM
Ben Lanterman is offline
Find More Posts by Ben Lanterman
Ben Lanterman's Avatar
St. Charles, MO USA
Joined Jan 2001
Cub Conversion
I have the rubberband model converted to RC. I covered it with silk and dope. The motor is a GWS-A with a 9/4 prop. I am using a GWS receiver, 2 HS-50 servos to drive ailerons with coupled rudder and 7 120nicds. The model is smooth and much faster than a Litestik slow fly type. Takeoffs are very straight and it breaks ground with a breath of elevator. All in all a very good model but not one that you enjoy flying in the street in front of the house. If horsed around roughly it will not handle very nicely and will drop out of the sky. Keep it fast and smooth and it is great.
Ben Lanterman is offline Find More Posts by Ben Lanterman
Old Oct 02, 2001, 03:16 PM
Norman Adlam is offline
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Ben,
Herr do 2 Piper Cubs. I guess yours is the smaller (18 inch?) one. They do a 32 inch(?) one, and I'm wondering if anyone has built that as a Park Flyer yet!
Cheers,
Norman Adlam is offline Find More Posts by Norman Adlam
Old Oct 03, 2001, 07:19 PM
St. Charles, MO USA
Joined Jan 2001
Cub size
I converted the rubber powered kit # 103. They also have a kit #302 that is designed for Speed 280. Both kits have a 35 inch wingspan although it looks smaller than that for some reason. I usually check to be sure I am not using the centimeter side of the yardstick.
Old Oct 03, 2001, 07:49 PM
T_Hartigan is offline
Find More Posts by T_Hartigan
T_Hartigan's Avatar
Oak Harbor, Oh
Joined Jun 2001
Herr has 3 j-3 piper cubs. Rubber or free flight, park flyer(280), and speed 400 sized. Just wanted to make the water a little less clear.
Tim
T_Hartigan is offline Find More Posts by T_Hartigan
Old Oct 03, 2001, 08:25 PM
rkissin is offline
Find More Posts by rkissin
Corte Madera, CA
Joined Mar 2001
I'm just starting construction on the 48" span Cub with floats. According to Tom Herr, I will need a Speed 480 due to additional weight and drag of the floats. I happen to have a 7.2V Graupner Speed 480 -- Does anyone know of a gear box, any kind of gear box, that will fit this motor? Even though the can is the same size as a Speed 400, the mounting holes are a different width.
rkissin is offline Find More Posts by rkissin
Old Oct 03, 2001, 09:00 PM
sb1 is offline
sb1
Find More Posts by sb1
sb1
Charlotte,NC
Joined Jun 2001
rkissin,
Hobby Lobby has 2 g/box's for a 480, 3.33:1 and 3.8:1. They are the planetary type and sell for $24.00. Go the electric flight accessory page on their site. Look like nice stuff for the money.
sb1
sb1 is offline Find More Posts by sb1
Old Oct 03, 2001, 09:39 PM
rkissin is offline
Corte Madera, CA
Joined Mar 2001
Just what I needed, thanks!
Herr Piper J-3 Cub Park Flyer DaveG Parkflyers 4 Feb 14, 2008 07:15 AM
Herr Piper J-3 Cub *Flight Report* genovia Parkflyers 14 Feb 12, 2008 06:53 PM
Herr Piper J-3 cub Rondb Electric Plane Talk 5 Oct 26, 2002 11:35 PM
Herr 1/2A Piper J-3 Cub (My love for the Cub) genovia Parkflyers 30 Jun 10, 2002 10:18 AM
