| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
half fast
Wing Section
Thanks, Keith. First flights are about a week away.
Here's the wing construction. Span is now targeting just over 60". The flat center section is about 34", with 15" polyhedral tip panels. The CF tape spar caps are 48", and will extend unbroken across the dihedral breaks to halfway out the end panels. I have the center panel complete save for the top sheeting, and the spar is every bit as strong as I hoped. It's just flexible enough that washout can be added via setting the Solite film. Wing construction photos will follow. Karl |
#62 |
half fast
Overview of most of the center section. The large bays will be diagonally braced with the leftover kevlar thread once the wing is complete.
I was going to add ailerons, but will keep the weight and complexity down for this version. |
#63 |
half fast
Rib/spar closeup.
#64 |
Aerial Shutterbug
Hi Karl,
Your project is coming along nicely Now hurry up and get it done so you could make a kit for all of us! ![]() Roger |
#65 |
half fast
I'm hurrying!
I have to take a break every three days to shed my CA skin...I'm finding out that it's just a little more complicated when the structural details have to be figgered out as I go. |
#66 |
half fast
Wing is nearly complete. After installing the last tip sheet & internal bracing, sanding will go quick, then covering.
#67 |
half fast
quarter view:
#68 |
half fast
last one tonight
With the top sheeting in place, there's almost no torsional flex. Fortunately I found this out on the center section, so I blocked up the tip panels for approx. 3/16" washout at the end.
Karl |
#69 |
half fast
Complete! Wing is held with a CF dowel in front, and a single socket head bolt in the rear. I'd like to have a 1/4 turn lock type of fastener, as I have to remove the wing to get at the battery, but this will do for now.
#70 |
half fast
After John (Extremeone) had the issue with transparent covering tinting his images, I was concerned that my plan for yellow transp. would affect the images. I wrapped the covering around the wing, held it so that the sun shone on the lens through the covering, and took a bunch of test shots. Doesn't seem to be a problem, so I went ahead. (Besides, I didn't want to have to wait on an order for more covering.)
First flights might be tonight. With the battery centered on the plate, the CG is about 1/3 chord back from the LE. I'll shift it forward for the first flights. I've also gone from a 9x4.7 to an 8x6 APC-sf prop. Not ready to be nervous, but I'm sure I will be by the time I start loading the car... Karl |
#71 |
Zoom, zoom...
That looks great! I hope all goes well and that you end up with quality pictures. If so, you will have lots of people clamering for plans/kit. GL on the maiden!
#72 |
Live FPV FTW?! ;)
Lookin good as usual! I like that white wingtip for orientation. Should come in handy for those high altitude flights.
#73 |
Karl:
Good looking bird. David |
#74 |
half fast
Thanks guys. Batteries are charging as I type this, and the winds are light enough for a maiden this afternoon if the rain holds off.
I managed to reroute the ESC wiring so that the battery can be disconnected by removing the aft lower hatch. Still need the wing off to change batteries, but power on/off is pretty easy with just a magnetically secured hatch. Plenty of ideas in mind for mods/next generation: - reduce dihedral and add flaperons to center section for better confined landing areas - enlarge fin/stab (the original area calculations were correct, but the wing grew from 380 to 565 sq. in. and the tailboom was shortened for mounting reasons.) - simplified fuse design & construction methods. Building and designing around the crutch was handy, as I could place components and build the fuse around them. Unfortunately, the parts count is high and not worth the minor strength/weight improvements it yields. - provisions for the PJS series of outrunner brushless. I'd really like to be able to shoot while the motor is running... - size the fuse for the upcoming micro CCD cameras now becoming popular. I doubt I'll ever kit this, but plans &/or a short kit (laser cut parts) might be an option. Excuse me, my batteries are done and I have a plane to maiden. Knock wood! Karl |
#75 |
Good Luck!
-Sam |
| Thread Tools | |
| AP Avenger - Scratch build Photo platform | Joe Bennett | Parkflyers | 32 | Apr 08, 2004 12:12 AM |
| AP Avenger - Scratch build Photo Platform | Joe Bennett | Aerial Photography | 0 | Feb 01, 2004 06:47 PM |
| What ever happened to the EDF design/build/fly contest. | OCModels | Electric Ducted Fan Jet Talk | 2 | May 13, 2002 05:10 PM |
| AIAA/Cessna design,build,fly | Travis | Electric Plane Talk | 6 | Apr 24, 2001 06:58 PM |
| AIAA Design, Build, and Fly! | foss1997 | Electric Plane Talk | 11 | Apr 20, 2001 05:00 PM |
