| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
half fast
Design & build of Pencam-class photo platform
I've been working on & off for the past 5 months on a design that will replace the Slowstick for me when operating out of all but the most cramped LZ's. Two months ago I reached CAD stage, and for the last two weeks the balsa scraps and glue have been flying.
WS: 48", just under 400 sq. in. Airfoil: modified E-193 Power: geared 300-400 class Control: R/E/T/Shutter Payload: 3 oz max CF tailboom, pull-pull controls inside boom, surfaces & fuse built-up balsa/ply, wing built-up balsa/ply w/CF tape spar doublers, quick-release wing (NO RUBBERBANDS! )Ideas for larger next-gen: 6-8 oz payload for larger CCD/AF, pitch leveler for camera, left-down-right aim on aux. channel, flaperons. Karl |
#2 |
half fast
Tail items:
#3 |
half fast
last for now:
#4 |
Aerial Shutterbug
Hi Karl,
Very nice design there. I am wondering if you will be incorporating any dihedral in the main wing? The self leveling properties of such a design would be a plus. Of course if you wanted maximum lift then keeping the wing flat would be a better design no? I like the angled rudder surface, has this helped in reducing the turning radius of the plane? I'm still learning the basics of plane design so please bear with my questions. BTW, 0.02 on your self-leveling thought. You could attach the camera with a simple two-axis gimbal, that would not only give you pitch correction but roll as well. Regards, Roger |
#5 |
half fast
Hi Roger,
Thanks for the comments. Wing will have a constant chord 24" center section, with two 12" double-taper polyhedral tips. The taper and tip design on the tail uses a modified TLAR method called ILILT (I like it like that). The fuse including the boom will be over 40", with a tail moment arm of about 26". Angling the rudder hinge line effectively adds a bit of up pitch, so that when holding a slow turn, the pitch angle (hopefully) won't need much adjustment. I built up a gravity leveler (pendulum) test rig with a small RC car damper (shock minus spring, 1/2" stroke), and found that the pencam needed to be suspended about 4" to swing free with the damper working at about an 8:1 reduction using 10w silicone oil. Shorter length requires less damping, and 8:1 is about the geometrical limit with a simple extension strut. A viscous suspension would certainly be simpler than struts, especially for a two axis stabilizer. At any rate, that would be for a larger craft, and using a commercially available optical wing leveler/copilot (FMA?) might be the simpler solution once weight is less critical. Back to work, Karl |
#6 |
Aerial Shutterbug
The wing sounds like a winner and I like your 'modified TLAR' method
![]() Here is a drawing of the gimbal mount I mentioned. Given that the camera would be exposed to the elements (namely open air velocity - buffeting), I really like your approach using a damper based system. The single spring in this design could be modified (single-dual rate, coil dia., wire thicknes) to account for this effect but would not allow for self leveling as the spring rate increases... I suppose I could increase the distance of the cameras moment of inertia away from the pivot point to account for any change in spring stiffness. Back to (work) the drawing board. ![]() Roger |
#7 |
Aerial Shutterbug
Oops, your plane shows the camera mounted in 'portrait' orientation...
#8 |
half fast
I've GOT to get into 3D cad. I have DesignCAD 3D, not sure of the version, for Win 95. Just haven't installed it yet.
Yes, I'm using the Pencam SD, which takes landscape shots with the body horizontal. I'll be mounting it as shown in the attached pic. An electronic switch or remote servo-actuated switches would reduce the dimensions to be rotated. I'll always need easy access to the USB port, SD memory cam, or batteries, and I went with the passively faired "notch" for simplicity. I may go with a thin sheet of ABS held with magnets to fully fair the cam. Karl |
#9 |
half fast
Fuse construction started with a crutch of 1/32 ply with balsa & ply boom mounts.
#10 |
half fast
Fuselage frame 95% complete. I have the upper portions sheeted with 1/32 balsa, and once I install the motor mount and LG hardpoints the rest of the sheeting will go quick.
Karl |
#11 |
half fast
Sheeted..
#12 |
half fast
View of the wing saddle showing the battery platform. Also visible is the right thrust built into the front former. Wing will have either a dowel or tab in front to engage a hole or slot, rear will be retained with either a latch or internal rubber bands.
Running out of excuses to put off making the wing... Karl |
#13 |
half fast
First mockup:
#14 |
half fast
Another view:
#15 |
Kinnic:
Looking great. Now can you design me a gyro-stabilized ball mount for my onboard video camera??? (just kidding) If you get up to Madison, let me know and we'll go flying. Dennis Moran dmoran@itis.com |
| Thread Tools | |
| AP Avenger - Scratch build Photo platform | Joe Bennett | Parkflyers | 32 | Apr 08, 2004 12:12 AM |
| AP Avenger - Scratch build Photo Platform | Joe Bennett | Aerial Photography | 0 | Feb 01, 2004 06:47 PM |
| What ever happened to the EDF design/build/fly contest. | OCModels | Electric Ducted Fan Jet Talk | 2 | May 13, 2002 05:10 PM |
| AIAA/Cessna design,build,fly | Travis | Electric Plane Talk | 6 | Apr 24, 2001 06:58 PM |
| AIAA Design, Build, and Fly! | foss1997 | Electric Plane Talk | 11 | Apr 20, 2001 05:00 PM |
