Old Jul 25, 2010, 02:43 PM
Russ40 is offline
Find More Posts by Russ40
Fort Smith Ar
Joined Oct 2005
Trainer type plane
Here is a plane I built so I could let some friends try to fly on a buddy box. I wanted a easy to build and fly and it sure is.
The motor is an E-Max 2812 1534kv with a gws 8x4 dd prop, 18a turnigy esc, 1000ma 3s lipo, hxt 9g servos.
Wing is a Kfm3 airfoil 50" span. The center is 36" with 7" tips. The tips have a 2 1/2" rise. The first step is 3" and the second is 2" back from the first. Cord is 9" total.
The body is a Cf arrow shaft 32" long. The pod is 1 1/2" thick 3" wide 14" long pink foam.
The hor stab is 16" wide 8" cord with a 2" elevator. The vert stab is 8 1/2" tall 10" base cord 5 1/2" top cord with a 3" rudder.
AUW is 16oz.
Here are a couple of videos and a few pics. If I missed anything let me know.
Russ
Trainer type plane with a kfm3 wing (3 min 58 sec)
Trainer type plane KFm3 airfoil (3 min 15 sec)
Russ40 is offline Find More Posts by Russ40
Old Jul 25, 2010, 04:10 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
I am impressed. Looks like a quick and simple design. And it flys great!!!! I am surprised that it flys inverted so well with that type of wing. Plus the rolls with RET are great! Plus it does all of this at a slow flying speed. Have you tried a inverted loop? The "Fuse" looks like a quick and effective way to go. Are there any reinforcements in the wing or tail pieces?
It is a real winner... I have a arrow shaft that needs some wings!
Ray
.......edit.......
I posted after looking at the second video. I just looked at the first and saw the ailerons. It is impressive.
High Flyin' is offline Find More Posts by High Flyin'
Old Jul 25, 2010, 04:24 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
Russ40,
That is an ingenious piece of machinery...perfect as a trainer!
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Jul 25, 2010, 04:48 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Russ,
That is a sweet flying plane. Looks as though it can be build for very little money as well! That is my style of flying. I like it.
Dalton
DaDesign is offline Find More Posts by DaDesign
Old Jul 25, 2010, 05:48 PM
Russ40 is offline
Fort Smith Ar
Joined Oct 2005
Thanks guys..
Ray...I have a smaller arrow shaft in front of the second step under the first step. It is about 1/4" dia and 31" long. I got a bargin on cf arrow shafts at a dollar each so that is what I have been using lately. It will do an outside loop nicely.
Russ
Old Jul 25, 2010, 11:05 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
This is a great little plane. Thanks for posting the specs. I have some guys that are learning to fly, and this will make a great little plane for them.
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Jul 30, 2010, 11:02 AM
Jim Hatch is offline
Find More Posts by Jim Hatch
MacBeth, SC
Joined Aug 2007
Hey Russ,
You've certainly built an interesting airplane that looks well suited for beginners.
I didn't see it mentioned, but it certainly looks to be an excellent aileron trainer
as well. I'd love to see a split screen of your thumbs and the plane at the same
time your doing your rolls. Does it hold altitude well while rolling or are you working
hard to maintain level flight? I'm going to build one to share with friends. Too cool!
Thank you for sharing. Warm regards, Jim
Jim Hatch is offline Find More Posts by Jim Hatch
Old Jul 30, 2010, 02:06 PM
Russ40 is offline
Fort Smith Ar
Joined Oct 2005
Thanks Jim. I am using the elevator to keep the altitude while rolling. I add a bit of down when it rolls inverted and just a bit of up to compensate for any altitude I lost while inverted. It isn't real hard, just takes timing.
Old Jul 30, 2010, 02:55 PM
Kevlar is offline
Find More Posts by Kevlar
Shocking!
Kevlar's Avatar
United States, MI, Commerce Charter Township
Joined May 2002
You did it again Russ, nice simple design yet effective. Looks like and takes off about as quick as my Yard Stick, but no ailerons on that one.
I was going to build a smaller version of the Yard Stick to fly around the tight back yard (230ftx100ft), looks like you just got me started at my base!
Kevlar is offline Find More Posts by Kevlar
Old Jul 30, 2010, 03:09 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Great job, and terrific flying! There's an arrow shaft in my garage just screaming to fly...
How far from the leading edge to the forward end of the shaft? Is the CG just about where the aileron servo is?
potshot is offline Find More Posts by potshot
Old Jul 30, 2010, 04:09 PM
Out the Window
Joined Jul 2004
Russ
Could you measure from the firewall/motor mount back to the leading edge of the wing and the front of the horizontal stabilizer? Also the CG of the wing?
Ray
Old Jul 30, 2010, 04:14 PM
insomaniac45 is offline
Find More Posts by insomaniac45
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
hey that is quite a sweet plane,
would it be possible to get a simple drawing please
i am building a bb atm, but this looks very robust, and would make for a great second build
insomaniac45 is offline Find More Posts by insomaniac45
Old Aug 03, 2010, 09:44 AM
Russ40 is offline
Fort Smith Ar
Joined Oct 2005
Thanks guys.
I am on vacation this week. I don't have the plane with me but when I get home Monday I will get the measutments and try a drawing for you.
Old Aug 03, 2010, 09:51 AM
potshot is offline
potshot's Avatar
Joined Mar 2009
Originally Posted by Russ40 View Post
Thanks guys.
Russ, check the PM I sent a few days ago. I have a drawing with all of the dimensions you've given so far and only need a couple more for it to be complete. I'll be happy to finish it for posting if you wish.
Old Aug 04, 2010, 09:24 AM
potshot is offline
potshot's Avatar
Joined Mar 2009
Oh, and have a nice vacation!
For Sale New Type of Trainer rorrock Aircraft - Fuel - Airplanes (FS/W) 5 May 04, 2010 08:05 PM
Question Indoor "plane"- type plane?? sidecar53 Scratchbuilt Indoor and Micro Models 1 Oct 04, 2009 01:28 PM
Wanted New or Used Electric Trainer type plane........... mtdoramike Aircraft - Electric - Airplanes (FS/W) 3 Mar 06, 2007 05:38 PM
Micro trainer type plane? docprego Electric Plane Talk 13 Sep 26, 2005 12:54 PM
t-ifo's the best trainer type plane flyinjim Beginner Training Area (Aircraft-Electric) 4 May 27, 2002 07:52 PM
