Old Jul 24, 2010, 10:27 PM
coupe-r is offline
Find More Posts by coupe-r
Northern Virginia
Joined Aug 2009
Interchangeable motor mounting (Best Practices)
Hey Guys,
What do you guys use to mount your motors on your planes, but still allows you to swap them out quickly.
I typically used the long screws that came with my Turnigy servos, but looking for a different way that allows me to change them out using 4 bolts and nuts.
What are your suggestions?
coupe-r is offline Find More Posts by coupe-r
Old Jul 25, 2010, 10:24 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Probably the easiest is the breakaway motor mount I saw from Dave Powers.http://www.rcpowers.com/forum/showth...ay+motor+mount Lets you swap your motor quick and easy, and helps act as a shock absorber for some of those "vertical landings". Seems to work oretty well,too.
EZglider is offline Find More Posts by EZglider
Old Jul 25, 2010, 12:49 PM
Lestertrece is offline
Find More Posts by Lestertrece
Joined Apr 2009
tape
well, on my new plane "the elephant" which i just posted a thread about i think i might just use tape. at first i used hot glue, but then i dropped it and it broke. i used hot glue again but doing a gliding test it broke again(i didnt have a tail on at the time so that may have made it crash)
id say tape is the best way to go; easy to move around, easy to take off. but it wouldnt work on a big trick plane very well. it might break.lol
Lestertrece is offline Find More Posts by Lestertrece
Reply With Quote  (Disabled)
Old Jul 25, 2010, 12:50 PM
Joined Apr 2009
oh ya and the tape hasnt broken off even with five more glide flights. it can just move around a bit to absorb shock
Old Jul 26, 2010, 01:38 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Using tape to hold on a motor is not the smartest idea.
I bought several stick motor mounts. When I build my foamies I Epoxy the square plywood rod in place then I just screw the motor mount right to it.
Takes a total of 30 seconds to take the motor off 1 plane and put it on another. As simple as moving 1 screw.
airbagit13 is offline Find More Posts by airbagit13
Old Jul 26, 2010, 01:48 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
I'm going to have to use that rubber band method from Dave from now on.
Old Jul 27, 2010, 09:01 AM
ankurkaul17 is offline
Find More Posts by ankurkaul17
www.allthatido.com
ankurkaul17's Avatar
United States, PA, Levittown
Joined May 2006
Here are some ideas for attaching motor to mounts. Some are really nice ones...
http://www.rcindia.org/tools-materia...rs-on-foamies/
Regards
Ankur
ankurkaul17 is offline Find More Posts by ankurkaul17
Old Jul 27, 2010, 12:59 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
That coke bottle top mount is genius.
I am going to use that for my Elite 400 motor.
Discussion 2.4 install best practices for a 2 antenna Receiver? Fly2High Hand Launch 3 May 20, 2010 12:44 PM
Question Are tower pro motor bearings interchangeable? Chatenever Power Systems 0 Oct 26, 2009 01:26 PM
Help! Contest Best Practices HLG contest!!!!! Dlhimself Hand Launch 60 Sep 21, 2009 11:10 PM
Need foam covering best practices... LexTalionis Foamies (Kits) 1 Jun 25, 2004 10:15 AM
Building best practices for 1/3 scale ASW 20 dckemper Giant Scale Airplanes 0 Jul 19, 2003 07:25 PM
