Old Jul 24, 2010, 02:00 PM
Timewerx is offline
Find More Posts by Timewerx
Timewerx's Avatar
Joined Mar 2010
DIY V7 Ultimate 140 Blade for Walkera 4G6(S), V120D02, and 4G3, released!
Finally, my best mod yet! Please download attachment for both the DIY guide and template!
V7 Ultimate 140 Blade in a nutshell:
-Best aerodynamic performance and efficiency - reduces bogging by a great degree and makes helicopter still easily controllable even in the most demanding maneuvers!
-Highest blade stability reduces fluttering, vibration, and tracking issues, also makes helicopter more stable and easier to fly while agility improved too! - more ideal for both flybarred and FBL versions.
-Best crash protection offered, also the easiest and fastest to repair.
-Dramatically reduces crash cost!
Looking for a blade that offers highest performance and efficiency, best crash protection, makes your helicopter easier to fly, and reduces crashing costs dramatically? Don't believe such blade exists? Well here it is and it's DIY!
The rest of the mods applied in the 4G6 used in the demo you can access by clicking this picture below
V7 Ultimate 140 Blade for Walkera 4G6(S), V120D02, and 4G3 (9 min 47 sec)
Timewerx is offline Find More Posts by Timewerx
Old Jul 24, 2010, 02:05 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
WinRar and WinZip won't unpack it...
SoloProFan is online now Find More Posts by SoloProFan
Old Jul 24, 2010, 02:29 PM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Just re-packed the guide in the latest winzip 14.5. Download from here:
http://www.winzip.com/downwz.htm
Please let me know if it's working now, thanks!
P.S. I had to put it in a zip file because the pdf file is too big for attachments with 3.12 mb filesize.
Old Jul 24, 2010, 03:31 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Zip works fine now.
Old Jul 24, 2010, 06:54 PM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Thanks for letting me know and glad it works now!
If someone has already tried the blade, 3D, whatever, I'd like to hear your feedback, thanks!
Old Jul 26, 2010, 10:37 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Just a warning, if anyone has done my previous blade mods, I would urge to read through all the instructions instead of skipping some of the steps. There's a significant change, especially the type of adhesive used to bond the blade to the graphite core. The new method should result to a bond that will last many crashes without compromising its integrity.
Old Jul 26, 2010, 12:59 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Timewerx,
How do you reccomend the templates be scaled when printing? My blades either come out too small (when "Fit to page" is used) or too big (when "No Scaling") is used. Should the blades measure 140mm from root to tip, or smaller to account for the added length of the original blade root?
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Jul 27, 2010, 03:24 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Originally Posted by Rocketman1092 View Post
Timewerx,
Hi Rocketman, I have updated the guide. Please download again and visit Step 20a and Step 20b for the printing guide.
Thanks for your feedback! I thought it was all default print settings, I forgot I did one change to the print settings in Adobe Reader.
But in case, the settings are still giving you trouble for other reasons or using other than Adobe Reader to open PDF files, Step 20b provides good reference if you prefer to scale the printing yourself to the specified actual measurements. Use the jpeg template provided in the zip file in that case, to conveniently scale the print yourself.
Good Luck and Thanks!
Old Jul 27, 2010, 06:36 AM
Doblao is offline
Find More Posts by Doblao
Spain
Joined Jan 2010
About size
Hello,
Im working in reducing size of my 4g6s helis and would like to know if this kind of blades improves efficiency. If it is yes,do you think I can scale them to a reduced lenght and yet get the trust of the original ones? (75-80 mm blades would be the size I need)
Best regards from Spain,
Doblao
Doblao is offline Find More Posts by Doblao
Old Jul 27, 2010, 09:11 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Originally Posted by Doblao View Post
Hello,
Doblao
Yes you can make it shorter, while retaining blade width. But to generate similar maximum thrust of the 'full size' blade, the motor had to work harder.
The math that explains this is:
http://en.wikipedia.org/wiki/Disk_loading#Theory
In a nutshell, why shorter blades need more work from the motor is it needs to make higher velocity 'exhaust' to generate the same thrust with longer blades. While longer blades exhausts a bigger volume at a lower speed, the relation of volume is linear while speed is squared due to kinetic energy.
But good new is, since the gear ratios are not optimized, you may get higher efficiency with shorter blades. I can't say for sure with 75 - 80 mm, you just need to try it out. Although one thing I can guarantee you, collective and cyclic performance will get worse with shorter blades.
Lastly, the V7 Ultimate blade in its original size of 140mm should be more efficient than conventional blades due its elliptical lift distribution which full size helicopters also employ through blade washout. The V7 blade does it with taper. Theories aside, and with high quality worksmanship, the V7 blade should give better than 10% of actual increased hover time and about 50% increased flight time in aggressive flying/3D. The blade also remains controllable and stable at higher blade angle of attack (angle of airstream against the blade pitch) compared to conventional design allowing you to make more aggressive and tighter maneuvers... Making your 4G6 a true indoor 3D heli!
Old Jul 27, 2010, 10:23 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Timewerx, some guys are making smaller "moth" 4G6s and 120do2. Then cut the stock blades. Can you shrink your blades on the computer and make them work.
NaterPin is offline Find More Posts by NaterPin
Old Jul 27, 2010, 11:02 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
[edit post]
Old Jul 27, 2010, 11:18 AM
NaterPin is offline
Joined Dec 2009
Sorry, when I said " Can you shrink your blades" I should of said "can people shrink your blades".
my bad
Old Jul 27, 2010, 11:21 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
my bad
No problem! I think they can do that, they can distort it somehow with any graphics software, reducing the length while keeping the width.
Old Jul 29, 2010, 08:26 AM
terry74 is offline
Find More Posts by terry74
la fabrique circulaire
terry74's Avatar
geneva
Thank a lot for this great TIPs Timewerx
I post it on Helimag.com
Jay
terry74 is offline Find More Posts by terry74
Sold Walkera/Heli-Max micro Servos (2) Fits - 4G3, 4G6(S), 4#6(S) or any Micro Servo App HeliFlyer711 Aircraft - Electric - Helis (FS/W) 4 Jun 10, 2010 01:10 PM
Discussion Can trex 250 blade fit a walkera 4g3/4g6 blade grip? mayday1 Micro Helis 4 Apr 02, 2010 09:55 PM
Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size robZulu Micro Helis 774 Feb 26, 2010 11:25 PM
For Sale Blade 400 Receiver ready plus spare; make offer or trade for walkera 4g6 or 4g3 db adreher Aircraft - Electric - Helis (FS/W) 2 Feb 24, 2010 06:25 PM
Wanted walkera 4g6 or 4g3 for a walkera 36 synman95 Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2010 01:15 PM
