Old Jul 24, 2010, 11:36 AM
knlever is offline
Find More Posts by knlever
Design is everything.
Sri Lanka
Joined Mar 2010
Build Log
Cessna 180 from Paul Bradleys Model Airplane Plans Page
Found these plans for sheet balsa - they seem the ideal starting kit. The Cessna 180 looks particularly good
http://www.parmodels.com/Plans/index.htm
Look under the link
" Reproductions of the old 1950's Top Flite Jigtime Models, Carl Goldberg and Keil Kraft EeZeBilt sheet balsa rubber powered Free Flight models"
Downloaded plans
knlever is offline Find More Posts by knlever
Old Jul 24, 2010, 02:13 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Yep, some nice plans there.
Do a search back a few years in this free flight section and you'll find some threads about guys that built some of these jigtime models from the plans when Paul first put them up on his site.
BMatthews is online now Find More Posts by BMatthews
Old Jul 25, 2010, 12:45 AM
knlever is offline
Sri Lanka
Joined Mar 2010
Great idea- I was looking for these . for reference I post these links here:
http://www.rcgroups.com/forums/showt...hlight=jigtime
Other links to vintage rubber scale : I really should start an info thread:
http://www.cahood.com/webcat8c.htm
Found a video as well. That plane is really light
Indoor Freeflight Cessna 180 (0 min 43 sec)
Old Jul 25, 2010, 10:18 AM
knlever is offline
Sri Lanka
Joined Mar 2010
Downloaded the plans
Downloaded the PDF - it is a small model about 40 cm span - smaller that I thought, I will have to enlarge it to a 1:20 which means a 55cm model
Old Jul 25, 2010, 01:29 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
I assume you'll then be working to make it using card stock and other materials?
Old Jul 25, 2010, 03:54 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
How many turns for that flight? Where'd you get the helium?
Lovely!
howell
gwinhh is offline Find More Posts by gwinhh
Old Jul 25, 2010, 10:10 PM
PaulBrad is offline
Find More Posts by PaulBrad
PaulBrad's Avatar
Independence, KY and Brandon, MS
Joined Jun 2000
Howell - When built with decent 1/32" balsa they all fly like the model in the video. When it comes to Free Flight, light is might. All of the prototype models I built from the plan packages fly like the Cessna 180 in the video. My models use a single loop of 1/8" rubber that is about 1.5 times the length between the prop hook and rear anchor. I typically get 1100 to 1200 turns on a lubed motor. That translates into flights in the 40 second range indoors.
The orignal kits used 1/16" balsa that was quite heavy. As a result their flying performace suffered greatly. When built light they really show what good designs these models were.
Paul Bradley
PaulBrad is offline Find More Posts by PaulBrad
Old Jul 26, 2010, 10:21 AM
knlever is offline
Sri Lanka
Joined Mar 2010
Well I will be using cereal box cardboard, whatever that is called, bamboo and recycled 80 gsm paper or so.
That, plus several problem solving methods will be reviewed and a few chosen. I have made such a lot of progress using problem solving methods, for some people it is built in to their thinking, some people try trial and error or maybe engineering practices they are used to
To recap:
Abstraction: solving the problem in a model of the system before applying it to the real system
The model follows the standard flight model - lift, drag, weight, thrust
The model should have enough wing area to support its weight. This should happen at its 'cruising speed', that is the speed that the motor is able to sustain through the prop. Weights should be kept at less that 40 g, the wing will sustain the weight, as verified by testing. The power of the prop against drag is not verifiable through this model
Analogy: using a solution that solved an analogous problem
Looking at similar models - 40 g weight and the 50 cm span, together with the prop and rubber used should sustain the model.
Brainstorming: (especially among groups of people) suggesting a large number of solutions or ideas and combining and developing them until an optimum is found
Not tried
Divide and conquer: breaking down a large, complex problem into smaller, solvable problems
An obvious physical approach would be to break the model down into wings, tail, fuselage and rubber power. Building a wing is basically OK, I can do that, and the tail surfaces pose no problem. The rubber motor has been tested. The only problems not solved are :
- ensuring a strong wing/fuselage attachment,
- a light fuselage
- a fuselage that will resist the pull of the rubber.
These may be tested separately
Hypothesis testing: assuming a possible explanation to the problem and trying to prove (or, in some contexts, disprove) the assumption
This has been looked at : high weight, low power not enough rigidity, these will be addressed
Lateral thinking: approaching solutions indirectly and creatively
Not tried
Means-ends analysis: choosing an action at each step to move closer to the goal
This is not tried as it will involve several models with each one improving on the other - will use up a lot of time and materials
Method of focal objects: synthesizing seemingly non-matching characteristics of different objects into something new
not tried
Morphological analysis: assessing the output and interactions of an entire system
Not Tried
Reduction: transforming the problem into another problem for which solutions exist
Not tried, redundant in the light of the above
Research: employing existing ideas or adapting existing solutions to similar problems
Not tried, lack the instrumentation to carry out research with measurements
However adapting existing solutions is part of the plan
Root cause analysis: eliminating the cause of the problem
Applies to an existing trial model that was built
Root cause related to construction methods
Trial-and-error: testing possible solutions until the right one is found
I hope I do not have to do this - this is too wide open, actually it leads to too many branches to follow, and I have been trying this so far which is very time consuming
PCDA
Plan-Do-Check-Act
http://en.wikipedia.org/wiki/PDCA
Appeciation
What good things need to be improved?
So what is the final yield - applying all these approaches?
- Aim for a weight of 40g or less
- Wingspan of 50cm
- Build tail surfaces and a test fuselage, test strength of attachment points and brace as necessary
- build a model of the model on a smaller scale, study it and correct any problems
This may seem 'trivial' , however I know that I have looked at the problem from many angles, and have obtained some useful information. I have a specific method now for trying out, and know what to do after that.
I will print out the existing plan in its 1:32 size, cut and paste on a cereal box and test for strength, weight, attachment points etc. Then I have to act.
Should be fun
Last edited by knlever; Jul 26, 2010 at 08:19 PM. Reason: No one had yet responded to my post so I edited it to save space
Old Jul 26, 2010, 10:28 AM
knlever is offline
Sri Lanka
Joined Mar 2010
Paul
Excellent plans and these kits have a charm of their own. How much do the originals weigh and how much did the 1/32 models weight - all up with rubber?
Could you tell me what sort of rubber and prop you are using? The models shown here give specs - 30-40 g and 25" or 50 cm or so wingspan. http://darehobby.com/ see under Airplanes > rubber 1
Old Jul 26, 2010, 02:42 PM
gwinhh is offline
Beaumont tx
Well, I see at least two differences between my old ones and yours -- wood thickness and number of turns.
Aside from THAT.....
thanks, as always
howell
gwinhh is offline
Beaumont tx
PS. When do you live in Brandon? I grew up in Starkville.
howell
Old Jul 26, 2010, 06:33 PM
knlever is offline
Sri Lanka
Joined Mar 2010
With the original plan and its standard the wood thickness, the instructions in the manual state that 75 to 1000 turns will get you 20 to 30 seconds of flight.
Advertising?.
Old Jul 26, 2010, 11:30 PM
PaulBrad is offline
PaulBrad's Avatar
Joined Jun 2000
knlever - For my Jigtime reproductions I use a single loop of 1/8" rubber that is 1.5 times the length between the prop hook and rear motor anchor peg. With rubber the models weight in the 15 gram range. Some slightly lighter and some just a bit heavier. I am using a 5.5" plastic prop of the style sold by Sig for models like the AMA Cub. My stated flight times are indoors. Outdoors times go up due to passing lift. The original kits could fly for the stated advertised times if you got one made from decent balsa, you replaced the prop with one of larger diameter, replaced the supplied rubber band with proper lubed rubber, and you used a winder. Not likely though with the supplied prop and rubber band.
The original models were generally in excess of 30 grams. They were guaranteed to fly and fly they did. Just not very long. Back in the day there used to be contests for the Jigtime models. The rules allowed you to replace the tiny kit prop and you could sand the wood to thin it out. All of the kit printing still had to be present so the builders would sand the back side of the die cut sheets before removing the parts. They would sand the sheet to nearly paper thin. The dense balsa allowed a lot of sanding without dramatic loss of strength. Competitive times, indoors, were well in excess of a minute.
Howell - my house in Brandon, MS is near the big Ross Barnett reservoir.
Old Jul 27, 2010, 09:20 AM
gwinhh is offline
Beaumont tx
Lovely country; I remember when the RB was built and they had to reroute the Natchez Trace -- through some residential districts as I recall.
howell
Old Jul 29, 2010, 07:15 PM
knlever is offline
Sri Lanka
Joined Mar 2010
Just in case : there is a thread about conversion to RC of a similar plan:
http://www.rcgroups.com/forums/showthread.php?t=657479
For free flight electric what sort of motor/batt/prop will work, I wonder...
Discussion Free plan: Gas Camera Model - non-scale gas from 1938 Model Airplane News planeman Vintage & Old-Timer Designs 9 Jun 12, 2013 02:10 PM
Discussion Vintage Model Airplane Plans rkohlme The Builders Workshop 1 May 12, 2010 10:05 PM
Help! Need Help Finding Cessna 180 Plans piloto22 Scale Fuel Planes 13 Oct 19, 2009 06:57 PM
Build Log Model Airplane News, p51 built from plans saucerguy Electric Warbirds 15 Apr 16, 2008 12:33 AM
Discussion Planes built from"The Plans Page" plans dogisland Scale Kit/Scratch Built 11 Apr 09, 2007 07:20 PM
