Old Jul 24, 2010, 09:18 AM
davew478 is offline
Find More Posts by davew478
davew478's Avatar
United States, CA, Escondido
Joined Feb 2006
Question
Aurora 9
Can the Hitec FM sythesized RF module be used with the Aurora?
davew478 is offline Find More Posts by davew478
Latest blog entry: FlyZone Aircore "Principle"
Old Jul 24, 2010, 10:45 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Only the new Spectra Pro FM module will function with the Aruroa...older units will not work.
http://hitecrcd.com/products/transmi...ectra-pro.html
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Jul 26, 2010, 09:25 AM
BRENDAN LUGO is offline
Find More Posts by BRENDAN LUGO
Hitec service
BRENDAN LUGO's Avatar
San Diego
Joined Nov 2004
The older modules are not compatable with the Aurora. The Spectrs Pro 72 Mhz synth module will be available in September for the Aurora.
BRENDAN LUGO is offline Find More Posts by BRENDAN LUGO
Old Jul 28, 2010, 10:20 PM
davew478 is offline
davew478's Avatar
Joined Feb 2006
The Spectra Pro 72 Mhz synth module
Are you going to have to take the plastic 2.4 module antenna out of the Aurora and screw in a metal antenna for the Spectra Pro module to work?.........Dave
Old Jul 29, 2010, 07:06 AM
Joined Apr 2007
Yup.
turn radio off
snap off the 2.4 antenna
remove the 2.4 modual
unscrew the rest of the 2.4 antenna mount
screw in the metal fm antenna
snap in the fm modual
turn radio back on and select model, freq etc...
It really doesn't take long at all, but it's more than flipping a switch
Now I have the question: Will the Spectra Pro modual come with the needed antenna?....I'm hoping so since it's specifically for the Aurora, and the radio does not have an FM antenna.
Old Jul 29, 2010, 07:58 AM
davew478 is offline
davew478's Avatar
Joined Feb 2006
Aurora 9
Will the exchange 2.4 module with the built on antenna work on the Aurora?
Then you could leave the metal antenna in. I don`t like the module with the wire dangling for the antenna, it`s just a accident waiting to happen. I would exchange mine for the built on antenna type any day.....Dave
Old Jul 29, 2010, 08:47 AM
Joined Apr 2007
I don't know if that module will fit/work Dave. Dispite the short comming of the dangly bits, I think the Arurora is better off with the "correct" module in place.
I like my planes too much to risk radio hacks. Just my opinion.
I wonder if there is a technical reason that requires the removal of the FM antenna for 2.4 operation?? Perhaps it's designed the way it is for a reason?? More likely it was a clever way to keep dust and dirt out of the un-used antenna hole and keep the traditional look
Old Jul 29, 2010, 09:03 AM
Hitec service
San Diego
Joined Nov 2004
Yes it will. (it's the same module, it just has a different antenna) To date the "dangling antenna wire" has not been a issue for anyone from a service/repair stand point. Now not paying attention and plugging things in backwards is a different story.
davew478 is offline
davew478's Avatar
Joined Feb 2006
Aurora
I`m talking about the Hitec 2.4 module they gave you for $29.95 if you sent in your old FM hitec module..... Dave
Old Jul 29, 2010, 09:13 AM
davew478 is offline
davew478's Avatar
Joined Feb 2006
Don`t get me wrong. I love Hitec. I have spent tons of money on Hitec stuff and the customer service is great at Hitec. You guys have hooked me up and helped me out many times and I`m just about to pull the trigger on a Aurora purchase........Dave
Old Jul 29, 2010, 02:40 PM
davew478 is offline
davew478's Avatar
Joined Feb 2006
Aurora 9 Synthesized 72MHz Tx & Freedom 9Ch Syn
The Hitec Aurora 9 Synthesized 72MHz Tx & Freedom 9Ch Syn that is coming out in Sept. Will it be able to use the Spectra 2.4 module with the antenna mounted to the module?
Old Jul 29, 2010, 06:12 PM
Hitec service
San Diego
Joined Nov 2004
Yes.
Old Jul 30, 2010, 07:49 PM
davew478 is offline
davew478's Avatar
Joined Feb 2006
Aurora 9
Ordered Aurora 9 from Tower crazy discount and free shipping.
Sold Hitec Aurora 9 2.4 TX & Optima 9 chn 2.4 RX-$359 Howard L Aircraft - General - Radio Equipment (FS/W) 0 Apr 20, 2010 08:19 AM
Sold Aurora 9 - 9 Channel 2.4GHz Aircraft Computer Radio 3DTRYER Aircraft - General - Radio Equipment (FS/W) 1 Apr 05, 2010 04:37 PM
Discussion Aurora 9 manual vhoward1122 Hitec/Multiplex USA 15 Oct 26, 2009 06:22 PM
Discussion Hitec Aurora 9 Manual now available. MikeMayberry Radios 31 Oct 08, 2009 06:07 PM
Discussion Hitec Aurora 9 Trainer Link jedorme Hitec/Multiplex USA 1 Aug 24, 2009 10:36 PM
