Old May 08, 2011, 04:45 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by arnaldo26 View Post
can fox 800 without filter induce failsafe on our dsss 2,4ghz(assan)?
Yes, absolutely. 1.2-1.3Ghz video Tx's spew 2nd order harmonics directly into the
2.4Ghz band. It doesn't matter what 2.4Ghz Rx you use, they will all be
negatively affected to pretty much the same degree. You *must* use a low pass or notch filter to block
the harmonics at the video tx side.
ian
Daemon is offline Find More Posts by Daemon
Old May 08, 2011, 05:29 AM
arnaldo26 is offline
Find More Posts by arnaldo26
Italia, Emilia Romagna, Modena
Joined Mar 2009
ian
ok but notch filter works only for one channel?
arnaldo26 is offline Find More Posts by arnaldo26
Old May 08, 2011, 07:43 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
ian
I am using Fox-800 with stock antenna on my SlowStick with Corona 2,4GHz receiver running from one battery and have been out to 1Km without a glitch.
soon i will be trying to go further.
Teo
teopbako is offline Find More Posts by teopbako
Old May 08, 2011, 09:57 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Teo
with which 2.4ghz system ?
i3dm is offline Find More Posts by i3dm
Old May 08, 2011, 10:20 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
An old Graupner MX-12 that i have moded to 2.4GHz with the
Corona DIY DSSS V2 system
http://www.hobbyking.com/hobbyking/s...idProduct=9770
Teo
Old May 08, 2011, 10:22 AM
Joined Mar 2009
Teo
my quad with channel 6 and assan 2,4 crashed at about 100metres
Old May 08, 2011, 12:23 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No. A notch filter is call that, because it passes all frequencies except for those
in the notch. The OMM notch filter has two notches which they set in the middle of 2.4Ghz
band (for 2.4Ghz control) and 1.5Ghz (for GPS). It acts the same regardless of channel.
Note that some receivers (FrSky for one) are directly influenced by lower frequencies (900Mhz)
and for those neither the low pass or notch filter are useful.
Teo
1km is not very far. Whatever range you can achieve without the filter, could
be more than doubled with it.
ian
Old May 08, 2011, 01:08 PM
Joined Mar 2009
ian
ofr my assan i think i will buy lpf from dpcav...
what channel i have to use? 5 is good?
Old May 08, 2011, 01:11 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I use ch9 (1280Mhz) because that's the legal one, and does not fall in
the band reserved for aeronautical navigation (ILS/MLS/DME control frequencies
used by commercial aircraft) as ch5 does.
ian
Old May 08, 2011, 01:16 PM
Joined Mar 2009
ian
ok...but i'm not american so what channel is the best for 2,4rx with lpf?
can i power the vtx with the same lipo of quadcopter? what i have to use?
thank you!
Old May 08, 2011, 01:30 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
DME/P control frequencies are the same world-wide, thus flying in that band
is pretty much not legal anywhere.
Beyond that, if you use the low pass or notch filter, it shouldn't
matter what channel you choose.
ian
Old May 08, 2011, 01:33 PM
Joined Mar 2009
ian
ok thank you...
can i power the vtx with the same lipo of quadcopter? it makes any interference?
thank you!
Old May 08, 2011, 01:56 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
So would you reccomend the Fox800 or the 1.2 700mw one from ReadymadeRc?
I could go either way, I just want the best performance. -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old May 08, 2011, 02:08 PM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
hi. i looking for Vrx with will work with this Vtx
http://www.lowpricerc.com/product_in...roducts_id=986
how know where i can get one ? Frequency: 1080.1120.1160.1200
jsxx is offline Find More Posts by jsxx
Old May 08, 2011, 03:12 PM
teopbako is offline
Ikaruswannab
Joined Sep 2009
I only have tested Fox-800 and i have to say that i have been very lucky.
I use the HK cam that has on its back the Fox-800 VTx hot glued!.
All running from one battery on 1280MHz in conjunction with 2,4GHz RC and have been to 1Km without one glitch and i mean it, not one!.
And i have to say that i wasn't flying in a str8 line.
For me is the way to go on 1280MHz if u r in a low budget.
I'll be getting a second one soon to create a diversity system.
Teo
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
