Joined Sep 2010
Is this: http://www.securitycamera2000.com/pr...5CH-700MW.html
the same as this: http://www.dinodirect.com/1-2ghz-700...R.html?cur=USD What about the losses frequency lock at 8,75V, if I would power the vtx with a 3S lipo, that would mean 2,9V per cell, which would mean the lipo is already discharged, so this info is not a problem right? Regarding duration of flight. |
NORWAY
Joined Jan 2011
can you help me with a very good combo off all i need to go fpv with my octo i have today the 5,8 ghz fvp gear,but i get alot off noise in the camera,i have ferit on all off my esc and have placed it so fare away from everything so i get it,but i need a better system how penetrate better then the5,8 i am flying in the forest and stuff liek that and want a good system for it,can you help me with links to everything that a need 1,2 og 1,3ghz?? thanks kjetil tønnesen norway |
Joined Apr 2005
Hey guys,
my first FPV model is a Funjet with a BOB 800mW 1.2Ghz set. i test flew it this morning in a deserted field and flew 4 gret flights with 0 problems. so i went home, installed my DVR on the Rx tripod (next to Rx) and went out to the local RC flying field. This time i had a problem where the picture freezes sometimes for 3-4 seconds as can be seen on the video i recorded:
What do you guys think can cause this and how do i avoid is ? is it related to the DVR being close to the Rx or to the fact that the video signal is now passing through the DVR ? or could it be related to outside interference of some sort which i didnt have at the deserted field i did the test flight in ? thanks for your comments. PS - it cause a small carsh on flight #2 when the video froze in the middle of a low altitude roll.. hehe ! |
And just so it's clear, the signal coming from the camera through the Tx to the Rx itself
cannot freeze. It's pure analog so always displays in realtime. It had to be happening in the DVR. Looks like it doesn't like more than a little static. ian |
Latest blog entry: My 2012 FPV year in Review
It freezes up when it sees noise.
I thought that was pretty obvious by now. The problem is, it's likely to do it when you need it the most, say you have a problem and your plane goes down far away. Edge of range, poor LoS, bad antenna orientation will produce noise, and then your recorder freezes up and you have no idea where the plane goes down. There's a HUGE recorder thread with lots of usable options. My choice is the most expensive one, so I'm not going to offer it here. ian |
Joined Apr 2005
Thank you. again, that does make sense. the strange thing is that usually when i fly overhead (with omni antenna) there is a little noise thats visible in the video, and its still visible through the DVR with no freezing. |
It's a matter of degrees. Test it around your house with the Rx antenna removed,
and it'll happen all the time. ian |
concerning the LawMate VidTx 1.3ghz ....is 1000mW too much/overkill?????
http://www.dpcav.com/xcart/product.p...cat=279&page=1 or should I just go with the 1.3ghz 700mW ? http://www.readymaderc.com/store/ind...roducts_id=324 What ones have worked out great without any issues? |
| Thread Tools | |
| Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? | iacei | Video Piloting (FPV/RPV) | 24 | Jul 22, 2010 08:49 AM |
| Discussion 1.2Ghz Tx Only: Where to buy a cheap one | iacei | Video Piloting (FPV/RPV) | 9 | Jun 07, 2010 02:03 AM |
| Question esc all one, can i change to different tx/rx? | Fossy313 | Beginner Training Area (Aircraft-Electric) | 4 | Jan 30, 2010 04:07 AM |
| Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro | _Spud_ | Video Piloting (FPV/RPV) | 1 | May 23, 2008 12:31 PM |
| Are 1.2ghz Tx and Rx any good. | JustFly | Aerial Photography | 3 | Apr 22, 2005 11:46 AM |
