Old Mar 20, 2011, 10:42 PM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
Since there appears to be an appreciation in this thead of the advantages of circular polarization, here is a CP Biquad design I did which is optimized for multipath rejection:
I took great care to get all measurements within 0.5 mm which resulted in the prototype matching the predicted SWR almost perfectly:
For this design I focused on getting the best axial ratio for a near 10 dBic gain antenna. The result is that the opposite polarized signal is suppressed by aproximately 20 dB over the primary coverage area of the antenna:
Note that this antenna is LHCP. It is easly converted to RHCP by fliping the elements top to bottom.
By the way, the above two plots are quite effective for showing the ratio of LHCP vs RHCP. You can clearly see that the high ratio is maintain over all the main coverage of the antenna in both Az and El.
Additional construction details here:
http://www.rcgroups.com/forums/showt...147430&page=28
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Mar 23, 2011, 09:19 PM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
Can some one remove there sunsky 800mw cover off and snap a picture of it? i wanna see if it looks like mine, since mine has problems.
paintball_kidz is offline Find More Posts by paintball_kidz
Old Mar 23, 2011, 09:50 PM
El1m1nate is offline
Find More Posts by El1m1nate
Melbourne, Australia
Joined Oct 2010
There are so many different models/revisions of these.. its crazy.. I have three and they all dont look like yours...
I bought one 2 months ago... that had the wires soldered to the top of the PCB [yours are on the bottom]
I bought 2 a couple of weeks ago, and they had a connector, instead of cables directly soldered on!..
What problems do you have?.. Ill get you a photo of mine when I get to a camera..
--El1m1nate--
El1m1nate is offline Find More Posts by El1m1nate
Old Mar 23, 2011, 10:02 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Can't see enough detail in your pic to see anything wrong.
Here's what it should look like.
Pretty amazing to consider that people are hand soldering
these SMT components.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 23, 2011, 10:10 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
just inability to power on or change channels in the cold. Im doing test right now... at room temperature powers on fine and cycles channels with now power lost. In the fridge and freezer it will not power on. If i plug it in before hand and then put it in the fridge or freezer it will stay on, but as soon as i cycle the channels it shuts off.
zoomed in, do you know what that knob does?
Old Mar 23, 2011, 10:15 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That could be a sign of a bad solder joint or crack in one of the traces
that pulls apart when it's cold. Try gently pushing on or flexing the board
when it's powered but otherwise not working. Generally you'll need a
good magnifying glass or hand held microscope to find cracks.
ian
Old Mar 23, 2011, 10:21 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
it appears that maybe 2 of these parts on mine are touching and yours are not? could that be a problem.
http://www.flickr.com/photos/tuandinhap/5554434477/
Old Mar 23, 2011, 10:37 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No, those just look like intentional differences in the board/layout design.
ian
Old Mar 23, 2011, 10:54 PM
Joined Oct 2010
If it is a crack/bad solder joint.. why not put it on an [old, unused] frying pan/hot plate and try to reflow it??
I have done reflow soldering on a clothes iron, and it works well.. the added benifit is you have a metal case that contains the pcb - which means components cant fall off the bottom.. maybe the vias.. otherwise use a hot air gun [or flame, reaaaly far away from the components] to get at it from the top..
Old Mar 23, 2011, 10:57 PM
Joined Oct 2010
Yes. They thought 'lets not follow the recommended application schematic and leave out the decoupling cap.', then went ahead and made millions of the PCBs, tested them and said 'oops, it needs that cap!!! I know, lets manually solder it in!'.
hehe
--El1m1nate--
Old Mar 23, 2011, 11:04 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
Well it does power when its cold, it just doesnt power on 100% just enough to flicker or barely show the screen light.
Old Mar 23, 2011, 11:12 PM
Joined Oct 2010
Hmm i wonder if anyone else is having similar problems.... i might chuck mine in the freezer and see how i go!! What temp approx?
Old Mar 23, 2011, 11:15 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
i have no clue, but its above freezing level for sure lol. i just toss it in there for a few minute untill the metal case is cold
Old Mar 26, 2011, 09:51 AM
Joined Oct 2010
I have a breakthrough [i think]..
I didnt have any problems with 1.2ghz and hxt900s on my assassin wing..but things where well spaced..
I just installed FPV on my new mini skywalker.. the camera is know [$11cmos] for interference.. I made a 1280mhz IBCrazy Inverted Vee and stuck it on.. tested the system.. and immediatly saw jittering on the hxt900 pan servo and interference on the vid signal [the camera was making a buzzing noise aswell].
What??!..
so I play around [all while having my tx on throttle cut].. and move the active element very close to the HK 6ch v2 rx [2cm] ... and my motor starts!!!
So that gets me to the conclusion that the output from the vtx is interfering with the rx and probably messing up the power for the cam.. [i had terrible lines, and still had lines at the best vtx pos]..
Then I though.. the I-Vee is horiz/vert polarized.. so is the rx antenna... why not try a CP on the vtx??
I slap on the skew planar wheel i made before, instead of the Vee and... silence..
No jittering from the hxt900..
Crystal clear picture!
It worked!
Im going to do some range tests today and see how it goes!!
Could you guys who have the same issue with jittering/etc, test a CP ant, to see if you have a similar result??
Edit: I am using a sunsky 800mw tx & rx
--El1m1nate--
Old Mar 26, 2011, 10:15 AM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
Originally Posted by recep View Post
Could you please help me about a confusing situation I'm experiencing. I have got two identical fox 800 tx units from bev rc and their receivers. I connect my vee antenna to one tx power it and no image on the googles until I touch the antenna once then the image comes. I connect the vee to the other tx power the system and I have the image without touching the antenna. With stock antennas everything is normal. I tried it with two receivers same thing happens with that tx and vee combination.
any one?
recep is offline Find More Posts by recep
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
