Old Mar 03, 2011, 08:42 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Originally Posted by bah7566 View Post
I've had the same issue. No idea why. Mine is a home made V on 900MHz.
Bruce
Who makes your transmitter?
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Mar 03, 2011, 10:18 AM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
An antenna that is not matched well will cause the Tx to run warm/hot. You can get a SMA dummy load that will plug into the Tx antenna slot. If the TX then under the same voltage runs cooler then it is indeed the antenna. Measuring the current draw will also be a good test but a bit more difficult.
Antennas are fickle. Using my wattmeter I found that on my Alex design "V" for 900mhz that just moving the coax at the base of the V changes the efficiency very noticeably. I did not realize how critical this was. Just as a note for 900mhz users. I tested 3 TX's of the cheap Chinese types rated at 500mw and all exceeded that output.
Tom
tom3holer is offline Find More Posts by tom3holer
Old Mar 03, 2011, 10:20 AM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
http://www.youtube.com/watch?v=y_LUAXuPqZI
Bruce
Bad connection or solder joint?
twinturbostang is offline Find More Posts by twinturbostang
Old Mar 03, 2011, 10:55 AM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
deleted
Old Mar 03, 2011, 12:44 PM
bah7566 is offline
Find More Posts by bah7566
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
It's a 200mW from Range Video.
http://www.rangevideo.com/index.php?...roducts_id=138
Bruce
bah7566 is offline Find More Posts by bah7566
Old Mar 03, 2011, 12:45 PM
bah7566 is offline
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
Good thought but I checked all the solder connections and they were all good.
Bruce
Old Mar 03, 2011, 01:49 PM
Joined Mar 2008
Bruce
Is Rangevideo using Lawmate transmitters?
Old Mar 03, 2011, 02:30 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 04, 2011, 04:57 AM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
does the sunsky receiver use a sma or rp-sma connector?
paintball_kidz is offline Find More Posts by paintball_kidz
Old Mar 04, 2011, 06:47 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Sunsky uses a standard SMA connector on the TX and an F connector on the RX.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 04, 2011, 06:27 PM
wiper1974 is offline
Find More Posts by wiper1974
Croatia
Joined Dec 2010
Hello everyone.
I got LM 1.2 1w Tx/Rx, so I try to find the optimal frequency for the video signal. For now, while testing, everything works perfectly (for testing on the bench I have a cooling fan dont worry) Now channels are configured as shown in these pictures:
I do not know what channel it is. According to the Tx it is 8th channel(all three dip switches are the right of the numbers 1 2 3) , but the RX can not be 8 channel because the AB switch in position for channels 1-4, or not?
I know this is already explained somewhere but no matter what I've read a lot of posts still do not understand in what position should be dip switches for certain channels. Can someone explain to me how to set dip switches for different channels.
wiper1974 is offline Find More Posts by wiper1974
Old Mar 04, 2011, 07:15 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
Bruce
That's crazy you too!
My friend made a home V.
I looked at it close and it has a lot of solder and one pole wire is longer than the other by a small difference.
Funny, he uses the rubber ducky and it goes straight to video but he has to touch the G spot on the V with his finger for things to happen
sim_io is offline Find More Posts by sim_io
Old Mar 06, 2011, 01:13 PM
FPVORDIE is offline
Find More Posts by FPVORDIE
Now which way was home.....
Joined Feb 2011
Sunsky 1.2ghz 800mw
ch1) 0.910
ch2) 0.980
ch3) 1.010
ch4) 1.040
ch5) 1.080
ch6) 1.120
ch7) 1.160
ch8) 1.200
ch9) 1.240
ch10) 1.280
ch11) 1.320
ch12) 1.360
FPVORDIE is offline Find More Posts by FPVORDIE
Old Mar 06, 2011, 03:04 PM
sim_io is offline
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
How much more sensitive is the black lawmate receiver compared to the sunsky (FOX?) is it like -95dbi?
Old Mar 07, 2011, 06:53 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
Difficult to say. It's more the assurance to have a good quality receiver with the saw filter mod already done.
Some Fox receivers are poorly made and give crappy results. But a good Fox Rx with saw filter mod will give the same results.
One drawback of the Lawmate Rx: not compatible with the latest IBcrazys antennas
One advantage of the lawmate: small and sma plug.
iacei is offline Find More Posts by iacei
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
