Old Feb 22, 2011, 09:44 PM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
Originally Posted by awa202 View Post
so like a ZIPPY Flightmax 1000mAh 3S1P 25C?? could this power my camera at the same time?
yeah, only if the camera is 12v
paintball_kidz is offline Find More Posts by paintball_kidz
Old Feb 23, 2011, 03:22 AM View Post
khunnie
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Feb 23, 2011, 05:42 AM
El1m1nate is offline
Find More Posts by El1m1nate
Melbourne, Australia
Joined Oct 2010
My sunsky 1.2ghz 800mw tx is dead!!!
- any idea where to find another one? or something cheap but usable [with fast shipping!]. [i am already getting that small untested tx mentioned on the first page]
- can it be fixed? I dont know exactly how it died, but i suspect reverse voltage.. i think the micro is dead or not working well as the display shows 8 [should be 9 from EEPROM anyway], but the button doesnt do anything.. nothing is burnt on the pcb..
El1m1nate
El1m1nate is offline Find More Posts by El1m1nate
Old Feb 23, 2011, 08:32 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
The voltage regulator is surely burned. Try to apply 5v to the output of the regulator and look if it revives the Tx.
iacei is offline Find More Posts by iacei
Old Feb 23, 2011, 12:43 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
This sunsky 1,2 Ghz 400mW, thats from China right, so there will probably be some customs issues in Europe right? Should i buy from some EU dealer, I fly 2.4ghz so I'll buy a 1.3 ghz or 900 mhz system, 400-500 mW will do right i don't want crazy long distance max 3-5km..
msev is offline Find More Posts by msev
Old Feb 23, 2011, 05:27 PM
Joined Oct 2010
Hmm, if i get it working, and on all my other equipment, i think ill install some diodes to prevent this from happening again..
the vreg is the first one coming into the case.. 78L05 - http://www.fairchildsemi.com/ds/LM/LM78L05A.pdf
sot-89 case style... bloody stupid naming system..
The interesting thing is the 470ohm resistor before the vreg.. which should supply 255mA of current.... i wonder if we can replace that to get higher power output .. my though is, if the components can take the new ammount of current, the only problem would be more heat..
Old Feb 23, 2011, 05:51 PM
Joined Oct 2010
yep, the 5v reg is dead!! [after removing dead reg, powering with 12v lipo and 5v regulated into the place of the old reg.. the numbers at least work..]
The circuit does need 12v for powering the 8 seg display... maybe even the mosfets/transistors for the radio...
time to switch out the reg and do more tests [and install a diode!]
Edit: scrap that 470ohm resistor!! thats the problem... at least in my case.. i had a look at the pads, and 12v was connected to the output of the 5vreg through the 470ohm resistor! thats what probably fried my first reg... and the second i just installed.. third is fine after removing the resistor altogether!
Old Feb 24, 2011, 11:21 AM
msev is offline
Joined Sep 2010
Are there any chinese (hobbyking, rctimer) cheap digital servos (for twinstar for example) which are free from jittering?
Also if someone has any experience regarding customs issues when buying video tx/rx from China to Europe, please tell..
Cheers
Old Feb 24, 2011, 12:35 PM
iacei is offline
Luxembourg
Joined May 2009
no problems at all ordering HK stuff to EU I buy some each and everyday.
for the servos, look at the 1st page, I made a list, you can buy some Hitec from hobbyking for example.
Old Feb 24, 2011, 12:43 PM
msev is offline
Joined Sep 2010
What about issues if buying a video transmitter receiver? I heard that some guys didn't get their items through customs...
Old Feb 25, 2011, 04:45 AM
Tommygunn is online now
Find More Posts by Tommygunn
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
Msev,
What country are you in?
I'm going to presume the UK. If so, and this probably goes for Europewide, then you can pretty much import anything you like. However, it will be its actual use that may be illegal i.e. the frequency you have chosen.
You need to check the internet, BIS (formerly DTI), Civil Aviation Authority etc to see if your chosen frequency is legal.
Here's a handy website to calculate possible import duty for your equipment.
It will give you a heads up, in case you get stung.
Just work your way through the sections to find the Taric code that is most appropriate for your purchase.
Remember for the UK it is (Product + Postage(convert to local currency))+ Import Duty (Taric %) + VAT (Tax).
You pay the difference between the local currency amount and the all up total.
Another useful website to find out other extras that might be tagged on i.e. handling charge, Tax free allowances etc is this:
http://www.sloanefox.freeserve.co.uk/importukduty.htm
Tom.
Tommygunn is online now Find More Posts by Tommygunn
Old Feb 25, 2011, 10:58 AM
msev is offline
Joined Sep 2010
Thanks Tom , I'm from your east neighbouring country I'll see what will be the cheapest option,...But as I see people or also transmitting video on "ilegal" frequencies,...is this considered to be a big felony or not...
Old Feb 25, 2011, 01:14 PM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Does anybody have a tutorial on how to strip down the Sunsky 1.3GHz 800mW Tx antenna?.
Just stripped down the Tx and now the antenna is really huge and heavy.
Teo
teopbako is offline Find More Posts by teopbako
Old Feb 25, 2011, 01:40 PM
c4v3man is offline
Find More Posts by c4v3man
It's pronounced Caveman...
Reno, NV
Joined Nov 2009
Teo
Very carefully, the antenna tube is quite fragile/thin.
Honestly, you can cut about a 1/4" above the thick hinge of the antenna and just pull the top off completely (this picture isn't fully trimmed, I still have a little ways to go). Another poster found that this raised the effective frequency closer to 1.28Ghz (around 1240Mhz if I recall), but obviously QC on these is so terrible that you don't know what frequency it's setup for from the factory.
I can upload a pic of the finalized antenna trimming if you need it for reference. At the bottom of the metal tube is a ridged plastic connector, so I'd maybe "carve/shave" one spot of the antenna so you can see where the tube ends, then slowly and lightly cut around the rest of the antenna at that point until you can pull the rubber off. As I said, even medium pressure with a new/sharp blade can sever the tube.
c4v3man is offline Find More Posts by c4v3man
Old Feb 25, 2011, 08:55 PM
tom83 is offline
Find More Posts by tom83
Rather be flyin
tom83's Avatar
Tucson, Arizona
Joined Mar 2008
Is this comparable to the BOB unit(is it the same thing)?
http://www.lowpricerc.com/product_in...roducts_id=986
tom83
tom83 is offline Find More Posts by tom83
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
