Old Feb 21, 2011, 01:11 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
I would not expect great video to all around your class rooms.
Maybe two or three classrooms away or so.
its nothing like it would be in the air.
Your audio is just a mater of hooking/wiring up the mic properly.
Just like you would for your plane
Originally Posted by paintball_kidz View Post
I cant seem to get my sunsky800mw to play audio D:< Im in a video production class at school and they are thinking of trying out live news broadcast since all our classrooms have a tv, so i was thinking of setting it up for them to do wireless video instead of streaming over lan.
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Feb 21, 2011, 01:30 AM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
I hooked up my video transmitter to my Canon 5dmkII with a rode shotgun mic and play really quietly and staticy, ive also tried plugging in music from my ipod and it still plays very quietly and staticy
paintball_kidz is offline Find More Posts by paintball_kidz
Old Feb 21, 2011, 06:43 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
I do agree with David. It seems like it would be a lot of effort to set up all of the classrooms, and in the end it would result with a lower quality video than if it went through a wire. The signal just wont penetrate cleanly.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Feb 21, 2011, 07:25 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Originally Posted by teopbako View Post
UPDATE:
Order placed: 2/16/2011
Order shipped: 2/18/2011
That is Fast!
And received two hours ago!!.
A quick question: Is there a way to strip down the Tx part without affecting performance. Is cooling necessary?
Teo
teopbako is offline Find More Posts by teopbako
Old Feb 21, 2011, 09:54 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
I normally fly 900mhz video, but I bought the SunSky 800 Tx/RX to try out.
I am (for now) using/testing the SunSky 800 Tx/RX in a home security setup. (see pic)
Setup in the picture is....
Camera, Mic and Tx in the garage, camera aimed thru the window at back door of house.
Using the stock antennas.
Cheap no-name amplified mic.
Big gold heatsink still on the Tx.
Set on Ch.9 1280mhz
Changed the SAW filter in the Rx. Original SAW filter (F-480-3) is wideband, approx 36mhz.
New narrow SAW filter is approx 17mhz. (D-480)
I tested before and after changing the SAW filter.
Before the signal was "ok" but tended to multipath and very sensitive to antenna position
After changing the SAW filter the signal (picture) is much "cleaner" and antenna position not as critical. Seems not as sensitive to multipath.
Audio is very good,
I can hear the furnace in the garage start up, and even when a car drives down the alley behind the garage.
Note that the signal has to pass thru at least 3 walls, (one of which is concrete) and get to the Rx which is below ground level in the basement.
I was using a cheap 200mw 2.4ghz setup for this setup.
Very grainy picture and prone to interference.
It worked... sorta... but very sensitive to multipath and even neighbors microwave oven.
I could always tell when they were cooking/heating something.
Now with the SunSky setup I have rock solid picture, and in over a week of the system being on 24/7, no interference that I have noticed.
Don't know if this helps you, but I think the SunSky system is pretty good.
For your audio issue all I can suggest is try a different mic.
Edit; you might need to use an amplified mic...
I don't know if that Rode mic is amplified?
galaxiex is offline Find More Posts by galaxiex
Old Feb 21, 2011, 10:13 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
About jitter-free servos: finaly I've found one absolutely jitterproof. It's HS-5085MG. And yes, it's digital servo. Please, if you can reproduce this problem, can you try any other digital servo? The idea is that digital servos are more resistant to nonstandard signal changes. We just need to proof this - those HS-5085MG works very well...
Rastislavko is online now Find More Posts by Rastislavko
Old Feb 21, 2011, 10:20 AM
David22 is offline
Joined Apr 2008
hs -5065mg and 5485hb's also work very well
Old Feb 21, 2011, 10:41 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
Jitter free servos
Added the following small list on the 1st page:
Esky EK2-0508
HS-5085MG
HS45, HS56, HS65MG, HS82 + all the Hyperion Atlas models
The EMAX servos from bevrc are certainly fine around 1280Mhz.
Avoid those:
9g blue ones do (rctimer, hextronic, turnigy, towerpro), Hitec HS82MG (Metal Gear), TPro MG90s and MG16R
iacei is offline Find More Posts by iacei
Old Feb 21, 2011, 08:45 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Do different brand Vtx's and Vrx's work togehter?
Just lost my Sunsky Vtx but still have the RX
beginner4life is offline Find More Posts by beginner4life
Old Feb 21, 2011, 08:53 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Yes, my Fox Vtx works fine with my LM rx's. So if the rx can tune the same channels it should work fine.
Derek_S is offline Find More Posts by Derek_S
Old Feb 22, 2011, 04:13 AM
Epic Huckin'
Surrey, BC
Joined Jun 2007
I think I may just ignore audio for now, I'm gonna rewire it and remove the mic. Are you guys using shielded wires comming out? I'm think of switching from twisted servo wires to shielded wires from a usb wires.
Old Feb 22, 2011, 06:14 PM
awa202 is offline
Find More Posts by awa202
NZ
awa202's Avatar
United States, NY, New York
Joined Dec 2010
hey guys just a noob question..
i have a sunsky 1.2 800mw.
want to put the video tx on my quadcopter for fpv. what lipo do you guys reccomend??? i thought it needed over 11v>??
awa202 is offline Find More Posts by awa202
Old Feb 22, 2011, 07:12 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
any 3s lipo will be fine.
Old Feb 22, 2011, 10:02 PM
awa202 is offline
NZ
awa202's Avatar
Joined Dec 2010
so like a ZIPPY Flightmax 1000mAh 3S1P 25C?? could this power my camera at the same time?
Old Feb 22, 2011, 10:11 PM
El1m1nate is offline
Find More Posts by El1m1nate
Melbourne, Australia
Joined Oct 2010
I got the sunsky 1.2 800mw and noticed the tx chews up power!...
2 hours and it ate half my 2200 batt.. the rx can run for much longer (~10hrs?)..
If you are worried about voltage, just get the ebay step up thingo mentioned here somewhere [first post?]..
The sunsky is def a pretty good system.. though it needs better antennas.
Its great compared to the 200mw 2.4 crappy hk system which goes 100m :/
and so far, there has not been any noticible interference from 2.4 [radio].
El1m1nate is offline Find More Posts by El1m1nate
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 09:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 03:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 05:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 01:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 12:46 PM
