Old Feb 15, 2011, 05:22 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Originally Posted by iacei View Post
Hot glue.... Very bad idea.... The case becames hot and your hot glue will melt.
Use epoxy.
... or silicone
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Feb 15, 2011, 12:42 PM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Has anyone used a Sunsky 800mW 1.3GHz system in combination with GPS with success?
I want to use one with my EZosd that uses a Locosys GPS and don`t konw if the will cooperate.
Cheers,
Teo
teopbako is offline Find More Posts by teopbako
Old Feb 15, 2011, 12:44 PM
alexedit is offline
Find More Posts by alexedit
alexedit's Avatar
United States, FL, Miami
Joined Dec 2008
are there any known issues with 1.2ghz and 72mhz ?
alexedit is offline Find More Posts by alexedit
Old Feb 15, 2011, 12:48 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Cheers,
Teo
I have used a fox 700 and a LM1W with GPS's; no problems and very fast locks, under a minute usually.. Just plan to space them out if possible. Mine are 24" apart sincce gps is near nose and vtx is near tail of my easy star.
Derek_S is offline Find More Posts by Derek_S
Old Feb 15, 2011, 12:51 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
I fly with them both a lot. The only issue I ever have is if the Vtx is near a PPM rx on the plane it can glitch them badly. lesson learned, put the RX near the tail or out on a wing (so the antenna wont pass by the vtx) and put the vetx far away elsewhere.
But, with a PCM rx I never had much problems and flew to a mile or so with them 8" apart.
Old Feb 15, 2011, 06:03 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
None whatsoever I've done 2 miles with the rp8d1 and the 400mw 1.2Ghz sunsky and the rc signal still felt solid. Like the above post said, you will get glitches if the setup of the 1.2Ghz tx and rx 72mhz are close but that's something you'll be able to see with some basic ground range testing.
sim_io is offline Find More Posts by sim_io
Old Feb 16, 2011, 12:07 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Hi,
Has anyone had problems with 1.2Ghz video and 2.4Ghz controlled for short (below 400meters radius) distance multi-rotors flights?
Thanks.
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Feb 16, 2011, 03:05 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
Just bought the Sunsky 800mW 1.3GHz (http://www.sunsky-online.com/view/13...ransmitter.htm) unit and as i can't find the info on their site i would appreciate if you could remind me which channel is 1280.
Teo
Old Feb 16, 2011, 04:10 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
no problems for a multicopter with 1.2ghz Vid and 2.4Ghz RC for me.
teopbako see first page.
iacei is offline Find More Posts by iacei
Old Feb 16, 2011, 07:10 AM
wiper1974 is offline
Find More Posts by wiper1974
Croatia
Joined Dec 2010
Hello!
Can anyone tell me the difference between these two low pass filter, and which would be better to reduce RF interference on LawMate 1.2 GHz Tx since I have a 2.4 RC. Will any of these two give me reduced interference to GPS. The difference in price is not small ...
http://www.dpcav.com/xcart/product.p...cat=272&page=1
and
http://aglhobbiesllc.com/shop/viewit...0&productid=36
wiper1974 is offline Find More Posts by wiper1974
teopbako is offline
Ikaruswannab
Joined Sep 2009
So for me that i am trying to get the best out of my Sunsky 800mW unit to make it fly in a 2.4GHz polluted environment in combination with EZosd GPS and Dragonlink what would your advice be?.
Is it possible all together?
Cheers,
Teo
Old Feb 16, 2011, 08:42 AM
Rastislavko is offline
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
teopbako: I live in capital city, so the radio pollution here very heavy. There is no way to use omni antenna, range may be limited to about 500 meters. Patch antenna can give you reasonable range, I would recommend to use both patch and yagi antenna with diversity. You can't try to catch world distance records in such areas, but even 4km in such areas is very nice...
Rastislavko is offline Find More Posts by Rastislavko
Old Feb 16, 2011, 10:18 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
Originally Posted by Rastislavko View Post
...but even 4km in such areas is very nice...
Very, very nice.
4Km in that field is more than i would expect. For long range i know where i have to go.
Old Feb 16, 2011, 05:12 PM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
Originally Posted by wiper1974 View Post
Hello!
and
The one from AGL will reduce interference to both GPS and 2.4 Ghz. The DPCAV unit will only reduce interference to 2.4 Ghz. (I am the designer of the AGL unit).
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Feb 17, 2011, 02:06 AM
THE_SHRUB is offline
Find More Posts by THE_SHRUB
Joined Dec 2010
Figured I would post up what I just purchased online:
1.2GHz wireless Camera/Tx and Rx all for under 60 bones:
http://www.inesun.com/Brand-New-Delu...and--3394.html
And heres a few internal pics:
So, is this a score by entry level FPV??? PSST... I'm new to the FPV scene
THE_SHRUB is offline Find More Posts by THE_SHRUB
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
