Old Feb 11, 2011, 07:26 PM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
the Sunsky 1.2ghz 800mw, it was pretty cold the last 2 days where we had sun and clear skies, with out gloves my hand were frozen, my ears and nose were red lol
paintball_kidz is offline Find More Posts by paintball_kidz
Old Feb 12, 2011, 07:53 AM
blively is online now
Find More Posts by blively
blively's Avatar
USA, GA, Atlanta
Joined Jun 2008
I have Tim's ReadymadeRC 1500mW 1300MHz Transmitter and it is awesome!
http://www.readymaderc.com/store/ind...roducts_id=321
Originally Posted by Mr.Pibb View Post
I've verified that the transmitters I sell output what they SAY they output. I went through a LOT of manufacturers to find components that weren't hyped. I didn't just copy the data from the manufacturer's web page and put them on mine, I MEASURED them. I really enjoyed the TX's that claimed to be over 2W that were putting out only about 100mW...
After all the "crap" I tested, I know it sounds self serving, but you're really gambling with your money purchasing from all these overseas "sources".
Tim
www.readymaderc.com
blively is online now Find More Posts by blively
Old Feb 12, 2011, 05:47 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Has anyone experienced much external interference (nearby transmitters, etc.) at 1280 MHz? I flew yesterday on 900MHz from a new location and believe I was getting interference from a nearby transmitter. It was also messing up my GPS lock. Anyway, I've been considering getting a 1.2GHz system and wanted to know if it's generally a cleaner band to use.
twinturbostang is offline Find More Posts by twinturbostang
Old Feb 12, 2011, 05:53 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
One place i flew had one of those really large towers that i think effected my range with video and 1280.
Normally i could of gone way further.
Someone told me if you change your altitude it will clear that problem up?
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Feb 12, 2011, 08:19 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
So today my 400mw Sunsky started a spontaneous combustion smoking terribly and smelling really burnt.
A couple of wires going to the tx unit were off melted completely. So I pried open the silver metal chassis to find that the positive wire going to the tx had come loose was touching the metal case. The metal case acts as ground so the lipo just started melting away all the cables and burning my unit.
So at this point I was expecting the worse, but I didn't give up so I soldered two new positive and neutral cables to the board back up and it still works. I have no clue how the tx unit didn't get obliterated.
sim_io is offline Find More Posts by sim_io
Old Feb 12, 2011, 08:21 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
i found also that is very hard to distroy those TX
vulpina is offline Find More Posts by vulpina
Old Feb 12, 2011, 08:27 PM
David22 is offline
Joined Apr 2008
switch to lawmate and be more safe and save some money as well
Old Feb 12, 2011, 09:20 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
First thing I did with my vtx when I got it was inject glue to the inside of the slot where the wires come out and also glued the outside so the wires don't break due to wear from ussage.
Old Feb 14, 2011, 10:50 AM
sim_io is offline
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
I don't know if I should trust my 400mw sunsky that smoked and burned half the wires. I fpv'd with it yesterday and it works, the video is as clean as it was before. I just don't want the video to disappear one day because the unit is damaged.
Old Feb 14, 2011, 10:57 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Run some more tests, full length on it. The accident you had could happen to any Vtx, even the sacred Lawmate ( my LM wires broke, but I saw it before smoking something), so I personally would run it a few more full flights as a test, and if it works then why not? Even if you bought a brand new one it could do that on the 1st flight. That is just me. I guess we have to be our own QC on much of these products
Derek_S is offline Find More Posts by Derek_S
Old Feb 14, 2011, 11:48 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The path of the short didn't pass through any internal components
since it was between + wire and case, so no reason to expect that they're damaged.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 14, 2011, 03:56 PM
sim_io is offline
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
That sounds about right. I filled the wires with hot glue and I don't think they are ever going to move. I think this is something every sunsky fpver out there should do.
Old Feb 15, 2011, 02:36 AM
2ne1 is offline
Find More Posts by 2ne1
Joined Jan 2011
any nice antenna??
2ne1 is offline Find More Posts by 2ne1
Old Feb 15, 2011, 02:54 AM
Epic Huckin'
Surrey, BC
Joined Jun 2007
Originally Posted by 2ne1 View Post
any nice antenna??
Lool, 2ne1 annyeong haseyo.
Search, inverted V on here its one of the best antennas right now for the video transmitter
Old Feb 15, 2011, 03:18 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
Hot glue.... Very bad idea.... The case becames hot and your hot glue will melt.
Use epoxy.
iacei is offline Find More Posts by iacei
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
