Old Feb 06, 2011, 03:03 PM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
Does anyone know the stock antennas DBI for the receiver of the Sunsky 800mw combo? Im looking to get a higher gain omni antenna
paintball_kidz is offline Find More Posts by paintball_kidz
Old Feb 06, 2011, 03:06 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
2-3DBI on the correct frequency. That fequency varies unit to unit.
Po73 is offline Find More Posts by Po73
Old Feb 06, 2011, 03:16 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
thanks, hmmm now where to fine a high gain 1.3ghz omni antenna, ive seen 1.2ghz but im pretty it wont work well with 1280, Im already getting 2km with stock and its fine but hopefully that will bump me up another 1km or so
Old Feb 06, 2011, 03:34 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
higher gain omni antenna?
I suggest you do a LOT of reading on antennas. A higher gain on the transmitter will do nothing for you- only make things worse.
and 1.2=1.3 in the world of premade antennas, unless you build your own.
Kmart is offline Find More Posts by Kmart
Old Feb 06, 2011, 03:49 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
I do need to do more reading, to much fun flying lately. But im going to use it for the receiver, Also i see alot that 1.2ghz only goes from 1080-1200 where as 1.3ghz goes from 1180 - 1300, which is 1280 no?
Old Feb 06, 2011, 04:28 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
low gain omni has a pattern essentially like a ball. A high gain omni smooshes that ball into a washer shape.
For the receiver, you want to use a 1.2/1.3ghz patch antenna.
Yes, 1280 essentially fits in the 1.3ghz band, but between atmospheric distortion, and manufacturing, the two are essentially identical. If you really want, it's easy to trim a 1.2ghz patch to exactly the right frequency of 1280. However, based on the conditions (humidity), that "perfectly" tuned 1280 patch could be resonating anywhere from 1000mhz to 1400mhz.
So yes, 1280 exactly may be best, but a 1.2ghz patch will work as well.
Old Feb 06, 2011, 04:38 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
I see, Im really stumped now, I mostly do FPV in circles around me, so a patch wouldnt work too well with out a tracker inless I move it by hand, I should invest in a diversity system maybe? hmmm, i guess ill get a 8dbi patch soon and use that for longer range flights that stay within the beam and the omni one for close range.
thanks for the help
Old Feb 06, 2011, 05:11 PM
Eganwp is offline
Find More Posts by Eganwp
Giant Scale 3D/IMAC & FPV
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
I've tested my omni to 5km (would go further, but my RC link will never go this far, so no point in testing further) in ground testing with 100% solid video in all orientations. I've also tested my customized 1280 l-com patch for flight behind it, and I was easily able to fly 1/2 a km behind the patch with good video. So it just all depends on how far behind yourself you want to fly.
I've heard of guys flying at 1km behind a patch, but I didn't wanna risk my plane in the air to test it. I'll likely do a ground test in spring and see.
Eganwp is offline Find More Posts by Eganwp
Old Feb 06, 2011, 06:12 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
what TX was it on the 5 km ground range test you did ?
vulpina is offline Find More Posts by vulpina
Old Feb 06, 2011, 10:03 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
pm me we can meet up in person
I have got lots of fpv stuff that I will sell to you cheap like 50 % off or less, oracle divercity, video rx's/tx's and patches etc.
only interested in a bulk sell however
thanks for the help
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Feb 06, 2011, 11:25 PM
LooseTooth is offline
Find More Posts by LooseTooth
Falls Church, VA
Joined Jul 2010
wrong thread - mispost - disregard
LooseTooth is offline Find More Posts by LooseTooth
Old Feb 07, 2011, 12:29 PM
Eganwp is offline
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
LawMate 1280 1W TX w/ matching RX. Tuned 1280 inverted vee on tx & an aftermarket 1.3dbi omni on rx. I haven't torn-down the 1.3 to see the exact frequency as I was planning to mod it to 1280, but at this point it's amazing stock! I couldn't be more happy with my setup to be honest.
In spring I'll test and see what the max range of the omni is... Will be useless to me without a LRS, but I'm interested to know if it'll do 8 or 10km.
Old Feb 08, 2011, 11:47 AM
Mr.Pibb is offline
Find More Posts by Mr.Pibb
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
Originally Posted by Bill Sanford View Post
Yea, but the BOB transmitter is just a cheap Chinese copy and doesn't put out 700 watts like the ReadyMadeRC VTx!
Doesn't marketing hype like this get old... Too bad the web designer or copy writer has no clue what they're selling...
I've verified that the transmitters I sell output what they SAY they output. I went through a LOT of manufacturers to find components that weren't hyped. I didn't just copy the data from the manufacturer's web page and put them on mine, I MEASURED them. I really enjoyed the TX's that claimed to be over 2W that were putting out only about 100mW...
After all the "crap" I tested, I know it sounds self serving, but you're really gambling with your money purchasing from all these overseas "sources".
Tim
www.readymaderc.com
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
Old Feb 11, 2011, 07:10 PM
Epic Huckin'
Surrey, BC
Joined Jun 2007
Its official for my vTX that it wont turn on in cold weather, i fly at a small power line valley across the street from my house when i dont have time to go to the field, and i have to plug my vtx in at home before i head out or else it will not power on properly inless i keep it in my hands for a few minutes, its cold even when stationary on the ground in this weather condition so as soon as i unplug all power to it, i gotta warm it up again.
Old Feb 11, 2011, 07:24 PM
David22 is offline
Joined Apr 2008
which vtx are you useing
Its not that cold here for this to be needed.
http://www.theweathernetwork.com/ind...ink_obs_last24
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
