Espritmodel.com Heli Air
Old Feb 03, 2011, 05:28 AM
no gap is too 'small'
screwup's Avatar
Melbourne, Australia
Joined Feb 2009
RangeVideo 12Ch 900mhz - 1300mhz RX
Has anyone had experience with this receiver?
http://www.rangevideo.com/index.php?...951c12d2bfdb09
or should i go with the lawmate 2.4ghz 500mw or 1.2ghz lawmate?
-kalvin
screwup is offline Find More Posts by screwup
Old Feb 03, 2011, 08:24 AM
Fly FPV, sleep; repeat
twinturbostang's Avatar
Germantown, MD
Joined Mar 2006
Originally Posted by Kmart View Post
Also, from what I've asked him, the weak link was UHF control, and only when he was close to the antennas on buildings.
-Kevin
Probably because he likes to use I think channel 8 on his 2.4GHz Lawmate, which is not a legal frequency to use in the U.S. by amateurs.
twinturbostang is offline Find More Posts by twinturbostang
Old Feb 03, 2011, 01:18 PM
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
Originally Posted by DarkHeli View Post
Hey guys,
I'm having some trouble with my fox 800... When I test it out by doing a quick hover, sometimes all of a sudden, the screen goes to full static, like it is disconnected and only the rx works.
The display on the VTX looks fine, channel 9. The power is around 11.3 so its not low voltage. It happens regardless if I connect to the main battery with the LC filter, or use a separate, second battery.
When I disconnect/reconnect the power, everything works fine as before...
Has anyone had a similar experience? I'm at my wits end with this.. It could mean disaster if I lose video signal during a flight...
I found out that it is not the TX..
It was my osd. An ic socket didn't have enough solder paste. All fixed and working perfect. I need to get me some more fox tx/rx!!!
DarkHeli is offline Find More Posts by DarkHeli
Old Feb 04, 2011, 10:09 AM
Joined Mar 2010
subscribed
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Feb 04, 2011, 12:14 PM
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
wich vTx's would work with the Lawmate 1.2 vRx ?
Looking for a low-power one for close by flying, 50-200mW. Should cope with 1.280Ghz
Kai
DrEvil is offline Find More Posts by DrEvil
Old Feb 04, 2011, 12:22 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
If your Lawmate Rx has 1280Mhz (one of them doesn't), then it'll work with
any of the Txs listed on the first page of this thread that can transmit at 1280Mhz,
which is most of them.
ian
Daemon is offline Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Feb 04, 2011, 12:46 PM
France
Joined May 2006
i just noticed my Vee antenna was shorted , i build it myself and messed up the sma plug when soldering , could i have damaged my VRX with such short ?
vulpina is offline Find More Posts by vulpina
Old Feb 04, 2011, 12:48 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I don't think you can hurt an Rx with a shorted antenna. It could definitely cook
a Tx though.
ian
Old Feb 04, 2011, 03:21 PM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
ian
Ok, thanks Ian.
I'l take a look !
Kai
Old Feb 04, 2011, 05:39 PM
France
Joined May 2006
Oh i meant TX actually , it is a fox 800 , seems to work still .
I will range check it later.
Old Feb 05, 2011, 12:49 PM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
This is a crosspost... but FYI
I was doing the initial installation on my DOSD+ and was having a lot of problems with jittering caused by the 72mhz ppm Rx and my HXT900 servos.
I was using the stock antenna on my fox 700 1280 vtx as I often do on the bench. On a whim I pulled the IBC 1280 V antenna off of my plane and installed it and my jitters went away even with the VTX next to the Rx.
I dont know how, but the V antenna apparently radiates in such a way that is much better for the Rx, maybe decreasing lower mhz noise closer to the 900mhz band which is known to cause some jittering. If problems are originating from the Rx for anyone, maybe try this.
Derek_S is offline Find More Posts by Derek_S
Old Feb 05, 2011, 06:39 PM
I should be flying right now!
al1242's Avatar
Indiana
Joined May 2010
My Lawmate 1W 1.2Ghz VTX is dead. I was using it on my T-28 this fall with no problems and now I am building a Skywalker. Had everything wired the same and nothing. I put 12V (3s lipo) right at the VTX to check my connections and it does not heat up like it used to, took the cover off and no visible signs of problems. Anybody got anything I might try before I order a new one at $85?
al1242 is offline Find More Posts by al1242
Old Feb 05, 2011, 08:35 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Re-check your wiring. Maybe a broken wire somewhere?
galaxiex is offline Find More Posts by galaxiex
Old Feb 06, 2011, 03:47 AM
Luxembourg
Joined May 2009
The included wires on the lawmates are crap and they have a weak spot where they connect to the board, for this reason I epoxied this spot.
If you did not secure the cable there is a chance that some of the wires do not connect to the borad anymore.
Open the case an measure the voltage.
iacei is offline Find More Posts by iacei
Old Feb 06, 2011, 01:52 PM
al1242's Avatar
Indiana
Joined May 2010
It does not appear to be the wires, I am getting 12volts to the board, I must have killed it, thanks for the help.
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei Video Piloting (FPV/RPV) 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei Video Piloting (FPV/RPV) 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ Video Piloting (FPV/RPV) 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
