Old Aug 09, 2010, 11:37 AM
masam54 is offline
Find More Posts by masam54
masam54's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Dec 2008
Originally Posted by scrape View Post
I tried out one of the Sunsky 1.2Ghz 800mw TX/RX over the weekend. The video would drop out after a couple minutes. The TX was getting warm so I tried another anntenna. It seemed to help but would still drop out after a few minutes and then come right back on after a few secounds, drop out, on, ect. I've have two of these units, hope to try the other one today.
Anyone ever have this problem.
Attached is a picture of my Fox 12ch video rx internals. Ignore the little bit of extra wiring (thats for the RSSI meter). Try to adjust the video level pot shown. I had that video drop problem on this rx resolved by tweaking that pot.
masam54 is offline Find More Posts by masam54
Old Aug 09, 2010, 11:39 AM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
It's a GoPro, recorded onboard. Still, there was no static at all in the video. Only lost RC control when I turned around.
Here's another thing that may be different with me- mine is still in that huge heavy gold case. It gets so hot, that I just took the weight penalty to keep it cool. Maybe some are over heating?
I'll pause the video and take a screen grab at the furthest part. If you watch the video carefully though, I'm pretty sure you can remember the park.
-Kevin
Kmart is offline Find More Posts by Kmart
Old Aug 09, 2010, 11:49 AM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
The Park at 0:35 seconds is where I launched from
Again at 2:36
2:58
1:15 is the furthest in the video. I've gone further than that before, I guess I just never posted it...
Old Aug 09, 2010, 11:58 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
I'll give that a try.
Thank You.
scrape is offline Find More Posts by scrape
Old Aug 10, 2010, 10:00 AM
striker121 is offline
Find More Posts by striker121
Arduino Nerd
Long Island, New York
Joined Aug 2010
So does the Sunsky TRANSMITTER use an sma or a type f connector like the reciever? I can't find the info anywhere in order to make an antenna while I'm waiting for mine to ship.
striker121 is offline Find More Posts by striker121
Old Aug 10, 2010, 10:02 AM
masam54 is offline
masam54's Avatar
Joined Dec 2008
All the transmitters uses sma (to be honest I havent seen a video transmitter with a F connector)
Old Aug 10, 2010, 10:15 AM
Zoki is offline
Find More Posts by Zoki
Varazdin, Croatia
Joined Aug 2006
Friend of mine got his set from Sunsky few weeks ago, and his set has F connector on receiver and sma on transmitter.
Zoki is offline Find More Posts by Zoki
Old Aug 10, 2010, 10:29 AM
Alcyon13 is offline
Find More Posts by Alcyon13
Alcyon13's Avatar
France
Joined May 2010
My fox 700mw from BOB have F connector on rx and SMA on tx
Alcyon13 is offline Find More Posts by Alcyon13
Old Aug 10, 2010, 02:24 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Qualitiative analysis of the BoB 700 Vs Sunsky 800
Pictures will come later
I flew both TX units on the same plane and in the same patterns a few minutes apart using the stock whip antennas on the RX units and my Vee antenna on the plane. I left my cellphone in my pocket to generate a little bit of noise to simulate a more noisy environment. Both TX units were uncased. Here's what I can determine from those flights:
Sunsky TX:
This unit is smaller, lighter and has slightly higher output power. My range on this with either RX was about 3000-3100 feet before the video feed got weak. I would suggest adding a small heatsink to this one.
Video feed gets weak around 10V. Drop out happens at around 8.8V.
BoB:
This unit is larger, heavier and has slightly less output power. Range was about 2500- 2600 feet before the video feed got fuzzy. A separate heatsink is likely unnecessary.
Video feed gets weak around 10.7V and drops out at 9.3V. This I feel is the greatest disadvantage to this unit.
RX units:
For all I can tell, they are identical. I could determine absolutely no difference in performance.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 10, 2010, 02:31 PM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
Nice Review thanks!
Question: On which channel did you do the Test?
iacei is offline Find More Posts by iacei
Old Aug 10, 2010, 02:34 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Thanks Alex. But still no mile mark like some are reporting..
How much does the cell phone really interfere?
Derek_S is offline Find More Posts by Derek_S
Old Aug 10, 2010, 02:35 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Yep, a good review. Thanks.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 10, 2010, 03:03 PM
Alcyon13 is offline
Alcyon13's Avatar
France
Joined May 2010
BoB:
-Alex
I have exactly the same results with my BOB fox 700mw. My cell phone is always off.
I'm using the stock antenna on rx an inverted vee on tx, exactly the same setup than IBCRAZY.
How can we improve it (without using a patch on rx) ??
Old Aug 10, 2010, 03:58 PM
masam54 is offline
masam54's Avatar
Joined Dec 2008
Exactly which stock whip antenna was used? Does anybody knows what frequency this antenna is tuned for?
Old Aug 10, 2010, 04:11 PM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
my 1.2GHz 800mW sunsky is on the way. Does anybody know how must dbi is the stock tx antenna? I bought a 7 dbi rudder duck and a 8 dbi patch for the rx.
kstmark is offline Find More Posts by kstmark
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
