Old Aug 07, 2010, 08:53 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Do you guys think attaching the rx to an aluminum pole to raise it high in the air really affects it's Rx capability? It is collapsable and thus way more convenient than PVC, or something. The case is grounded of course to all the stuff inside, so I have wondered if this being grounded to a big pole possibly introduces interference?
If so, do you think plastic washers and screws attaching it to the pole would be enough isolation for any problems?
Derek_S is offline Find More Posts by Derek_S
Old Aug 07, 2010, 08:55 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Originally Posted by theothercliff View Post
Non sequitur: The 700 and 800 have identical receivers.
Cliff
That is the question I have really been wondering the answer to..are they really identical? Somewhere someone seemed to notice differences in SAW filters among the units(sunsky vs BOB)? They sure look the same, but so do many other Chinese units of all bands. I have a 900 unit from Future Hobbies that is identical in every way except it has an SMA output instead of F.
Old Aug 07, 2010, 09:10 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Yes, they are the same receivers. I have a BOB and a Sunsky Fox 800mw system and the receivers are identical.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 07, 2010, 09:13 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Derek anything but air will effect your transmissions
re your ground station
those video rx's that looks the same are the same and really are not that great in quality
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 07, 2010, 09:17 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Thanks guys, I was wondering. I will try mounting it differently to see if I can get rid of someof my strange interferences.
Old Aug 07, 2010, 10:44 PM
masam54 is offline
Find More Posts by masam54
masam54's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Dec 2008
Yep, they are the same receivers. Its the norm in manufacturing that components vary sometimes depending on availability/pricing as long as they are within manufacture's specs. Quality wise, at their prices I'm not complaining,
masam54 is offline Find More Posts by masam54
Old Aug 07, 2010, 10:58 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Oh, sorry, I rechecked the lawmate is about $30 after shipping. But still, $30 difference for a 'better' Rx and Tx, if you dont mind 5v?
I say 'better' becasue I do not have a Lawmate, I just have asked several of the veteran FPV'rs here and ALL of them I asked told me Lawmate was the way to go. Granted they also are mosly using the 2.4 channels. And When I asked David22, he at least uses a LM RX. (Thanks David for your advice)
BUT, I also do not have a Sunsky unit. I have only 2 BOB units, which for me are working out to be a waste of money. Range just really sucks, not even counting that I am getting local interference at my favorite field (but not the BOB's fault I guess). I wish I would have tried Sunsky, as they seem to be better units. Kmart is getting 1 mile with stock omnis? JEALOUS
Just saw this.
Yep! Workin' great for me. No filtering on anything, straight up stock antennas. Unfortunately, I left my stock TX antenna on the ground when i was "Flying in God's Country", so I ordered a custom one from Alex. So now I should be doin' even better. Although I still have never hit the limits of my video. I usually fly at 2k feet up then XX feet out.
-Kevin
(All Radian videos with stock everything)
This one is the furthest for me.
Radian FPV 2 (4 min 48 sec)
Kmart is offline Find More Posts by Kmart
Old Aug 08, 2010, 08:55 PM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
It may help it, it may hurt it. If I wanted to use an aluminum pole, I would test it compared to plastic of the same height. Fly three flights out to the edge of your video reception with the receiver set up on:
- the plastic pole
- the aluminum pole with the receiver touching the pole
- the aluminum pole with the receiver insulated from the pole
Having a dipole (as maybe opposed to a patch) up in the air helps. At least for line of sight issues.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Aug 08, 2010, 09:08 PM
David22 is offline
Joined Apr 2008
thats recorded on board?
right?
not a good representation on the video link?
Originally Posted by Kmart View Post
Just saw this.
-Kevin
http://www.vimeo.com/13303679
Old Aug 08, 2010, 09:09 PM
Temple, GA, USA
Joined Jun 2009
Just saw this.
-Kevin
Nice!
Is that a Sony Webbie camera by any chance? Looks like HD recorded on board, not like SD video across an RF link.
Would have been a little better if there had been some description and maybe some arrows pointing out where the landing zone was.
Cliff
Old Aug 08, 2010, 09:35 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
It is a Gopro according to his other posts, I think.
Hey, maybe this has been said and I missed it, but those digital 12 RXs might be the same across the board because I just started playing with my 900mhz one from Future Hobbies (which looks exactly like the BOB Rx except with SMA) and it received exactly the same channels, so I can use either Rx with both my 900 or 1200 systems. The Tx's look exactly the same too, even the center, main chip looks like the same numbers best I can tell but they definatly transmit on different freqs, with just 3 overlap channels at 1010, 1040, and 1080.
If this has been sai I have completely missed teh short bus on that one, I had no idea. I had even put tape on them marking them for their appropriate freqs since thet looked identical. I wonder if the stock antennas are identical as well (read extremely mismatched, possibly)
Old Aug 08, 2010, 09:43 PM
David22 is offline
Joined Apr 2008
if its 12 chanel digital yes
as i posted the channels in this thread
you guys should be getting the manuals and catalouge
It tells you everything and also shows the various antnnas etc that are available
see post #33
Hey, maybe this has been said and I missed it, but those digital 12 RXs might be the same across the board because I just started playing with my 900mhz one from Future Hobbies (which looks exactly like the BOB Rx except with SMA) and it received exactly the same channels, so I can use either Rx with both my 900 or 1200 systems. The Tx's look exactly the same too,)
Old Aug 09, 2010, 02:17 AM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
I have check the output frequency of Lawmate 1.2 transmitter, its as flow
CH1- 1080MHz
CH2- 1120MHz
CH3- 1160MHz
CH4- 1200MHz
CH5- 1010MHz
CH6- 1040MHz
CH7- 1240MHz
CH8- 1280MHz
I just found a problem, picture is BW with Lawmate receiver and Fatshark goggles, Lawmate receiver has color output with Trimersion and Headpaly goggles and Fatshark has color with FOX receiver.
Talajouy is offline Find More Posts by Talajouy
Old Aug 09, 2010, 03:42 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Video levels, many of the grey box receivers have a potmeter with which you can adjust the level, the Fatsharks can be a bit finnicky when the video levels are too high.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Old Aug 09, 2010, 10:27 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
I tried out one of the Sunsky 1.2Ghz 800mw TX/RX over the weekend. The video would drop out after a couple minutes. The TX was getting warm so I tried another anntenna. It seemed to help but would still drop out after a few minutes and then come right back on after a few secounds, drop out, on, ect. I've have two of these units, hope to try the other one today.
Anyone ever have this problem.
scrape is offline Find More Posts by scrape
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
