Old Aug 06, 2010, 01:46 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
forget about the sunsky/bob/fox typical rx's
they are not good and not at all consistant
the tx's however work well
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 06, 2010, 02:02 AM
iacei is online now
Find More Posts by iacei
Luxembourg
Joined May 2009
Maybe but I had more problems with my lawmate Rx then with the BOB Rx.
But as you say you may need to be lucky.
Problem is: to have a Fox tx and a Lawmate Rx you have to buy 2 combos and the lawmate ones are expensive. Also channel switching on a lawmate is really not handy.
iacei is online now Find More Posts by iacei
Old Aug 06, 2010, 02:10 AM
David22 is offline
Joined Apr 2008
try to turn your rx and tx on first and wait 10 seconds or so then turn on your other fpv stuff
you for sure have to be lucky, i tried 7 of the fox/bob rx's to get a really good one, and even that needed modifications, they all work, but some are way better performing than the others
to make the lawmate work is easy and not hard to switch channels
Old Aug 06, 2010, 09:37 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
The Sunsky Team is quick. I ordered on the 3rd and got it this morning. Heart land USA.
1.2GHz 800mW 8 Channel Digital Wireless AV transmitter & receiver
http://www.sunsky-online.com/view/13...ransmitter.htm
scrape is offline Find More Posts by scrape
Old Aug 07, 2010, 08:15 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
(Anyone who buys a Fox-700 or Fox-800) Let us know how well it works. David22 is has apparently had quite some bad luck with Sunsky and BOB receivers lately. It would be good to get some other reports to figure out whether a bad batch has run it's course.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Aug 07, 2010, 08:22 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Cliff
I have a Sunsky FOX 800mw 1280mhz video system. I went out 5 3/4 miles (9.3km) and still had excellent video. I'm using an inverted vee antenna on the vtx and a goof proof patch on the receiver.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 07, 2010, 08:44 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Jeez, just out of curiosity how many Sunsky 800 systems do you have? If more than 1 I am curious how they compare to each other?
Derek_S is offline Find More Posts by Derek_S
Old Aug 07, 2010, 08:46 AM
David22 is offline
Joined Apr 2008
some create a white flashing or something like that.
I put a video tx up a mountain lookout with a line of sight of my ground station, with stock antenna and a large 3 cell battery to make sure volts were steady.
This alowed me to test the rx's and different rx antennas.
this test can be done, in house, as well, just walk the video rx away untill signal is poor, but still "seeable" and go back to ground station to perform similar tests
out of the six or so rx's one didnot work hardly, and one worked very well.
even trying to manual tune them, didnot correct a white flash and crackle
type of video
the one that worked very well, the best of the bunch, I used.
the differences in video quality between the exact same rx's messed with my video divercity as well, especially my dvr
eliminated video divercity, and started to experiment with haveing the 1.2 rx close to the rc tx (uhf) found the "lawmate" is better at close proximities, in my case.
there is another guy on rc groups who had the exact same conclusion not all of these rx's are the same
Cliff
Old Aug 07, 2010, 08:47 AM
David22 is offline
Joined Apr 2008
the 800 is a great choice
Old Aug 07, 2010, 09:17 AM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Please tell me what's this antenna? I've seen them only in UHF. Do you have a link? DBI? I've order a 3dbi rudder duck for the vtx.
kstmark is offline Find More Posts by kstmark
Old Aug 07, 2010, 09:24 AM
Joined Mar 2008
Inverted vee:
http://www.rcgroups.com/forums/showthread.php?t=1159968
Goof Proof Patch:
http://www.rc-cam.com/gp_patch.htm
Old Aug 07, 2010, 09:27 AM
scrape is offline
Joined Mar 2006
The first post,
Antennas
Stock Antennas give good results but here are some better ones
Tx: Go for IBcrazy's inverted Vee, better results and lighter.
Old Aug 07, 2010, 09:29 AM
scrape is offline
Joined Mar 2006
Cliff
It works, hope to test range today.
Old Aug 07, 2010, 09:52 AM
masam54 is offline
Find More Posts by masam54
masam54's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Dec 2008
I have two of those Fox video receivers feeding my Oracle. Initially had video dropout problem with one of the receivers. I ordered another one. Turned out I didnt need to as the problem was resolved just by rx positioning. Also I notice if using a whip antenna, best to lay rx body to be perpendicular(acting as ground plane?) to antenna. Now two are working well with my Oracle, and the third one I use as a spare or when I want to use a single rx (not lugging my heavy GS to the field).
Another thing is I bought those rx from three different suppliers.
masam54 is offline Find More Posts by masam54
Old Aug 07, 2010, 08:45 PM
Temple, GA, USA
Joined Jun 2009
Non sequitur: The 700 and 800 have identical receivers.
Cliff
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
