Old Jan 10, 2013, 08:44 AM
pulsarxp is offline
Find More Posts by pulsarxp
pulsarxp's Avatar
Joined Sep 2012
Stabilized power supply
Thanks for your help here.
I made it quickly to a power supply, the output of which is independent of the input voltage.
Stabilized power supply for FPV video transmitter and camera (0 min 54 sec)
Operation of the system was 6 inputs. But it is unfortunate when a 3S lipo is only 6V output.
pulsarxp is offline Find More Posts by pulsarxp
Old Jan 13, 2013, 03:06 AM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Just wanted to share pictures of 2 Lawmate tx I got from different vendors.
Here is 2.4ghz 1w on the left and 1.2ghz 1w (new design) on the right side:
Has anyone flown that new version? (Sorry if it was already talked about) I don't read this tread each time it has updates.)
Virgis
Virgis21 is offline Find More Posts by Virgis21
Old Feb 16, 2013, 05:10 PM
DerRose is offline
Find More Posts by DerRose
Germany
Joined Oct 2010
I'm not really sure if I'm right here.
But: I'm looking for a small V-TX (200 - 400mw) for upgrading my photocopter with FPV equipment. My RX is using these frequencies:
- 1.080
- 1.120
- 1.160
- 1.200
- 1.240
- 1.280
- 1.320
- 1.360 Ghz
Can someone recommend a cheap device?
DerRose is offline Find More Posts by DerRose
Old Feb 17, 2013, 02:02 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
Probably from,
http://www.bevrc.com/
although i can't help you any more as the site is bugging this morning, or maybe Google isn't his friend,,,
paulinfrance is offline Find More Posts by paulinfrance
Old Feb 17, 2013, 06:41 PM
Jetboatftw is offline
Find More Posts by Jetboatftw
Joined Oct 2009
Hello, i bought the Fox-800 from sunsky, but my 12ch vrx only seems to have 8 channels. Is there a mod or something for getting the last ones? From what i have read it should have 910mhz on one of the channels and thats what i need as im now using the vtx from the "do not touch" category.
Jetboatftw is offline Find More Posts by Jetboatftw
Old Feb 19, 2013, 07:47 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
This one?
It uses 1080Mhz + 3 other channels so normally you should find a channel matching one of the 8 on your Rx
For the channels available on your Rx there are noted here under Inesun Rx (1080 is the lowest available):
http://www.rcgroups.com/forums/showa...8&d=1261432777
iacei is offline Find More Posts by iacei
Old Feb 19, 2013, 07:50 AM
iacei is offline
Luxembourg
Joined May 2009
- 1.080
- 1.120
- 1.160
- 1.200
- 1.240
- 1.280
- 1.320
- 1.360 Ghz
readymaderc will make you happy.
Old Feb 19, 2013, 04:59 PM
Joined Oct 2009
Thanks for your answer. But i dont think i made myself fully understood.
I have this http://www.sunsky-online.com/view/13...6+receiver.htm and it works great if i use the combo that was in the box.
But since im trying to save weight the included vtx was way to heavy. So i bough this, http://www.ebay.com/itm/Wireless-Cam...item2ebf76a8f9
Inside the camera there is a transmitter that should transmit at 910Mhz according to a thread i found a while ago.
And in the manual that followed the fox it says at page 11 that the 12channel receiver starts at 0.910G and stops at 1.360G. But mine does not have 12 channels its only 8 if not some of them got the same number on the digital display. According to the manual the display should show a 0 when its at 910Mhz\0.910G. But mine start at 4 and goes 4,5,6,7,8,9,A,6, then 4 again. So i was wondering if theres a mod for getting channels 0-3. Or is my receiver just broken? I got a very bad picture while trying to see if it would work so one of the channels is seems really close to 910Mhz
Old Feb 19, 2013, 05:53 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Just remove the outer case of your VTx. That's how most of us use it.
Dunno why your Sunsky manual says it's a 12ch Rx. It's not.
Daemon is online now Find More Posts by Daemon
Old Feb 19, 2013, 05:59 PM
DerRose is offline
Germany
Joined Oct 2010
Thanks! I ordered the 100mW version. I'm just looking for a range about 100-300m for using my photocopter. 100mW should be fine and and 19$ it should be worth a try.
http://www.readymaderc.com/store/ind...roducts_id=445
But what is this for a strange antenna design? Do i have to change something for use it for FPV?
BR
Old Feb 19, 2013, 06:26 PM
Joined Oct 2009
My bad i didnt purchase it from sunsky i think i got it at banggood or goodlucksell. Maybe theres a different manual. So even though its printed on the receiver its not really 12ch, that cant even be a chinglish mixup. Well i plan on modding the "do not touch receiver" anyways so hopefully it will be good enough. Hoping to use the fox-800 in a boat or something as its still to heavy without the casing(well actually the antenna at 23grams is whats really killing me). Maybe ill make a antenna if the "do not touch" gear doesnt cut it. Anybody knows the weight of the lightest antenna you can make for 1.2ghz? I see some have removed the rubber from the stock antenna that alone must save a ton of weight.
Old Feb 19, 2013, 06:27 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The lightest antenna you can make will have very poof performance.
The best way to maximize the performance of any of this gear, is to give
it a proper antenna. Best you can probably do is a Vee.
Old Feb 19, 2013, 07:04 PM
Joined Oct 2009
Ok i just assumed a crappy antenna would be good enough for around 1km if people go 2-3 out of the stock one. Any idea of what the vee weighs in at? Thanks for the help
Old Feb 27, 2013, 07:02 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
a vee could be one of the lightest/best antennas you can use. my homemade vee did 5 miles in NYC with the stock antenna on the rx.
KillerCut is offline Find More Posts by KillerCut
Old Feb 27, 2013, 08:59 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
my friend makes antennas for me
he just solders on the right lenght of copper wire to the video tx
they work very well
my favorite is the 2.4 video tx lawmate 1 watt
it has nice thick copper wire that bends and can be straightened after landing
i position it under the plane pointing down
so all blocking stuff is above it
its a truely high performance video tx antenna
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
