Old Jan 03, 2013, 10:15 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Originally Posted by David22 View Post
I flew yesterday evening with 1 watt lawmate and audio was great , just had to,turn down the volume
It is great to hear servos etc. if one of my servos is slightly bound and makes buzzing I can stop that with little servo movement, so glider has no servo sounds but just wind
Motor sound also is great
Maidened a glider but powered the video,tx with separate battery
Now plane is trimmed etc i will remove video tx battery and just power the camera and 1 watt lawmate via balance plug of a 3 cell
I hope with ground tests my camera and video tx work to 8.5 volts
Anyone knows it the racewood is a good vtx combined with the lawmate reciever?
timtimtim is offline Find More Posts by timtimtim
Old Jan 06, 2013, 02:25 AM
pulsarxp is offline
Find More Posts by pulsarxp
pulsarxp's Avatar
Joined Sep 2012
Hi,
I have a Lawmate 1.2Ghz 1000mW TX.
(Old design)
What is the operating voltage of a significant loss of performance.
you put extra cooling? Or is it sufficient to factory?
pulsarxp is offline Find More Posts by pulsarxp
Old Jan 06, 2013, 03:02 AM
GLADUS63 is online now
Find More Posts by GLADUS63
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
Originally Posted by pulsarxp View Post
Hi,
(Old design)
It's enough if you have airflow on it, on mine I stick with "artic silver aluminum paste" a piece of an old computer ship radiator.
Cedric
GLADUS63 is online now Find More Posts by GLADUS63
Old Jan 06, 2013, 05:20 AM
NutBag is online now
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Here's my mod'd lawmate 1watter. Heatsink well attached with Devcon metal epoxy and it has dropped "bench burn" operating temp by over 15DegC!
Ditch the gold heatsink, besides being held on with double sided tape its not much good unless your rig always flies fast and it gets the airflow
Chris.
NutBag is online now Find More Posts by NutBag
Old Jan 06, 2013, 06:28 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Hi Pulsarxp, I found the significant loss of performance will occur if operating the old Lawmate 1W Tx at 9.5v or less.
I power my Lawmate Tx at 10.0v and still maintain 1W output power and it seems to run cooler, quite safe for bench testing.
Geoff
Hi,
(Old design)
garris2 is offline Find More Posts by garris2
Old Jan 06, 2013, 09:36 AM
paulinfrance is online now
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
Originally Posted by falconiforme View Post
Hi all,
I am building FPV system for my RC car. I have already 1.5W 1.2GHz Tx/Rx.
But I do not have proper antennas. I want to use omnidirectional antennas with about 6dbi on Tx and Rx.
I found this antenna on e-bay but I did not found any particular info about it:
1.2 GHz 7 dBi Omni GSM rubber Antenna SMA male connect
http://www.ebay.pl/itm/1-2-GHz-7-dBi...item2310e25701
If in your opinion it is not worth it I could build my own antenna based on this tutorial:
http://wireless.gumph.org/articles/homemadeomni.html
Thank in advance
Hi, i have the 8db and 12 db versions a load of CRAP, if you want to spend your money buy some Bacon,,,,
paulinfrance is online now Find More Posts by paulinfrance
Old Jan 06, 2013, 12:24 PM
pulsarxp is offline
pulsarxp's Avatar
Joined Sep 2012
Thank you for your help.
I'm going to do ground testing. Connent with a camera and then I go it by car. I repeat this test from 10 and 12 volts.
Geoff
Old Jan 09, 2013, 10:36 AM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
BOB (Fox) 700mw VRx Corrosion
I decided to open up my new BOB vrx to take a peak inside and found substantial corrosion on two of the components and light rust throughout. The vrx/tx seem to work ok around the house. I have not flown with them.
Has anyone experienced this? Should I trust the rx?
The unit is brand new. It's just been sitting in the box (opened) in my pc room (air conditioned) for 2 months.
Also, it has an F connector (right?). If I decide to ditch the stock antenna, am I better off with a F-to-sma adapter or build the new antenna with a F male connector on the pigtail?
TNug is online now Find More Posts by TNug
Old Jan 09, 2013, 10:53 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Originally Posted by timtimtim View Post
Thanks! i tried my lawmates sound yesterday and i could hear some buzzing noise, is this the lawmate sound problem everyones talking about? if so im going to RMA this lawmate and get a new one if the problem is solved. did you turn down the volume using a transistor or what do you mean?
I just turned down volume of the ground station
I also use lawmate video rx and it works well
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jan 09, 2013, 10:58 AM
David22 is offline
Joined Apr 2008
Geoff
Yes
10 volts power supply to video tx works best
Because there is 10 volt linear regulator in the video tx
Less heat and wasted energy
Powering from a 3 cell battery works well but needs cooling when no air flow at 12.6 volts
Old Jan 09, 2013, 11:01 AM
David22 is offline
Joined Apr 2008
Chris.
If you use antenna that matches the frequency output of the video tx your video tx will run much cooler and use less amps.
Old Jan 09, 2013, 11:33 AM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Do not trust that unit. It's been very wet to have corrosion like that.
Martin Y is offline Find More Posts by Martin Y
Old Jan 09, 2013, 11:37 AM
GLADUS63's Avatar
Joined Jul 2009
Change the module for a Comtech if you want to keep it ;-)
Old Jan 09, 2013, 01:35 PM
TNug is online now
Waypoint Collector
TNug's Avatar
Joined Feb 2012
I saw the reference on the first page to this mod. It says you need an o-scope. Is this still the case? If so, I may just buy a new rx.
Old Jan 09, 2013, 01:45 PM
GLADUS63's Avatar
Joined Jul 2009
It's right but on a certain way it can't be worse ;-) even if you don't calibrate it, I change one on mine and didn't calibrate it as is seem to be good.
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
