Old Nov 28, 2012, 05:49 PM
nieder2 is offline
Find More Posts by nieder2
Joined Jan 2012
Originally Posted by Jack2010 View Post
I just have pluged in never used Fox800 VTX and have an issue with it It always starts with CH4. My old one remembers the last CH used, but this one not.
Any remedy for this? It makes it complicated to use that VTX and been forced to change CH every time you start it...
I noticed your post and started seeing something similar. My tx used to remember its channel and now it doesn't. Now, the button sometimes is unresponsive/the display doesn't change. Sometimes when i'm cycling the button the display goes blank and i have to cycle power to get it to come back on. Anyone else seen this? is my Tx going bad?
nieder2 is offline Find More Posts by nieder2
Old Nov 29, 2012, 09:20 AM
Rogman88 is offline
Find More Posts by Rogman88
United States, LA, Monroe
Joined Mar 2009
After reading this thread I decided to go with the Fox 800 and couldn't be happier. I am using stock antennas and flying around my air field less than one mile without issue. The one thing that I didn't realize is that the Fox uses RP-SMA adapters to link the antennae instead of the SMA adapters that most others use. Now I have to get a RP-SMA to SMA adapter to use my DVR link from reciever to TV screen. No big deal, but I couldn't figure out why my adapters didn't work until I came across the answer by accident.
Rogman88 is offline Find More Posts by Rogman88
Old Nov 29, 2012, 10:54 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
None of my fox800 txs use rp-sma connectors.
Daemon is offline Find More Posts by Daemon
Old Nov 29, 2012, 11:02 AM
Rogman88 is offline
Joined Mar 2009
Daemon,
This is where I got this from. I'm now confused. I know my DVR cable doesn't fit into my Fox-800 reciever and figured this was the problem. Look about halfway down where it states that you have to have a RP-SMA female to SMA female adapter. I assumed this was why my DVR cable wouldn't go into my Fox 800 reciever? Am I reading this wrong?
http://www.readymaderc.com/store/ind...roducts_id=457
Old Nov 29, 2012, 11:15 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Connection between Receiver and DVR has nothing to do with SMA.
Those are all composite RCA connectors, and presumably you need
some sort of gender changer to link two male plugs together.
ian
Old Nov 29, 2012, 11:26 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
Rogman88,
You're confusing the type of connections.
Fox 800 (Sunsky 800mW) VTx has a SMA female input for you to use SMA male antennas, just like the link you refer.
Foxtech webstore sells 5.8GHz gear (not 1.3GHz) that came with other type of connectors: RP-SMA, or reverse polarized SMA.
And, as Daemon said, for connecting your receiver to the DVR we're speaking of other matter and for that you need the very common RCA connectors. It has nothing to do with the plug for attaching the antennas.
HF_ATL is offline Find More Posts by HF_ATL
Old Nov 29, 2012, 03:59 PM
Rogman88 is offline
Joined Mar 2009
Oh, I see! Thanks guys. I would like to make a cloverleaf/skew planer setup for my Fox 800 transmitter/receiver combo. Since I am a complete noob at this, I just want to be sure that I get the right leads. I need SMA male leads like this.
http://www.ebay.com/itm/12in-SMA-mal...item256370c38e
Now that you mention it...I feel quite stupid asking the previous question...RCA adapters is what I need to get my DVR to connect to receiver. I'll look at them again and will go to Radio Shack to find one.
Thanks again guys for bearing with my noobness.
Old Nov 30, 2012, 10:27 AM
Roel-CP is offline
Find More Posts by Roel-CP
Roel-CP's Avatar
Netherlands
Joined May 2010
Corrrect!!!!!!!
yellow / white Boobs are RCA
Small holes can be special like Ipod plugs and most of the time they will come with the reciever.
Roel-CP is offline Find More Posts by Roel-CP
Old Dec 05, 2012, 09:13 AM
tupelo is offline
Find More Posts by tupelo
tupelo's Avatar
Finland, Uusimaa, HKI
Joined Feb 2008
Best 1.3GHz combo
Hi
At present, what would be the best 1.3GHz receiver/transmitter combo? I was thinking ReadymadeRC but nearly everything is out of stock there.
Is it still the FOX-800 transmitter and Lawmate receiver? Or something else?
In short: What TX and what RX would you buy now for long range flights?
I use Chainlink radio system.
Thanks!
tupelo is offline Find More Posts by tupelo
Old Dec 05, 2012, 10:06 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
I would buy a fox 800 kit + lawmate receiver.
Or stuff from readymaderc if they have stock.
iacei is offline Find More Posts by iacei
Old Dec 26, 2012, 11:12 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Originally Posted by Summitdude View Post
Got the cables and stuff but cant really test it properly since it raining here and will for like a week.
I hooked it up and it seems to work fine except the same issue that i have with other
brand VTXs that the audio level is too loud. I have a resistor to make it less loud.
But this may be a problem with the Gopro audio level could be too high.
Did it have the sound issue? or is it gone with the new lawmates?
timtimtim is offline Find More Posts by timtimtim
Old Jan 02, 2013, 02:51 PM
falconiforme is offline
Find More Posts by falconiforme
Joined Jul 2012
1.2GHz Omnidirectional antenna
Hi all,
I am building FPV system for my RC car. I have already 1.5W 1.2GHz Tx/Rx.
But I do not have proper antennas. I want to use omnidirectional antennas with about 6dbi on Tx and Rx.
I found this antenna on e-bay but I did not found any particular info about it:
1.2 GHz 7 dBi Omni GSM rubber Antenna SMA male connect
http://www.ebay.pl/itm/1-2-GHz-7-dBi...item2310e25701
If in your opinion it is not worth it I could build my own antenna based on this tutorial:
http://wireless.gumph.org/articles/homemadeomni.html
Thank in advance
falconiforme is offline Find More Posts by falconiforme
Old Jan 03, 2013, 03:58 AM
Rastislavko is offline
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Hi, so much work, not worth of I think... Make tuned dipole antenna and you'll be fine: http://www.rcgroups.com/forums/showthread.php?t=1159968
For the car the CP antenna would be better... but you can't hide it in the car.
Rastislavko is offline Find More Posts by Rastislavko
Old Jan 03, 2013, 07:30 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
I flew yesterday evening with 1 watt lawmate and audio was great , just had to,turn down the volume
It is great to hear servos etc. if one of my servos is slightly bound and makes buzzing I can stop that with little servo movement, so glider has no servo sounds but just wind
Motor sound also is great
Maidened a glider but powered the video,tx with separate battery
Now plane is trimmed etc i will remove video tx battery and just power the camera and 1 watt lawmate via balance plug of a 3 cell
I hope with ground tests my camera and video tx work to 8.5 volts
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jan 03, 2013, 07:34 AM
David22 is offline
Joined Apr 2008
You mention to me a while ago about better penetration with non omni antenna
I switch to fan antenna and now fly into areas that with stock whip was unflyable
For short range in good flying rf areas the omni work perfect
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
