Old Nov 01, 2012, 01:04 PM
Summitdude is offline
Find More Posts by Summitdude
Summitdude's Avatar
Joined Oct 2012
Originally Posted by GLADUS63 View Post
I'm using SPW on my lawmate VRx and it's good.
You can only fry a VTx... but not with a SPW.
I forgot to add, mine is the 1.2ghz. What urs ?
*edit* ok i tested it and it seems fine (on "bench test" that is).
Its a Circular Wireless SPW that has a high pass filter on it (to remove UHF freq.)
Summitdude is offline Find More Posts by Summitdude
Old Nov 01, 2012, 02:03 PM
GLADUS63 is offline
Find More Posts by GLADUS63
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
I'm using 1280MHz
GLADUS63 is offline Find More Posts by GLADUS63
Old Nov 02, 2012, 02:57 AM
Summitdude's Avatar
Joined Oct 2012
I'm using 1280MHz
Same here.
Why i asked is that i have read about it not working in other threads
like here http://www.rcgroups.com/forums/showthread.php?t=1423690
Old Nov 02, 2012, 02:59 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Im also using lawmate 1.2 with spw on vrx without Any problems
timtimtim is offline Find More Posts by timtimtim
Old Nov 02, 2012, 03:08 AM
GLADUS63 is offline
GLADUS63's Avatar
Joined Jul 2009
I don't know there was this problem, may be like some 5gh8 there a power source for an active antenna or LNA, and in this case it wouldn't appreciate any antenna that is shorted like SKP and Cloverleaf.
Old Nov 05, 2012, 10:55 AM
Summitdude's Avatar
Joined Oct 2012
So i am getting way to high audiolevel from the vtx i think. If i have the volume @ 1/50 in my monitor it still is crazy loud.
I use a GP2 and a Mini FPV 1000mw.
What is the easiest solution ?
Old Nov 05, 2012, 02:24 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Put a resistor in the audio out line.
vertcnc is offline Find More Posts by vertcnc
Old Nov 05, 2012, 04:27 PM
Summitdude's Avatar
Joined Oct 2012
Going to buy a set of different ones tomorrow, mayby a potentiomer too so i can find a good value.
Old Nov 05, 2012, 04:36 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Yah, Potentiometer would be the best. You can find some pretty small ones. Just leave it in-line.
Old Nov 07, 2012, 10:27 AM
Summitdude's Avatar
Joined Oct 2012
Got some used ones in a store but they all were bulky.
But i used one to find a sweet spot. I ended up @ almost 4k ohm. I actually didnt need that much to make the sound good but i noticed when i increased the resistance a bit further some small strange static in the picture vanished also.
Mayby some audio bleeding into the videofeed ?
Old Nov 07, 2012, 01:44 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
I am not an electronic expert but, I always had problems with the audio being over driven where it bleeded over to the video creating static lines similar to what happens form interference from motor. Most of my setups now, I have put a volume control in-line but now just leave the audio disconnected.
Old Nov 13, 2012, 02:10 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Hello to all I am in need of a
Low pass Filter LPF1200/LPF1400
If anyone in the USA has an extra one.
I would love to get it from you.
I have an FPV demo this weekend and would love to use my 1.3 ghz vtx to show the guys around here some tree surfing.
If you have one plz PM me. The one I ordered won't be here quick enough.
Thanks guys?
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 20, 2012, 10:06 AM
Summitdude's Avatar
Joined Oct 2012
Got my lawmate 1.2 1000mw today. I guess they changed the design ? New "heatsink" and a connector instead of soldered wires.
Old Nov 20, 2012, 10:47 AM
Joined Apr 2012
Nice is it free from sound issues? And where did you buy it?
Old Nov 20, 2012, 11:04 AM
Summitdude's Avatar
Joined Oct 2012
Hobbywireless.
Will try it out soon.
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
