Old Sep 03, 2012, 08:19 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
FYI just did a Test yesterday with a dragonlink V2 and a crappy Digital Rx, Indeed the Dragonlink caused problems but as soon as we got it 2 m away from the Rx we went to 2.5km on 1240Mhz with homemade Cloverleafs and Bob 700mw
iacei is offline Find More Posts by iacei
Old Sep 06, 2012, 07:36 PM
snelan is offline
Find More Posts by snelan
snelan's Avatar
Joined Jul 2012
So I am getting some weird glitching with my 900MHz system. It seems to do the "I feel like sliding off the screen vertically" thing. I figure 1.2GHz and 900MHz probably experience the same issues so...
My only possible theories for this are:
1 - It is getting RF from something like the motor or servos. (It is mounted behind the motor on that little pad on the Skywalker.
2 - It is getting RF from my newly installed Rangelink. However, the RL is in low power mode and the antenna is mounted right by the aileron servo on the wing, so at least 2 or 3 feet away.
3 - I was doing a lot of testing on the ground for setting up the RL, so the video system might not of liked the 11.4v on the video battery after it got lower (I fly two batteries). I fly through a NOVA OSD, I imagine I don't need an LC filter on the separate battery if it also powers the OSD?
4 - I wasn't far enough away from the ground station.
In case it matters, this is a 910MHz 800mw system from BEV, flying an inverted vee and an 8dbi patch (patch also from BEV).
snelan is offline Find More Posts by snelan
Old Sep 07, 2012, 05:07 PM
Adrian87 is offline
Find More Posts by Adrian87
Joined Jul 2012
thx
Hey,
just wanted to say thanks! especially to ian!
i had a vrx from Bevrc 1.3ghz and could not stand any closer than 10m with my rmilec uhf system, video just shuts down. after reading for a while i got a 4ch Racewood vrx from dronesvison. All problems solved, just went home from my first real fpv flight(even though bad weather over here in germany atm). I could even touch the racewood reciever with my rmilec uhf antenna without interferrence! Great forum, thanks guys!
Adrian87 is offline Find More Posts by Adrian87
Old Sep 10, 2012, 03:27 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
Hi, i have dug out my old Planar 2.4 ghz antenna now unusable, can i modify it for my 1.2/1.3 system ?, especially for 1.320 ghz channel 'H', on this,
http://www.bevrc.com/bev-13g-400mw_p242.html
if so can anyone out their give me the measurements (no formula's please my maths are too rusty).
Thaks Paul.
paulinfrance is offline Find More Posts by paulinfrance
Old Sep 11, 2012, 03:30 AM
voutsasva is offline
Find More Posts by voutsasva
Canada, QC, Montreal
Joined Jul 2008
Has anyone tried this antenna?
1.2GHz and 1.3GHz FPV Flat Patch Panel Antenna with 15dBi
I have the eagle eyes tracker and I'm between this one and a Yagi from RMRC.
thanks
voutsasva is offline Find More Posts by voutsasva
Old Sep 11, 2012, 03:36 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
With crappy digital rx long range is no problem, I did 16 km away with clear video, using yagi for video rx
And stock fox 800 for tx
For like 50$ it's well worth buying a better video rx and stop experimenting with crappy ones
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Sep 11, 2012, 07:09 AM
RocketMouse is offline
Find More Posts by RocketMouse
mucho FPV
RocketMouse's Avatar
Joined May 2011
Hi!
Does anybody know is it really FOX-800 as shown in pictures?
JBA-800
http://ru.dinodirect.com/Wireless-Tr...0002|23477|2|0
RocketMouse is offline Find More Posts by RocketMouse
Old Sep 11, 2012, 08:17 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
Originally Posted by RocketMouse View Post
Hi!
JBA-800
Looks just like it, but antennas are usually black... Thats a great price too.
KillerCut is offline Find More Posts by KillerCut
Old Sep 11, 2012, 01:15 PM
mucho FPV
Joined May 2011
I mean has anybody already bought it to be sure?
Old Sep 11, 2012, 07:07 PM
BatterysIncluded is offline
Find More Posts by BatterysIncluded
BatterysIncluded's Avatar
Joined Feb 2007
Hi!
JBA-800
One of the photos shows white antenna but the other shows a black antenna. Looking at the magnified image of the TX shows a FOX800A label (see below). But who really knows for sure what you will get.
Edit: Coupon code 10% Off = RS10OFFSEP
BatterysIncluded is offline Find More Posts by BatterysIncluded
Last edited by BatterysIncluded; Sep 11, 2012 at 07:14 PM. Reason: Added coupon code
Old Sep 11, 2012, 07:14 PM
David22 is offline
Joined Apr 2008
no one else actually gets the fox 800 in the box except for me from local guys who sold me these years ago
white antenna is nothing to worry about
what you need to worry about is if stock antenna is good or not
some are just as crappy as the video rxs they sell
some work very well
Old Sep 11, 2012, 08:47 PM
snelan is offline
snelan's Avatar
Joined Jul 2012
Hi guys, just looking for some oppinions on this.
http://www.bevrc.com/bev-13g-800mw-t...or-fpv_p8.html
I have the 900MHz version, and am getting massive interference. I believe they are identical, but the 900MHz one is firmware locked to channels 0,1,2,3, that's 910-1040MHz. If anyone has a way around that, it would be even more appreciated, and save me buying the 1.3GHz one.
Looking at the first post, it looks to be the Sunsky 1.2Ghz 800mw aka Fox-800 without the heatsink.
Old Sep 11, 2012, 09:01 PM
David22 is offline
Joined Apr 2008
which ever one you get , heat glue or whatever the video tx antanna and the video tx houseing. it will or could make a big difference in your life of the video rx
you can use papertape first then hot glue to make great bond.
idea is to ensure if brush or hard landing the video tx does not get broken
try highest possibale channels to gecloser to 1.2
i
Old Sep 12, 2012, 01:01 AM
mucho FPV
Joined May 2011
Thanx for code!
Got one, will post what it is upon arrival.
Old Sep 12, 2012, 05:04 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
scrape is offline Find More Posts by scrape
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
