Old Aug 18, 2012, 06:54 PM
ro.bi. is offline
Find More Posts by ro.bi.
... where is it ?!
ro.bi.'s Avatar
United States, CA, SF
Joined Jul 2011
Originally Posted by Daemon View Post
Try ch 9 on both VTx and VRx. If that doesn't work, then one or the
other is probably defective.
ian
Thanks!
That was (their support) conclusion too, but I haven't heard from them in a couple of days ...
Not too eager to ship the stuff back (cost, time) ... and I might get another broken set again?
Is there another solution I could try?
ro.bi. is offline Find More Posts by ro.bi.
Old Aug 18, 2012, 07:15 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Well, I don't care much for the Sunsky digital display Rxs (they don't work
near UHF RC Tx's at all), so I use a Racewood (4ch tan box) Rx
that is compatible with 4 of the channels on the Sunsky Tx and does
work with UHF RC Tx without issue.
You could pick up one of those, and if that works, you know the Sunsky
Rx is bad. If it doesn't work, you know the Sunsky Tx is bad.
ian
Daemon is online now Find More Posts by Daemon
Old Aug 19, 2012, 01:00 AM
tosjduenfs is offline
Find More Posts by tosjduenfs
Joined Jul 2006
So today I ran my fox-800 for about 1.5 hrs for a sort of confidence run and to see how long my ground station battery and video goggles would last. I have a 20mm fan mounted to my Tx for cooling. I checked the video frequently during the run and did not see any problems. When I finished and disconnected power from Tx and Rx, the Rx was just slightly warm (like normal) and the Tx was just barely above room temp.
I turn them both on again later and I get nothing. I fiddled with all the connections and they were all as they were supposed to be. I didn't touch the thing since the last test.
If I put it on channel 4 or 5 then I could just barely make out an incredibly distorted image. But when I put it on any other channel I get absolutely nothing. The batteries to Tx and Rx were good.
What's going on here, has anyone had this problem before?
tosjduenfs is offline Find More Posts by tosjduenfs
Old Aug 19, 2012, 02:09 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
For tests like this I put a watts up between the battery and video rx
To find the amp draw, then just use battery discharger to test battery to see how long it lasts
Fully charged 2 cell will,still,work for video rx to find lowest volts the videomtx will stop working,
Don't forget to also do,range tests when low voltage tests are done
Set up ground station so it works for a long long time way more than you expect
Also set up your rc rx so it lasts for a long long time
Remember the fox video rx and rx are poor in quality so also expect things to not always work well as quality is inconsistent
Consider yourself lucky your fpv stuff failed on the bench as in the air would of cost you more than just a video tx
Good ground range tests like you do is important as you found out
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 19, 2012, 02:14 AM
ro.bi. is offline
... where is it ?!
ro.bi.'s Avatar
Joined Jul 2011
ian
Thanks Ian!
My radio is a stock Turnigy 9x (2.4Ghz). I'll do that when I'll upgrade to ?Rangelink?
What other video has good penetration & works w/2.4 RC?
(preferably w/ stock antennas & w/out filters).
Will see what Sunsky support does ...
In the meantime I'll go back to my 5.8ghz video ...
Old Aug 19, 2012, 02:20 AM
Joined Jul 2006
Well the gear has lasted through several fpv flights but I was testing my new goggles and now it won't work
Old Aug 19, 2012, 03:10 AM
David22 is offline
Joined Apr 2008
This is great example to have video recorder that has screen
If in case goggles stop working you just look at pvr
Lots of this fpv stuff is poorly made and as you can find out many people have reported problems
Keep it simple and lessen potential problems
You goggles might just have connections that have come loose
And can be fixed easy with simple mod with hot glue
The older rv
goggles had big defect due to this
Just folding the goggles causes this issue
Dominators have poor coax that shorts out
Headplay are just crap
Do some wiggle tests
Can be fixed easy
Old Aug 19, 2012, 03:15 AM
David22 is offline
Joined Apr 2008
I done lots of testing with those video rx's
Don't waste yourvtimevwith them
Originally Posted by GLADUS63 View Post
Flying in an area with a lot of interferences, I found an idea (not new and use by professionals), why not killing the parasites with a band pass cavity filter.
I found one on ebay, I modified it to suit 1010Mhz (a spectrum analyser is needed for that), it's the blue thing from REACTEL.
I made a test video, with 2 VTx emitting at the same time, on for simulating parasites (800 mW at 980 Mhz with a dipole) and one for simulating a long range plane flying away (200 mW at 1010 Mhz with a dummy load on it).
I'm very happy with it, just look at the result, first test a good Vrx (lawmate) with no cavity, second test RMRC with the cavity filter.
http://youtu.be/MrvTn7Ht_ro
The test
Conclusion, some more professionnal than me could make filter like that for specific frequency, that would be very usefull for us. May be IBcrazy ?
Cedric
Old Aug 19, 2012, 12:10 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
None.
ian
Old Aug 19, 2012, 01:23 PM
ro.bi. is offline
... where is it ?!
ro.bi.'s Avatar
Joined Jul 2011
None.
ian
Thanks Ian!
So you got best video penetration with a 1.2 Sunsky Tx & compatible Racewood Rx?
Which antennas?
Old Aug 19, 2012, 01:56 PM
GLADUS63 is offline
Find More Posts by GLADUS63
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
Even this one from RMRC ?
GLADUS63 is offline Find More Posts by GLADUS63
Old Aug 20, 2012, 12:10 AM
Joined Jul 2006
The older rv
Can be fixed easy
Thanks, but I tested it with goggles and two lcds and I still get nothing. I've got some new range video gear on its way.
Old Aug 20, 2012, 01:03 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
I have a lawmate 1.2Ghz VRX and looking for a VTX for about 20-30USD, which one?
timtimtim is offline Find More Posts by timtimtim
Old Aug 20, 2012, 01:13 PM
GLADUS63 is offline
GLADUS63's Avatar
Joined Jul 2009
I want to buy the best lawmate Vrx I can found, what is the difference with pro and non pro lawmate, except built in battery ?
thanks
Cedric
Old Aug 21, 2012, 12:40 AM
David22 is offline
Joined Apr 2008
Tim most likey test each video rx so they should all be good
I however tested 7 of them and found a few to be absolutely useless
1 or two of them however worked great out of the 7
But lawmate video rx at that time was way better withnuhf and video in general
Reports now are lawmate rx's are not good
The new ones they sell
I would recomend the immersion video rx's even though I never used them before
Good video is just way more than a video rx but videomrxmismimportant
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
