Yes it gets hot, even with a good antenna. But it doesn't get hot enough to
cook itself, as long as it has at least one bare side open to the air. The FOX800 has proven itself to be a pretty solid Tx. ian |
Latest blog entry: My 2012 FPV year in Review
I think that would be a bad idea.
ian |
Joined Sep 2009
I read at a forum that this Tx can handle more than 12V and as a side effect it outputs more dB. So there is an internal 12v regulator in there, right? As a result it can work at lower voltages with lower output power but anything over 12V drops down to 12V creating extra heat. I am asking because here you can see that voltage affects output power http://www.rcgroups.com/forums/showp...64&postcount=5 |
Joined May 2009
So this FOX800 seems to have been a good (if impulsive) purchase. A few more questions, if I may:
-Is it advisable to remove the actual transmitter from the surrounding case/metal plate assembly? It seems overbuilt for my purpose. I was thinking about removing the case and gluing a CPU heatsink onto it. -The box/manual says its 1.2 mHz (or, I guess, that's gHz?). I am looking to upgrade the antenna, probably either a Cloveleaf, a V or skewed wheel from ReadyMadeRC. (Actually--i'll probably get one of each!!). Does it matter that the ones available from that site are tuned for 1.280 mHz? Can I "custom-tune" it down to my 1.2 transmitter? Maybe selecting the higher channels on my tx/rx will help get it closer? |
Joined Sep 2009
Boise
Joined Mar 2009
I'm having really crappy luck with the lawmate 1W...... Now I get no signal unless i grab the transmitter in my hand, then perfect video comes through, it's not the wires either, wiggling them gets nothing..... I worked extra hard on all my solder jobs too... Could this be a negative wire issue or something? or bad vTX AGAIN? My last one I got working but would have some drop outs when i touched it or the antenna (could be my TV responding to the static) The audio channel was dead.
| Thread Tools | |
| Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? | iacei | Video Piloting (FPV/RPV) | 24 | Jul 22, 2010 08:49 AM |
| Discussion 1.2Ghz Tx Only: Where to buy a cheap one | iacei | Video Piloting (FPV/RPV) | 9 | Jun 07, 2010 02:03 AM |
| Question esc all one, can i change to different tx/rx? | Fossy313 | Beginner Training Area (Aircraft-Electric) | 4 | Jan 30, 2010 04:07 AM |
| Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro | _Spud_ | Video Piloting (FPV/RPV) | 1 | May 23, 2008 12:31 PM |
| Are 1.2ghz Tx and Rx any good. | JustFly | Aerial Photography | 3 | Apr 22, 2005 11:46 AM |
