Old Jun 01, 2011, 07:53 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Does the SAW filter mod actually help out a lot? -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old Jun 01, 2011, 10:05 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Having to read some saying it was worse.
I use a Hexacon thermotrac soldering pencil. It has a dial and can go up to 850 deg F using 120 watts regulated.
Going to max heat I flowed some solder on top of the old filter. In about 45 seconds the filter started to move. Adding another 15 seconds the pencil was removed and I grabbed two small flat head screwdrivers fast and lifted the old filter off the board angled against the rails evenly. Using solder wick the remaining solder was removed afterwards. I purchased 4 filters 2 were spares. I decided on the second receiver to solder the bottom of the saw to the board using heat just like removal. That was not the right thing to do. Later results showed fuzzy areas on the video link. Don't burn the new saws like the ones that are removed. Heat the work fast, apply solder at the right time. Let cool. I used acetone on tissue to remove the flux. Works well.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jun 02, 2011, 06:18 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You are highly unlikely to see any difference with the SAW mod. Many of us have done it successfully but have seen little improvement. The reason for this is simple: most people's problems have little to do with RX sensitivity. Problems experienced in the RX side are ususally multipath interference and noise floor. Neither of these problems can be overcome by a more sensitive RX. These problems must be overcome by frequency and antenna selection.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 02, 2011, 06:20 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by idletime View Post
Just to be specific...when 'we' say 1.3...is that really 1280 or is it in fact 1300??
thx
1.3GHz = 1245-1296MHz
The cheap multi channel VTX at the beginning of this thread does 1256MHz which gives us an additional 1.3GHz frequency. Unfortunately, I already had one fail on me, so I question the quality. It's also large and heavy.
-Alex
Old Jun 02, 2011, 08:09 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
You're talking about the one from Dino Direct, right, Alex? I had mine fail too, do you have any idea what happened to yours?
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Jun 02, 2011, 09:14 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Was it an inflight faliure? (I also have one )
msev is offline Find More Posts by msev
Old Jun 02, 2011, 10:26 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yep, the same one.
The voltage regulator shorted out internally. I think it was a ua78m05. I'll have to replace it and then check it for heat. As much as I think this transmitter is way too large, there's no doubt that having an extra 1.3GHz channel has it's advantages. I'll have to do some stress testing on this unit too.
-Alex
Old Jun 02, 2011, 10:28 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nope, pre-flight failure. I never flew the transmitter. I'll replace the regulator and see if I can determine the failure cause. It might be over driven. The regulator is speced for 500mA, but with a large heatsink. There is no heatsink on the dino direct transmitter, so the current limit is probably closer to 150mA.
-Alex
Old Jun 02, 2011, 11:31 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
-Alex
Hi do you think the lawmate vrx's are worth the money in comparison the the stock fox rx's?
NDw is offline Find More Posts by NDw
Old Jun 02, 2011, 11:48 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not if you are using a circularly polarized antenna system. I actually prefer the cheaper units If you are using linearly polarized antennas, then the Lawmate is certainly worth the investment.
-Alex
Old Jun 02, 2011, 12:09 PM
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Alex, what is your favorite, overall video system on 1.2?
I need to buy another combo for my new plane, and might as well get something that's preferred by the pro
Old Jun 02, 2011, 01:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I like the Sunsky-800, personally. It's only 600mW, not 800, but it works down to 7.5V. I use the standard 1.3GHz RX from readymade RC rather than the Lawmate. The cheap RX that comes with the Sunsky is OK with a circular polarized system, but the filtration is kind of poor. I can still do a mile and a half on omnis with the stock RX.
-Alex
Old Jun 02, 2011, 01:41 PM
NDw is offline
NDw
NDw
Joined Aug 2010
Is it possible to improve the filtering on the stock sunsky unit?
I know some people have changed the module to the comteach one but I think I read on rc-cam forum you need special tools to set the video lvl afterwards.
And the filtering on the "standard rx" on rmrc site is better than on a standard lawmate?
Old Jun 03, 2011, 02:29 AM
Joined Feb 2011
I don't know but possibly at 0 deg K there is nothing flowing unless it is bumped.
Old Jun 03, 2011, 07:37 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The filtering on the modules of the Lawmate and RMRC is similar. If you change the SAW filter on the RMRC unit, the filtering will be even better than Lawmate. Lawmate has better video processing, however. The processing in the Lawmate allows it to filter multpathed signals better than a standard RX. With a circular system, the antennas do that for you.
-Alex
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
