South East, MN
Joined Mar 2007
It'a a fantastic plane. Being Z-foam it's more quickly fixable than a balsa plane, and landing it takes more room than some lighter planes.
If your an experienced pilot I'd look at the 3d hobby shop Buck Huck: http://www.rcgroups.com/forums/showthread.php?t=1226319 But if you need more durability in the form of z-foam this is a great option. |
Eugene, Oregon
Joined Feb 2011
Waverunner,
I agree with creapyd....both are fine airplanes. Have both. Do not have much time on either frame. Extra 300 is tough, faster, but does aerobatics really nicely....while the Buck is lighter, can fly slower, but is of course 3D and is sturdy balsa. Only solution is to buy both!! |
After reading a bunch on the Extra 300 I decided to jump in and get one! I've made the usual mods (pulled and re-glued the gear mount, expanded the battery compartment slightly to fit all my lipos, replaced the wheels with 2 1/2" lite's for park flying) and am psyching up for the maiden flight. I also picked up a couple of 11x7E APC props to make the first flights more manageable, but the prop hub is smaller than the motor shaft. I hadn't read anything in the thread(s) about having to ream the APC props out, so am I missing something? And if they do need to be reamed, what are you guys using?
The Great Planes reamers include a handle so they can be turned by hand, just takes a LONG time to ream a prop that way. If you have a power drill and a vise, you can put the reamer into the chuck of your power drill, put the prop in a vise, and carefully ream with the bit at 90°.
| Thread Tools | |
| Discussion Parkzone's F4F Wildcat Owners Thread | ChuckTseeker | Electric Warbirds | 9982 | Today 07:46 AM |
| Discussion Parkzone Sukhoi SU-26XP Owners thread | tdriedger | Micro RTF | 2934 | May 01, 2013 07:44 PM |
| Cool Its here!!!! Parkzone extra 300 | lightspeeddud | Parkflyers | 26 | May 31, 2010 08:34 PM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Parkzone F-27 Stryker owners--Are you happy with it? | BuzzBomber | Parkflyers | 43 | Mar 21, 2008 10:49 PM |
