Old Jun 02, 2011, 10:26 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
Originally Posted by jgalexander View Post
Interesting. I got two of the 2200mAh 25C version about 4 months ago, and they seem to be doing pretty well. They come out of the extra cold, both with the stock prop (before I broke it ) and with a 12x6. How long did it take yours to fall to pieces?
The first couple failures were around 6months/50 cycles, A couple had weak cells out of the box that worked itself out after a few cycles. It does seem the quality control varies widely with the Blues, a couple are still going strong after more than a year,
alucard0822 is offline Find More Posts by alucard0822
Old Jun 02, 2011, 11:38 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Gotcha. Thanks for the heads up!
jgalexander is offline Find More Posts by jgalexander
Old Jun 04, 2011, 09:42 AM
bonnie9496 is offline
Find More Posts by bonnie9496
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Have logged 30 flights now on my Extra 300 and love it! The landing gear has come out twice so have given up on it. Hand launch and belly land on my grass field. The plane is so easy to hand launch. Use 80% throttle and away she goes See my video
Parkzone Extra 300 Hand Launch (0 min 23 sec)
bonnie9496 is offline Find More Posts by bonnie9496
Old Jun 04, 2011, 07:54 PM
shung1 is offline
Find More Posts by shung1
shung1's Avatar
Joined Jan 2011
http://youtu.be/GxFvHEIRpOk
hey mate,
Did you put anything underneath the fuselage to protect the foam/paint for when you belly land it?
cheers
FYI: what i did with my landing gear was take the screws out that hold the side fairings to the landing gear plate. This in fact puts less force/pull on the plate as the wire flexes when the wheels touch the ground. The fairings are held in place with clear tape.
shung1 is offline Find More Posts by shung1
Old Jun 04, 2011, 09:44 PM
Fighting Gravity
bonnie9496's Avatar
Joined Jan 2011
Originally Posted by shung1 View Post
hey mate,
cheers
Thanks for the feedback.
I have now placed a thin plastic plate(in orange) over where the landing gear attached. The tail wheel is still in place so only a small amount of the fuselage touches the ground. May put some small glider skids on the wing tips if wear is evident.
The grass is very thick and uneven on the field where I fly so this seems to work for now.
Old Jun 09, 2011, 08:29 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
bonnie9496, I spent 8 wonderful days in Perth in 1983 while stationed aboard the USS Carl Vinson. Perth and Fremantle have to be my favorite places of the many I visited. I especially love the big park (King's Park?) To fly a RC plane there would be a memorable thing. Perth had to be the cleanest city I ever saw. Great place and many fond memories.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jun 10, 2011, 09:37 AM
Fighting Gravity
bonnie9496's Avatar
Joined Jan 2011
Yes it's a great place to live.
No flying allowed in Kings Park. Too many pedestrians and tourists. The big drop off on the Easern side to the Swan River would be awesome for slope soaring.
Old Jun 11, 2011, 10:10 AM
FalseHope is offline
Find More Posts by FalseHope
Foam Flyer
FalseHope's Avatar
Wakulla County, FL
Joined Oct 2009
Hey 300 flyers...
I just got a 300 and I am having a little problem that someone may be able to help me with. First off, I am liking this plane in the air and find it fun to fly. I am pretty nervous with it and have only flown it a few times so far.
I understand the need to land it faster than my other planes, so I have been lining it up for a long staight in approach. Here is my problem (other than slow thumbs and a narrow landing strip)... On final either with no power or just a little the plane will pick up speed, balloon up a bit, slow to a stall, nose down, pick up speed, balloon up, repeat, repeat etc. I would prefer it to just find its own glideslope and come down in a straight line.
Is this a CG issue? Should I make it more nose heavy or tail heavy? Any help would be appreciated.
FalseHope is offline Find More Posts by FalseHope
Old Jun 11, 2011, 12:05 PM
Joined Apr 2010
Originally Posted by FalseHope View Post
Hey 300 flyers...
Been there! I did a few things that helped my smooth out my landings with this reactive little plane.
1. Pushed the battery fwd until the velcro was just covering the very end of the battery. Nose-heavy CG is easier to manage/less squirrely than tail-heavy CG.
2. Flew approach and landing with low-rates to reduce the chance of over-controlling and inducing a stall.
3. Practiced a number of fake landing approaches (go-arounds) at an altitude safe enough that I could recover if the plane got too slow (~50')
4. Flew a base-crosswind-final approach (just like at a real airport) so I'd have time to get my speed and altitude (and brain) set up for landing.
Some pilots do a shallow power-on approach, while others do a steeper power-off approach. I think playing around with it at altitude will help you figure out what style is best for you and your landing location.
Hope that helps!
Josh
Old Jun 12, 2011, 09:16 AM
robusp is online now
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Try what Josh recommended. Especially moving the battery forward, since its and easy fix. The rest you have to practice.
I added washers to the top screws of the motor. My plane with elevator trimmed horizontal stays level at pretty much all speeds. (2/3 to wot)
If you have spare channel on your receiver, run ailerons separately.
Program some spoilerons. It will help a lot. It will give you faster sink rate.
With all that it will still need power on approach.
Another thing, change the prop to 11x7. You will lose top end, but gain slow speed control. 12x7 is better, but I could get it to last only 5 landings on average. My 12's are now 11.5 and 11".
If you really need to land slow, you can, but you have to blip the power once in a while and right before touch down to get prop wash over surface controls.
What helped me was practicing with a cheapo profile 3D planes and jets.
In those planes throttle control is everything.
Rob
robusp is online now Find More Posts by robusp
Old Jun 12, 2011, 10:51 AM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Guys I have a problem. For some odd reason my 300 does not want to roll tight. Instead of a nice roll around the axis i get a slopy barn roll to the left and to the right a nice roll. I have adjusted everything right. I was wondering if anyone out there has any inputs? Cheers
DonQ
DonQ8401 is offline Find More Posts by DonQ8401
Old Jun 13, 2011, 07:19 AM
Pennsylvania
Joined Jun 2010
DonQ
Check your throws, and if you can run the ailerons to separate channels do it. More than likely one servo has a bit more throw than the other, and depending on the angles of the arms when centered, and the linkage length, you are probably getting more throw on one side. The plane will roll nice and axial if the ailerons have the same throw side to side, up and down. With a dual aileron mix, you can adjust end points to get them perfect, without, you have to fiddle with the linkages and subtrim to get them close.
Old Jun 19, 2011, 07:45 PM
starwarsfan is offline
Find More Posts by starwarsfan
United States, NY, Wyoming
Joined Apr 2011
Well I flew mine for the first time in over a year. I was one of the unhappy wings guys when it all started. I tried flipping the wings but put them back to normal. I always thought I may have been landing to slow and that was really the major issue. Based on a lot of the information here I went out to give it another try. With the battery all the way forward and more speed on the landings everything went great. It's back on the " fly me " list. Thanks for the great tips.
starwarsfan is offline Find More Posts by starwarsfan
Old Jun 19, 2011, 08:53 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
A few mm of forward CG shift can make a world of difference. The manual was incorrect regarding the battery location inside the PZ Extra 300, HorizonHobby later released a technical note stating that the correct CG can only be achieved IF the battery is all the way forward inside the compartment, leaving only the red/black lead wires underneath the strap.
ChrisWNY is offline Find More Posts by ChrisWNY
Old Jun 20, 2011, 02:40 PM
capadotia is offline
Find More Posts by capadotia
Joined Jun 2008
I really enjoy this plane but landings have always been a bit of a fight. It flies great but when you slow it up for landings the nose tends to pitch up. This is even with the battery all the way forward on mine. I learned to fly it right to the ground and had been enjoying it a lot over the last year.
Lately, I epoxied about 1/2 oz of lead into the cowl and that made a huge difference for landings. Now I can chop the throttle and it will pretty much land itself - I just need to flair a little before touch down. Now I just like to shoot landings for fun. I have always liked landing a plane but never did it much with the extra because it was such a chore but now I can fly pack after pack of landings.
capadotia is offline Find More Posts by capadotia
Discussion Parkzone's F4F Wildcat Owners Thread ChuckTseeker Electric Warbirds 16916 Feb 04, 2016 09:27 PM
Discussion Parkzone Sukhoi SU-26XP Owners thread tdriedger Micro Ready-to-Fly 3039 Sep 12, 2015 06:55 PM
Cool Its here!!!! Parkzone extra 300 lightspeeddud Parkflyers 26 May 31, 2010 09:34 PM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 04:00 PM
Parkzone F-27 Stryker owners--Are you happy with it? BuzzBomber Parkflyers 43 Mar 21, 2008 11:49 PM
