Canberra Australia
Joined Jun 2009
It's a short coupled plane, so I think good knife edge will always be hard. On the other hand, others on this thread have said they regularly knife edge the plane. I think the CoG would be the critical factor here. I suspect it probably needs to be more forward than I would prefer for my flying.
United States, MA
Joined Jul 2012
Check the throw on the rudder. If you're not getting the full throw you may have problems like you describe. I had a problem with the rudder pushrod binding in the hole in the fuse on mine, severely restricting the throw in one direction. After I opened up the hole so the rod moved freely through the whole range it helped a lot.
I'm happy to report the stock prop is a much better fit than the 10x8 that was on it when I got it. I was able to get it vertical and hold it it for a bit while it torque rolled. Sounded awesome! Got a tail slide in there too...i think a 2200 is just too heavy to sustain those types of maneuvers. The KE is getting there...
I agree, the stock prop is tons of fun. Makes a great sound when it stalls too (during harriers, attempted hovering, tailslides, etc.).
@ MrMurder: If you want to take a shot at hovering, you'll want a prop that can provide lots of thrust and has the diameter to blow plenty of air over the control surfaces. A 12x6 has been the most successful one I've used, and the consensus on here seems to be the same. Best of luck, cause 3D with this puppy ain't easy! Josh |
Latest blog entry: VIDEO: Real Helicopter Rescues Hangar 9...
Canberra Australia
Joined Jun 2009
Part of my problem (with precise knife edge) is that I have hacked away into the battery hold so much, to fit large batteries, that the batteries just sort of flop around the inside and the CoG changes. I guess I should try a smaller (lighter battery) fixed in place to keep the CoG forward, but the nose as light as possible.
United States, FL, West Melbourne
Joined May 2011
| Thread Tools | |
| Discussion Parkzone's F4F Wildcat Owners Thread | ChuckTseeker | Electric Warbirds | 10009 | Today 10:52 AM |
| Discussion Parkzone Sukhoi SU-26XP Owners thread | tdriedger | Micro RTF | 2934 | May 01, 2013 07:44 PM |
| Cool Its here!!!! Parkzone extra 300 | lightspeeddud | Parkflyers | 26 | May 31, 2010 08:34 PM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Parkzone F-27 Stryker owners--Are you happy with it? | BuzzBomber | Parkflyers | 43 | Mar 21, 2008 10:49 PM |
