It must be a sign of a very well balanced airframe
Latest blog entry: Ridge Flying Fun :)
Joined Sep 2012
Swinging a 12X6 at about two clicks over idle I I would have people aske me to please land and check my receiver battery... I was a bit of a frequency pin-hog back in the day. |
I've got an Acro Wot with some kind of 46ish motor in it, might just have to get that flying again.....
Yeah, electrics are quieter for sure!
The Handle comes from me flying [full size] Gliders ![]() I wanted PowerlessPilot but settled for Silent... |
United States, FL, West Melbourne
Joined May 2011
Something to check
When I run into something I always share. I have no doubt that the experienced people out there know this but here goes.
I was advised to check the horizontal stab and make sure it is squared to the fuse and wing. I lamely said it looked OK but boy was I wrong. A significant amount of slippage and I don't know when. Oops! I never thought the bird would be ready in the AM but t is. Thanks also to the post about working the ailerons to loosen them up. After re-gluing the right one the throws were limited. Worked them and cool beans! Rudder ripped off, gear again, a smashed cowl and yes the battery bulkhead. All fixed in a few hours. What a strong tough bird! |
I believe it's RTV silicone. I've used some in the past to seal gaps on my Habu and to glue in servos. Looks very similar and has a similar holding strength.
J |
Latest blog entry: Proud Poppa of a new Cal Grad! :)
Joined May 2011
Tale of two flights
All surfaces square, Side force generators installed. 11x5.5 APC prop and that bird is as good as I can make it. Take off and flight smooth and a stall is REALLY hard to induce. Set up a perfect glide watching it all the way in, slow and smooth.
Did I mention my Sunday field is a soccer field? I had a path well clear of the nets and was waiting for the kiss of three inch wheels. I didn't notice the aluminum bench. Scratch the prop and I got retracts again. This thing lands sweet on its belly. Glued it up and had a great flight. I think we are going to get along just fine. |
United States, NM, Santa Fe
Joined Aug 2011
Silicone
Regular silicone adhesives emit acetic acid gas during the curing process, which can corrode nearby wiring or electronic circuitry that is exposed to the fumes. Neutral-cure silicone adhesives are advised. fairly cheap in 2.8 oz reusable tube from Hardware Box stores-- I used GE silicone II clear window/door/attic/basement-- instead of acetic acid (strong vinegar smell), it releases methyl alcohol and ammonia while curing. The ammonia while curing perhaps could be a problem too for metal. But various folks who repair circuit boards have suggested it as a cheaper alternative. non-corrosive electronics grade RTV is probably better. like Permatex Ultra Copper |
| Thread Tools | |
| Discussion Parkzone's F4F Wildcat Owners Thread | ChuckTseeker | Electric Warbirds | 10240 | Yesterday 08:50 PM |
| Discussion Parkzone Sukhoi SU-26XP Owners thread | tdriedger | Micro RTF | 2934 | May 01, 2013 07:44 PM |
| Cool Its here!!!! Parkzone extra 300 | lightspeeddud | Parkflyers | 26 | May 31, 2010 08:34 PM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Parkzone F-27 Stryker owners--Are you happy with it? | BuzzBomber | Parkflyers | 43 | Mar 21, 2008 10:49 PM |
