I've been using spoilerons more than flaperons.
I don't have to force the nose down to land it just looses lift. One time I had them on for take off by mistake. I realized that and switched them off when plane was still on the ground after rolling for 20 feet at full speed. This morning I had a little mishap. When taxiing away from me and going down wind sudden gust picked up the tail and the plane did a cartwheel. Only damage is crack in fuse right by the tail which I already fixed it. This is not the first time wind did it to me, but usually it just flips the plane and there is no damage. Rob |
I went into a bit more detail on the numbers in the other thread here I'm flying off a DX6i, so mixing on the gear channel seemed either impossible, or very difficult. I had the AR6200 handy from an EDF I was repairing. The plane is not a floater, and I fly from a big schoolyard, so I don't really need any help shortening landings, and with the power the plane has takeoffs are simple and only takes about 20' of "runway", raise the throttle 3/4, keep it straight with the rudder, then pull up when the tailwheel lifts, pitch it straight up, go full throttle, and hang on, turn, spin, or stall it before it dissapears into the sky. For short landings, I line it up at about 6' elevation and just a hair bit of throttle as it comes onto the field, then keep pulling up as I raise the throttle to keep the nose up, and land either 3 point, or tailwheel first, lowering the throttle, holding full up elevator, and the tail stays planted. Only takes about 50' approach and 10 feet to stop, with the bigger wheels, CG at 3" back, and landing gear raked forward a bit it really helps keep it from nosing over, as does a quick burst of 1/4-1/2 throttle and full up elevator as the gear touches down. This isn't neccesary on pavement, and would likely lift the plane back off, but the grass slows the wheels quickly, and the burst of throttle pushes the tail down as the mains start to settle and roll. On pavement you can practically line it up, cut the throttle, and dead stick a nice 2 point landing. |
Tailwind: Elevator full down Headwind: Elevator full up (Just think about keeping the the tail wheel planted firmly on the ground) Quartering tailwind:Elevator full down; Upwind aileron full down Quartering headwind: Elevator full up; Upwind aileron full up (The goal here is to keep the upwind aileron from catching the wind and (again) keep the tail on the ground) Have fun! Josh |
Latest blog entry: VIDEO: Real Helicopter Rescues Hangar 9...
I try not to fly Extra on days like today, but its been a while and I already had it with me. Rob |
I had forgot about the Happy Owners Thread.Yesterday I swapped the stock esc for a ss45 electrifly I had around and ran it on 4s with a 11/7e prop.No static tests or #'s but I did fly it last night.It was cold out so it was a short flight but I must say its enen more fun to fly now.
The beginner throws and exponential settings suggested in the manual actually make this a pretty well mannered plane, so get all your control surfaces centered and use those settings. When it comes to flying it, just remember that this thing is an aerobat, so you need to keep it moving forward at a decent speed. Take it up high, trim it out, and don't push the stall speed too much until you learn where it is. This Extra was my second plane and I've put a LOT of flights on it with no problems... you just gotta respect it's flight characteristics and ease into the more advanced maneuvers slowly. |
Joined Jun 2008
For your first flight I would get a good deal of altitude and get an idea how slow you can fly it before it tip stalls. Then land a little faster than that. Also pulse the throttle on landing, especially with the stock prop. This will help keep air over the surfaces. With the stock prop the plane is quite fast. A common change is to the APC 12x6e prop. It slows the planes down some overall and it will decelerate faster. It also allows for slightly slower landings with a more control due to more prop wash over the surfaces. An 11x7 is pretty much in between the stock prop and the 12x6. Without much WOT throttle flight times are around 8 min max with a fully charged battery. I would recommend to try to bring it down after about 5 min to account for aborted landings. Also knowing what you have flow before would help. Do you have other electrics - are you familiar with LiPo planes and batteries. Do you have any other LiPo chargers or will you be using the stock one? |
| Thread Tools | |
| Discussion Parkzone's F4F Wildcat Owners Thread | ChuckTseeker | Electric Warbirds | 9982 | Today 07:46 AM |
| Discussion Parkzone Sukhoi SU-26XP Owners thread | tdriedger | Micro RTF | 2934 | May 01, 2013 07:44 PM |
| Cool Its here!!!! Parkzone extra 300 | lightspeeddud | Parkflyers | 26 | May 31, 2010 08:34 PM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Parkzone F-27 Stryker owners--Are you happy with it? | BuzzBomber | Parkflyers | 43 | Mar 21, 2008 10:49 PM |
