It can do but the best (worst if you like) spin I've ever been in, and it was intentional at height, was from about 5kts above stall speed. As you slow down boot in full rudder. The inside wing stalls and the outside wing creates lift throwing you over. Trying to pick the wing up with Aileron makes things ![]() Like I said though, it just tickled me, that's all. The important thing is to recognise what is happening and react accordingly. |
Latest blog entry: Ridge Flying Fun :)
DaxFX,
Per your request. http://www.hobbyking.com/hobbyking/s...ner_Motor.html Custom RCParts lists the following Turnigy motors as being compatable with their mount for the Extra 300 Turnigy SK3548-900 Turnigy SK3548-1100 Turnigy C3548-800 Turnigy C3548-900 Turnigy C3548-1100 http://www.customrcparts.com/index.p...products_id=57 I hope that helps and if you go that route please let us know how it works out for you. |
An aircraft stalls due to excess angle of attack. Most of the time this is due to lack of speed but it could also be High G breaking the airflow...
I was trying to demonstrate that slow flight with over use of the Rudder could cause one wing to stall before the other therfore making a spin. Maybe I'm not expressing myself correctly, it's hard to do in text. |
United States, NC, Huntersville
Joined Feb 2009
If the wind ever dies down I'll get it out for some test taxiing and a flight to see how it holds up. |
Australia, SA, Adelaide
Joined Sep 2011
Speaking of stalls, my new favourite way to fly this plane is inverted 3ft off the deck as slow as I canand try and bring it around only using rudder.
I got a little cocky today and attempted to pull out of a very low pass vertically. Pulled a little hard on the elevator and hit the rear stabiliser on the concrete ripping it off and taking the rudder with it. So my top tip of the day is, yes this plane can fly without a rear stabilser, but its not reccomended. Infact it flew so well I finished off the pack before bringing it in. ![]() Some medium CA and some baking soda later and it was back in the air less than 2min flying like new. |
I flew my Radian Pro without a rudder following a mid air collision with my Dad. That thing has a huge wing and virtually all of the vertical stab is rudder (even more so than the Extra) but when it landed with no issues I just moved the battery pack back a bit and carried on ridge soaring for about another 30mins without a rudder...
They must be so overrated!!! |
Improving the top of the Parkzone Extra 300 wing
Wing Help Request
Has anyone tried to fix the flat area on top of the Extra 300 wing. I have thought of gluing long strips (of varying thickness) of balsa along the top of wing and then glue on .4 mm flexible plywood sheet or very thin balsa sheet to restore the airfoil shape on the top of the wing. It would have to be carefully done with a good eye keeping in mind where the top of the chord should be along the length of the wing. Any other ideas out there ?? Thanks Creative RC |
Interesting, so you flattened the bottom of the wing to match the flat area on top of the wing. Is that correct and it worked ? If so that was inovative.
Joined Sep 2010
Here we go again. Well it has been a few days.
Did my usual 5 batteries worth of flying yesterday. The first 2 were spent testing the repairs from my dumb thumbs crash from Sunday. All was well so the next 3 I pushed it a bit, KE loops and Hi Rate snaps even a few intentional spins since that has been a topic of debate recently. All still good, on the last landing I bounced a bit but no big deal the tail stayed down and I didn't scratch up the new cowling. When I taxied back and stopped I noticed a sag in the middle of the fuselage right behind the wings. Closer examination revealed the Fuselage was broken from the back of each wing pocket down and all the way across the bottom. I had cracked it in the same spot way back on flight 5 when the new motor separated. At that time I Super Glued it back together and put 5 thin strips of cellophane tape on it to hold it together until the glue dried. Good thing I left those little pieces of tape on there because that was the only thing holding the fuselage together at the end of flight 5 yesterday. My crash Sunday must have at least partly rebroke the old damage and the snaps and one crappy landing did the rest. Reglued with hot glue when I got home and added some more cheap tape over that. Also made a slightly bigger set of Winglets and installed those. 76 flights total on this Extra hope for more later today. Did 4 flights early this afternoon on the fixed again Extra. Hot glue is a wonderful thing. It tracked and flew as good as new. My new winglets made from $Tree foamboard are slightly taller than the last ones I made and are working very well I did the tightest KE loop yet today. On the down side I think my motor has a slightly bent shaft. At low power there is a vibration and noise that was not there before. At half throttle and above the noise and vibration disappear. I checked the balance on the prop and spinner and all was good. Replaced the prop adapter with a new one and still the same thing. Checked the motor to mount screws and the mount to firewall screws and all were still nice and tight. Guess it has to be the motor shaft? Looks like I am going to be trying one of those cheaper alternatives sooner than I thought. I should send all 4 of these stock motors I have lying around back to HH and see if they can make me one good one out of them. |
Ah crap I killed the thread again! Well I did 3 batteries on my Frankenstryker and 2 on the Extra yesterday. Nice to take them both out and mix it up a bit and get the best of both worlds. Gives motors and ESCs a chance to cool switching back and forth like that. I just need more batteries to keep it going longer. Hoping to elicit some kind of reply from out there.
| Thread Tools | |
| Discussion Parkzone's F4F Wildcat Owners Thread | ChuckTseeker | Electric Warbirds | 10242 | Yesterday 07:56 PM |
| Discussion Parkzone Sukhoi SU-26XP Owners thread | tdriedger | Micro RTF | 2934 | May 01, 2013 07:44 PM |
| Cool Its here!!!! Parkzone extra 300 | lightspeeddud | Parkflyers | 26 | May 31, 2010 08:34 PM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Parkzone F-27 Stryker owners--Are you happy with it? | BuzzBomber | Parkflyers | 43 | Mar 21, 2008 10:49 PM |
