Old Oct 10, 2010, 10:20 AM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Originally Posted by Biggles51 View Post
...Gee with pod retracted and light winds they looked so beaut on a low pass.
Loved the Decal scheme in an earlier post by the way...OK to copy ? ...
Absolutely! Thank you for the compliments. MoF, here is the PDF as promised.
Best to lay down 3M clear packaging tape FIRST anywhere you want to install cut vinyl, helps it stick, because it won't stick to the foam. However, the printed Oracal white vinyl does stick to the foam without clear tape. Have at it, knock yourself out!
Ref. photos > http://gallery.me.com/studiors#100683
studioRS is offline Find More Posts by studioRS
Old Oct 10, 2010, 11:37 PM
Biggles51 is offline
Find More Posts by Biggles51
Gold Coast Australia
Joined Sep 2010
PDF on file for future.
Cheers
Tony
Biggles51 is offline Find More Posts by Biggles51
Old Oct 20, 2010, 10:01 PM
firehorse is offline
Find More Posts by firehorse
firehorse 2
firehorse's Avatar
Kilcoy Australia
Joined May 2004
dg1000
Hi,
I'm on a second model now.
longest thermal 1.5 hrs
I bought spare blades as they wear very quickly
I'm going to add the other dg wings to the next model for a 3/3.5 m model
its a hoot for $$$
firehorse is offline Find More Posts by firehorse
Old Oct 21, 2010, 11:51 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Where can you find spare props?
davidjensen is online now Find More Posts by davidjensen
Old Oct 21, 2010, 11:53 PM
firehorse 2
firehorse's Avatar
Kilcoy Australia
Joined May 2004
I got them from the store I got the glider
bought 5 for $40
Old Nov 07, 2010, 02:06 PM
ShoGinn is offline
Find More Posts by ShoGinn
Space Cowboy
ShoGinn's Avatar
United States, CA, Vandenberg Air Force Base
Joined Jan 2007
So today was the last flight of my DG-1000
Day was going great, I was flying around looking for thermals, couldnt find one so powered up and started gaining altitude and then turned around, well plane just held that turn and spiraled into the ground. motor out and running... no idea why....
Running airtronics Rx600 RX and a Sd-10g so no idea!
couldnt get it to respond to any input on the spiral down....
I got it home and hooked the battery back up after it destroyed the whole fuse.
everything functioned fine...
I am not using the RMS controller just mixes on the radio.
So I have all kinds of extra parts now
Anyone know what KV the motor is? specs etc?
ShoGinn is offline Find More Posts by ShoGinn
Old Nov 14, 2010, 02:54 PM
viper368 is offline
Find More Posts by viper368
Joined Feb 2008
Had an issue with my DG-1000 on it's maiden flight in which the retractable motor arm broke mid-flight, leaving the motor flopping around. I was able to land it safely, but now I'm faced with the task of finding a replacement arm. This must have been a factory defect, as I hadn't done anything to stress that part. The plane was in a straight and level flight when it decided to break.
Does anyone know where I can purchase this item from? Tower Hobbies, who I bought the plane from, has no spare parts listed, and even the manual doesn't have a parts list. I emailed ST-Models, but haven't heard back from them yet. They have a parts section on their site (sheng-teng.com), but you need a user name and password to be able to access it. Any help would be greatly appreciated.
viper368 is offline Find More Posts by viper368
Old Nov 14, 2010, 03:45 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Hype in Germany is the importer and sells the ST Models DG-1000.
http://www.hype-rc.de/?page=shop/pro...85&setlang=deu
Parts are listed through here on other German hobby sites.
http://www.preisroboter.de/ergebnis15649917-30-0.html
http://www.cmc-versand.de/Kyosho/Mot....html?ref=1008
At $99 EU ($135.394 USD) for just the motorsystem alone (Artikel-Nr.: 8-018-1504 ), shipping to USA will place this well over the cost of a total replacement from Tower. It's just a shame.
Another reason why I just ordered an Art-Tech ASK-21 from Hobby-Lobby = replacements parts are supported.
If it were me (I still have to maiden my DG-1000, so I could be faced with the same exact decision with much worse results ), I would remove the motorsystem and keep it as a slope sailplane.
Let us know how you get along, I'd try calling Tower Hobbies and explain your situation.
Old Nov 14, 2010, 04:58 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
My first one had a similar defect and Tower simply replaced the entire model as a warranty claim: it "blew apart" first flight.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Dec 24, 2010, 06:23 AM
jakerevs is offline
Find More Posts by jakerevs
Joined May 2009
ground take off
with a wheel on the bottom and the motor above has anyone tried ground take off?
jakerevs is offline Find More Posts by jakerevs
Old Jan 05, 2011, 10:15 AM
Big Browns is offline
Find More Posts by Big Browns
Phoenix, Arizona
Joined Dec 2008
Where can I buy one of these planes? I've looked on Tower's web site, but I can't seem to find this plane. Please help!
Big Browns is offline Find More Posts by Big Browns
Old Jan 05, 2011, 10:23 AM
Joined Sep 2009
I bought mine at Tower and the most recent "paper" catalog shows it.
Did you try a search for "ST models?"
Old Jan 05, 2011, 10:33 AM
pilotfrank is offline
Find More Posts by pilotfrank
Chicago Mayor: A Terrorist
pilotfrank's Avatar
USA, CA, SoCal
Joined Sep 2002
I've taken off a decent grass field many times without a wheel
No need for a wheel really, unless you fly off asphalt or dirt.
pilotfrank is offline Find More Posts by pilotfrank
Old Jan 06, 2011, 07:22 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
ST Models DG-1000 available through Tower Hobbies
http://www3.towerhobbies.com/cgi-bin...&I=LXYYS4&P=ML
Old Jan 07, 2011, 08:23 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
We were very disappointed when our DG-1000 crashed on the maiden flight last summer, too.
After a great 7 min flight, went to retract the motor system for landing (thinking that would protect it from stress) and the glider just froze. No control at all.
After considering repair options, ordered another one. Hope to fly it in the spring
Next time we will fly it with a Castle external BEC, for power to Rx and servos!
Video of my son flying his DG-1000 on page one of this thread
320pilot is offline Find More Posts by 320pilot
Discussion Harbor Freight EPO Foam 4 channel P-51 Mustang...RTF $79.99..Flight report and Video modfly Electric Warbirds 1342 Jan 06, 2016 09:28 AM
Sold ST Model DG-1000 EPO Brushless Glider RR 79" $125.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 11 May 27, 2010 01:27 PM
Sold Multiplex Easy Glider -Sailplane RR version rfk Aircraft - Sailplanes (FS/W) 2 Mar 13, 2010 06:48 PM
For Sale FS: Kunlun 79" elect Glider mpls/stpaul jimklein Aircraft - Electric - Airplanes (FS/W) 10 Oct 07, 2009 07:39 AM
Help! Multiplex Easy Glider RR / brushless upgrade epwierman Parkflyers 2 Aug 11, 2007 04:29 PM
