Old Nov 21, 2010, 08:33 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Cores only not a kit,and its 54'' I ben contemplating selling cores only with no improvements wings and beds only.
klique is offline Find More Posts by klique
Old Nov 23, 2010, 02:17 AM
bluefalconhollan is offline
Find More Posts by bluefalconhollan
Brazil, MT, Barão de Melgaço
Joined Jan 2007
Just a zephyr made of balsa
bluefalconhollan is offline Find More Posts by bluefalconhollan
Old Nov 23, 2010, 02:29 AM
badinstincts is offline
Find More Posts by badinstincts
Queens, NY
Joined Nov 2005
is it heavier or lighter than the epp version?
badinstincts is offline Find More Posts by badinstincts
Old Nov 23, 2010, 02:34 AM
AgentCow007 is offline
Find More Posts by AgentCow007
USA, CA, Los Angeles
Joined Sep 2004
AgentCow007 is offline Find More Posts by AgentCow007
Old Nov 23, 2010, 03:14 AM
Joined Jan 2007
Weight is 2100 grams include two 3S3200 mAh batteries. Spann 1.7 meters. Profile RAF-48. The shape is simmular to the zephyr but the wing tips are more like wing lets same the robbe sportwing. I will try to make a video soon.
@ Agent...what about "Zepalsa" (:
Old Nov 23, 2010, 08:41 AM
Queens, NY
Joined Nov 2005
what does the bare airframe weight though?
Old Nov 23, 2010, 08:58 AM
Joined Jan 2007
Abou 920 grams on the picture.
Old Nov 23, 2010, 09:24 AM
Queens, NY
Joined Nov 2005
ok, so anyone know how much the zephyr cores weight, Without covering?
Old Nov 23, 2010, 10:44 AM
Bandarra is offline
Find More Posts by Bandarra
Bandarra's Avatar
UK, South Yorkshire, Sheffield
Joined May 2009
Approximately nothing. lol, joking but I would be surprised if it was more than 460g.
Bandarra is offline Find More Posts by Bandarra
Old Nov 23, 2010, 10:50 AM
klique is offline
Mum is the word!
Joined Jun 2003
The two wings only bare, are 240 grams
I can make them from styrene too guys if you want it even lighter.
Old Nov 23, 2010, 12:20 PM
Joined Jan 2007
Actually I did not made a balsa model to make it lighter. I just like a smooth wing. Although a wooden wing is more fragile but it is far more stiff then EPP. To get that stiffness you need to cover the EPP core and that puts weight on.
Old Nov 23, 2010, 04:26 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I love balsa as a building material. All my planes are balsa. I don't crash them too often. However .....
On my Zeph maiden I managed to stall it and lose control. It smashed through a bunch of trees with no damage.
Then I decided to mount the servos in the wing horizontally as recommended rather than my original vertical mounting. I forget to check the controls, of course, and on the launch it went down when I pulled up and slammed into the ground nose first at full throttle. With a balsa wing it would have been tiny little pieces. With my Zeph there was really zero damage. I couldn't believe it.
My airframe with lam and way too much paint and a couple of servos was about 1.5 lb. By the way, my Zeph is stiff like a board. You really can't bend the wing.
u2builder is online now Find More Posts by u2builder
Old Nov 25, 2010, 01:37 PM
mike20sm is offline
Find More Posts by mike20sm
mike20sm's Avatar
California
Joined Aug 2010
I'm duplicating Trappy's setup for the most part, and I need more info on the type of prop and hub used. I think it's a 10 X 6 aeronaut pusher right? Does anyone have a link for hobby king on this item?
*wait I just realized I don't need a pusher prop right, since I can just mount them differently in the hub*
mike20sm is offline Find More Posts by mike20sm
Old Nov 25, 2010, 02:03 PM
Bandarra is offline
Bandarra's Avatar
Joined May 2009
What you need to have the same setup as trappy is:
(all aeronaut material)
- Aeronaut CAM-Carb-Blades.10,0x 6,0" (middle section)
- Prop Hub Yoke 38mm/8mm bore (right section)
- Collet Adaptor .M8 for shaft [your motor shaft] (i used 4.0mm),total length 26mm (left section)
See images and "tecnical names" of the stuff on the bellow link. try to find a local distributor of aeronaut.
http://www.gliders.uk.com/departments.asp?dept=123
Old Nov 26, 2010, 09:59 AM
mike20sm is offline
mike20sm's Avatar
California
Joined Aug 2010
Thanks Bandarra, and what kind of setup did you use to stop the props from folding too far? was it like this? http://static.rcgroups.net/forums/at...g?d=1281969111
Discussion Mats 54" Zephyr RiteWing Build matwelli Flying Wings 47 Nov 25, 2011 07:24 PM
Discussion Another Ritewing Zephyr build thread trappy FPV Talk 136 Jan 11, 2011 04:25 AM
Build Log My little folding Ritewing Zephyr jimbob00 Flying Wings 10 Sep 19, 2010 07:05 AM
Build Log Building the ultimate Ritewing Zephyr trappy FPV Talk 49 Jul 21, 2010 05:28 PM
Discussion Ritewing Zephyr 1st FPV flight Matt Gunn FPV Talk 13 Sep 18, 2009 09:25 PM
