Old Jul 26, 2010, 09:36 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by Air Head View Post
Sorry Jim but I still cant find anything close to 20KW.
I think id be happy with 10, and the 14 cell 200 amp controller should do that, but its only a little past 10KW.
If your making a 20KW motor what do you plan to use to spin it ?
200 amps needs 100 volts to get the 20KW
There will be controllers!
JimDrew is offline Find More Posts by JimDrew
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by Arngeir Blakseth View Post
Another solution for high power would be to make the motor with a higher Kv accepting a higher amp draw and use a 14S 300A controller, that would be good for 15-16kW. There are a couple of those controllers available on the market now (Schultze and Jeti) so no need to wait for vaporware controllers to run the fan unit. Large 2P or 3P batteries needs to be used (10000-15000mAh), but that's just what the large 3D/acrobatic plane guys are doing and have been doing for some years. If it works for them it should do so in a EDF as well.
In the real world, it doesn't work that way! You must use the Kv that matches the load at the peak effiiency.
Old Jul 26, 2010, 10:19 PM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Don't tell me that a Kv of 650 is the only one that a motor can have to spin the Dynamax at max efficiency. I'm sure you could design a motor with a Kv of 750 to do the job just as good if that was one of the basic design parameters for the motor. It may end up with a different length or diameter but what would be the problem in doing this?
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jul 26, 2010, 10:27 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Oh but that's not so AB. Every fan has a peak efficiency and runs best at a given rpm. Now consider esc's and batteries. I think as battery technology gets better we may find that 680 might be a peak kv for the dynamax and still be a usable fan for the average guy. Now if you are buildind a dedicated racer (like I am), then a higher kv is not only desirable but a must. But this is a plane that will fly for 3 minutes tops. Not what most are in the market for.
rvincent is offline Find More Posts by rvincent
Old Jul 27, 2010, 12:22 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Peak efficiency for the Dynamax and a 63mm motor is actually about 645kv. Our new big motor is 676Kv. It is slightly larger than the original 63mm motor so it can handle more load with the same power. Really do have to tune the motor for the load.
Old Jul 27, 2010, 06:54 PM
flyarmy58 is offline
Find More Posts by flyarmy58
Living the dream
flyarmy58's Avatar
United States, TN, Adams
Joined May 2006
Im just ready for the small motor setup,haha Mike
flyarmy58 is offline Find More Posts by flyarmy58
Old Aug 03, 2010, 01:03 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Hey Jim any updates on the Dynamax Xtreme?
bri6672 is offline Find More Posts by bri6672
Old Aug 03, 2010, 01:53 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
They are in production. We will have units available before the end of the month.
Old Aug 03, 2010, 03:16 AM
Jonno271 is offline
Find More Posts by Jonno271
Cardiff, S. Wales, UK
Joined Apr 2009
Got my name on the list yesterday Is there anyone else in the UK using an XPS Dynamax or am I gonna be the first?
Jonno271 is offline Find More Posts by Jonno271
Old Aug 03, 2010, 01:48 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
We have sold 1/2 of our fan systems to Europe/UK, so there are definitely people using them there!
Old Aug 03, 2010, 01:52 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Im starting to make some progress on my Yellow F-18 I cant wait for this fan!!!!!!!!!!!!!!!! SOOOOOOOO Excited
Old Aug 03, 2010, 10:58 PM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
I see progress and a better future!
wingspan100 is offline Find More Posts by wingspan100
Old Aug 17, 2010, 04:25 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Any updates yet?
Old Aug 17, 2010, 08:19 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Parts are on there way to us for building the smaller (6Kw) setup. We will have production of the new larger (20kw) starting on October 1st.
Old Aug 19, 2010, 03:16 PM
Living the dream
flyarmy58's Avatar
Joined May 2006
Just so I know, the smaller (6Kw) would fit my Byron F-16, correct? Thanks, Mike
Discussion My new R1/Dynamax Fan -- T-38 and Foremost 150 CRCJA Electric Ducted Fan Jet Talk 25 Jun 16, 2016 07:30 PM
Wanted XPS/Littlescreamer Dynamax Fan system RCSCALEGUY Aircraft - Electric - Jets (FS/W) 0 Jul 16, 2010 12:47 AM
Sold NEW XPS / Little Screamers Dynamax Xtreme Fan System badbill Aircraft - Electric - Jets (FS/W) 3 May 19, 2010 09:05 PM
Discussion Formost 150 & XPS Dynamax fan system bruff Electric Ducted Fan Jet Talk 12 Jan 03, 2010 11:36 AM
For Sale NIB Dynamax ducted fan propulsion system for OS .91 DF engine WARBIRDMAN Aircraft - Fuel - Airplanes (FS/W) 1 Jun 14, 2005 05:30 PM
