Old Oct 31, 2012, 11:48 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
There is always _something_ that could be better right?
Maybe this fan is too big for my Jet.
dennisjm is offline Find More Posts by dennisjm
Old Nov 01, 2012, 11:14 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by Air Head View Post
This new version without the c-clip notch is much safer as the shaft is the full 8mm (not 6.5mm like it was where the notch is cut). This and the new blades that Tom Cook made (improved blade material) make this the safest version we have sold to date.
No, there is no 'problem' with any version we have produced (we have never had a single fan system come back, and we have sold hundreds of them). We just keep making it better with each new batch. Tom improved the blade material prior to our last batch.
JimDrew is offline Find More Posts by JimDrew
Old Nov 01, 2012, 11:15 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The rule of thumb is that if a Dynamax was in the plane originally, the electric version is a drop-in replacement with 2/3rd the weight of the batteries (12S/5000mAh packs) being added to the overall weight.
Old Nov 01, 2012, 11:25 AM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
Well that's pretty much why I thought this fan would be just fine. From the YA page:
Recommended Power Package: .82 and up Ducted Fan Engine with any 5 1/4" Tractor Type Fan Unit
There are a number youtube videos of this thing flying around with a dynamax/0S .91.
Old Nov 02, 2012, 11:29 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Yep, it will work fine!
Old Nov 04, 2012, 06:22 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
With the most current version of the XPS system, what is the approx amp draw on 12s installed in a plane with a thrust tube. Looking for a power plant for a Yellow Aircraft Starfire, but dont want a super high amp draw.
Brian
Tumbler is online now Find More Posts by Tumbler
Old Nov 04, 2012, 09:16 PM
Air Head is online now
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
Think ill play it safe
and add a capacitor bank.
Air Head is online now Find More Posts by Air Head
Old Nov 05, 2012, 11:56 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Brian
I fly my Starfire on 12S most of the time. Peak amperage with 65C/5000mAh packs is about 120A.
Old Nov 12, 2012, 06:15 PM
Joined Jan 2005
I have the 15Kw system in another Starfire that I will use to set the Guinness record
Care to share some data and let some of the customers of yours in the loop?
Old Nov 13, 2012, 10:09 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
18S 5000mAh setup, strictly designed for this application with flight time requirements of about 1 minute max - two 14 second passes, take off and land.
I established a category with Guinness World Records called "Fastest Electric Ducted Fan Jet - R/C". I know that a 15S setup with dead batteries (4th high speed pass) does 223.9MPH - flat and level, using a Starfire with no main gear doors and linkages hanging in the airstream. I expect double the power and a fully cleaned up airframe to break the 250MPH mark, but I trying to get as close to 275MPH as possible. I will start flight testing in a month or so, with the record setting event to be early next year.
Old Nov 13, 2012, 07:49 PM
Joined Jan 2005
Thanks Jim
Is this an off the shelf setup? What sort of numbers are you seeing @18S as far as load and rpm goes?
Rick
Old Nov 14, 2012, 10:18 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
This is one of our stock fan systems with the winding being off a bit on Kv (about 670 instead of the normal 650).
I did not do a thrust or RPM test for this setup. I will check installed thrust, which is what matters.
Old Nov 28, 2012, 11:42 AM
FliteMetal is offline
Find More Posts by FliteMetal
FliteMetal's Avatar
Joined Mar 2009
Jim,
What is availability of the Pro2 these days? Turnaround from date of order to arrival?
FliteMetal is offline Find More Posts by FliteMetal
Old Nov 29, 2012, 11:41 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
We are currently sold out of fan systems. We have motors built in batches, and it typically takes 2-3 months to get them. The sales of fan systems is very unpredictable. Sometimes we go several weeks without selling a single fan system, and other times we might sell 2-3 a day for weeks straight. So, there is no way to try to stay ahead without investing a lot of resources and considering there is no profit in these, it doesn't make sense to do that.
Old Dec 10, 2012, 04:14 PM
Joined Jan 2005
What guidelines do you need to follow
Wanted XPS/Littlescreamer Dynamax Fan system RCSCALEGUY Aircraft - Electric - Jets (FS/W) 0 Jul 16, 2010 01:47 AM
Sold NEW XPS / Little Screamers Dynamax Xtreme Fan System badbill Aircraft - Electric - Jets (FS/W) 3 May 19, 2010 10:05 PM
Discussion My new R1/Dynamax Fan -- T-38 and Foremost 150 CRCJA Electric Ducted Fan Jet Talk 19 Apr 15, 2010 06:33 PM
Discussion Formost 150 & XPS Dynamax fan system bruff Electric Ducted Fan Jet Talk 12 Jan 03, 2010 12:36 PM
For Sale NIB Dynamax ducted fan propulsion system for OS .91 DF engine WARBIRDMAN Aircraft - Fuel - Airplanes (FS/W) 1 Jun 14, 2005 06:30 PM
