Old Sep 19, 2012, 05:53 PM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Why not simply try to run the fan yourself, then you'd find out how it performs. Much easier than getting a straight and true answer out of JD.
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Old Sep 20, 2012, 11:44 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
You need the higher amperage controller because the power requirement is exponential. The amperage increases dramatically. 18S is closer to 240 amps (at 3.70v per cell using 70C batteries). The motor will handle 20Kw itself, but it is limited to 18S in voltage. The wind (and wire) would have to change in order to use more voltage and less amperage to achieve the same wattage. Make absolutely sure that you test your setup with a ballastics shield over the fan system in case there is a blade failure. Keep in mind the 3.7v per cell is from fully charged (4.2v), under full load, using 10,00mAh batteries. The more capacity you have the lower the voltage drop will be and the higher the wattage output. At this type of load, it doesn't take long to drop from 3.7v per cell to <3.0v per cell. So, you need to be careful not to destroy your packs. Don't expect long flight times at full throttle! For my Starfire setup, I need about 35 seconds of full throttle to make the two passes required and then some low throttle for take-off and landing.
JimDrew is offline Find More Posts by JimDrew
Old Sep 20, 2012, 06:11 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
Ballistic Shield?
What thickness plexiglass do I need?
20Kw PRO VERSION! Only $549 ready to install!
So I read this as the fan is now limited to 18S and on that it will pull 240 amps
this adds up to 15984 watts.
I do not see any way that this 20kW setup can run at 20kW if I understand all this. Yes I read the motor will handle 23kW before the windings break down but I read that we are limited to 18 cells so I am only 4000 watts short of 20kW
Do I get the picture?
Air Head is offline Find More Posts by Air Head
Old Sep 21, 2012, 03:55 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
xxS is not a good way to define max voltage for an application. Voltage will vary depending on current and cell IR (depends on C-rating, capacity and temperature). Only testing can tell if a battery will limit power to a safe level (<20kW).
flarssen is offline Find More Posts by flarssen
Old Sep 26, 2012, 10:33 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The fan system as always been limited to 18S. You can exceed 20Kw with the proper battery setup. If you could have only a .2v drop at full load, you would have 18x4.0 = 72 x 300A = 21600 watts.
The problem is that the voltage sags under load. If you used 50000mAh of capacity there would likely be very little sag.
Old Sep 26, 2012, 11:05 AM
Air Head is offline
Joined Jan 2005
Ill try it out Jim - Thanks
I am planning on using a 12,000 mAh battery, 50,000 would be a bit heavy. Is that how it was run at 20kW? Your spec list shows 16 cells @ 205 amps and then the jump to 18 cells is 300.
Picking up the controller after work today and almost finished with the test stand. (Update) (They sent the wrong controllers)
Rick
Old Sep 26, 2012, 01:57 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
Is the current $549 fan the only available option right now?
dennisjm is offline Find More Posts by dennisjm
Old Sep 26, 2012, 05:20 PM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
Oh and if I were to purchase one what ESC are people running that works well? I saw talk on here of HV escs but I haven't seen anything on the XPS site.
Old Sep 26, 2012, 08:09 PM
Air Head is offline
Joined Jan 2005
That would be the problem.
Id like to see this actually run up on 16 cells, and also the 20kW as advertised.
Old Sep 27, 2012, 02:03 PM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
So what in the mean time? I see some running on ICE2 160 HV but I also see people talking about them burning up. Castle Cremations... you know.
Old Sep 27, 2012, 04:59 PM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
I think I was wrong about them actually being in stock. Wasn't apparent from the site but someone posted they weren't in stock. Tried adding to cart and sure enough it said no inventory.
Soo......
JD any timetable?
Old Sep 27, 2012, 05:41 PM
Senior Member
Molde, Norway
Joined Jan 2001
Jeti Spin 300, or a MGM Compro X-series 25063 will get you going on up to 15S, above that is a problem now that the Fightercat series of esc's seems to be gone, and XPS does not have their HV series out as promised.
Old Sep 27, 2012, 06:15 PM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
I got the jeti spin 200 as a recommendation as well. 200 is probably good enough for me. I might be happy with 12S and if not perhaps 14 would be plenty. YA F18 is my target and I think it can come in under 16lbs when RTF. Those are all "coming soon" to on espritmodels though.
Is it just me or is the high end EDF market dwindling?
Old Sep 27, 2012, 06:44 PM
Air Head is offline
Joined Jan 2005
Controller Setting Questions
Anyone know the best settings for the controllers?
I am wondering about the PWM (8 / 16 / 32) - and Motor Timing.
Old Sep 27, 2012, 10:27 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Why not just get BVM's new fan and controller. Bulletproof service should anything go wrong.....and they actually torture test their systems before being released to the public.
http://www.bvmjets.com/Pages/EVF3_12+.htm
I don't know what application Air Head is putting this fan in - but anything above 12S and about 8000 watts is rare and probably not needed for about 99.5 percent of the modelers out there.
skyhawk is offline Find More Posts by skyhawk
Discussion My new R1/Dynamax Fan -- T-38 and Foremost 150 CRCJA Electric Ducted Fan Jet Talk 25 Jun 16, 2016 07:30 PM
Wanted XPS/Littlescreamer Dynamax Fan system RCSCALEGUY Aircraft - Electric - Jets (FS/W) 0 Jul 16, 2010 12:47 AM
Sold NEW XPS / Little Screamers Dynamax Xtreme Fan System badbill Aircraft - Electric - Jets (FS/W) 3 May 19, 2010 09:05 PM
Discussion Formost 150 & XPS Dynamax fan system bruff Electric Ducted Fan Jet Talk 12 Jan 03, 2010 11:36 AM
For Sale NIB Dynamax ducted fan propulsion system for OS .91 DF engine WARBIRDMAN Aircraft - Fuel - Airplanes (FS/W) 1 Jun 14, 2005 05:30 PM
