Old Jul 21, 2010, 01:30 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
New Product
New Dynamax Xtreme Fan System
Due to the problems we have had in the past getting the large motor from Little Screamers, we had no choice but to pursue other motor manufacturers.
We are replacing the current "Dynamax Xtreme" fan system with a newer, lighter weight version. This version is designed to handle 5000 watts continuously and 6000 watts burst. However, the reality is that this motor is very efficient and typically operates on 12 cells at under 100 amps, making the wattage in the low 4000 watt range.
The motor is integrated into the center hub. It is an outside-in design, meaning that it is an outrunner motor that is placed inside of a housing. There is a a special cooling fan inside that pushes air through the motor. Note: the screws shown in the photos are not the correct type, production units will have proper counter-sunk screws.
This new fan system uses an unheard of six bearing support system! There are two bearings on the rear, two bearings on the front, and two more bearings on the 7/8" long output shaft for the 11 bladed rotor.
We ran the fan continuously for more than 5 hours in the 115 degree F Arizona desert heat! The maximum temperature at the core was 230 degrees F, with the bearing temperatures about 160 degrees F. This is extremely cool compared to other outrunner setups being used in Dynamax fans!
Here are the numbers:
Motor type - outrunner with 8 poles, 12 stators
Motor Kv - 642
Total weight - 2 lbs, 4oz (should drop by several ounces with new rotor hub)
Cells - 8 to 12
Controller - 110A or more recommended
12 cells (XPS Platinum 45C)
Peak amperage - 96A
Stabilized amperage* - 90A
Peak RPMs - 27,110
Stabilized RPMs - 25,960
10 cells (XPS Platinum 45C)
Peak amperage - 84A
Stabilized amperage* - 75A
Peak RPMs - 24,731
Stabilized RPMs - 23,127
* After 1 minute of running
NOTE: Thrust is now equal to (and sometimes better) than the Little Screamer motor we have used in the past!
Retail price will be $439, availability approximately 30 days.
JimDrew is offline Find More Posts by JimDrew
Old Jul 21, 2010, 03:19 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
AWESOME! I am on the list!!!! As soon as orders are ready let me know and I will get you guys paid, I am lovign this!!! So when you say low 4000's on 12s are we talking 4100 or what? And do you have any thrust #s yet on 12s?
bri6672 is offline Find More Posts by bri6672
Old Jul 21, 2010, 03:32 PM
Ken Lapointe is offline
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Jim, motor looks great. It would really help if the 12C and 10C numbers you list had the voltages for the amps, even if it was just the "stablized" voltage.
A picture without the shroud would be great too.
Ken Lapointe is offline Find More Posts by Ken Lapointe
Old Jul 21, 2010, 04:08 PM
lt40 Flier is offline
Find More Posts by lt40 Flier
Joined Jul 2005
I have the Falcon waiting and the credit card warmed up.........EJets is calling
lt40 Flier is offline Find More Posts by lt40 Flier
Old Jul 21, 2010, 04:17 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Voltage and amps depends on your cells, with the XPS Platinum packs we typically see 3.6v per cell under full load. That means 12 x 3.6 = 43.2v x 104A = 4492.8 watts peak. That tapers off and stabilizes to about 4000 watts.
Thrust is just a few ounces less than our our original setup with the Little Screamers motor. The weight savings of 1lb, 3oz. over the other setup more than makes up for that.
Old Jul 21, 2010, 04:53 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Hi Jim,
I invite you to post data on this thread for a spreadsheet project I'm working on for everyones benefit. I sent your office an email earlier today but I just saw this thread.
http://www.rcgroups.com/forums/showthread.php?t=1278689
Great looking fan, now what do I use it in? Decisions-decisions...
Chris
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jul 21, 2010, 05:18 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
So Jim, is it safe to say right at 15lbs of thrust (based on the same environment the big screamer was tested in)?
Old Jul 21, 2010, 05:21 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
The larger motor (20Kw version) will be available around the time e-Jets begins
Can you provide a little more input on this monster you mention?
Air Head is offline Find More Posts by Air Head
Old Jul 21, 2010, 06:05 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Jim,
Would this work in my PST Panther? I'm using the XPS Extreme fan on 12S in it now. I could save 2+ lbs. using this instead. The jet weighs in at 23 lbs now. Would drop down to 21lbs with new system.
Bob
bruff is online now Find More Posts by bruff
Old Jul 21, 2010, 06:06 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Sort of like my Hacker Turbo except you are using the fan center hub for the case..........good idea on using the hub. Is the motor a Hacker?.
Madmax1965 is offline Find More Posts by Madmax1965
Old Jul 21, 2010, 07:16 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
It's actually closer to 16 pounds of thrust with the original motor as well as this motor.
Old Jul 21, 2010, 07:17 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Not yet. We have 10 more samples coming and we want to verify that they all perform the same before releasing pictures and specifications.
Old Jul 21, 2010, 07:18 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by bruff View Post
Jim,
Bob
This would work, Bob. You would save 1lb, 3oz over the fan system you have right now. You could also get rid of the bigger controller and go with a lighter weight HV120 ICE or something like that.
Old Jul 21, 2010, 07:19 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
We are getting the parts from a variety of companies.
Old Jul 21, 2010, 07:49 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Perfect!
Bob
Discussion My new R1/Dynamax Fan -- T-38 and Foremost 150 CRCJA Electric Ducted Fan Jet Talk 25 Jun 16, 2016 07:30 PM
Wanted XPS/Littlescreamer Dynamax Fan system RCSCALEGUY Aircraft - Electric - Jets (FS/W) 0 Jul 16, 2010 12:47 AM
Sold NEW XPS / Little Screamers Dynamax Xtreme Fan System badbill Aircraft - Electric - Jets (FS/W) 3 May 19, 2010 09:05 PM
Discussion Formost 150 & XPS Dynamax fan system bruff Electric Ducted Fan Jet Talk 12 Jan 03, 2010 11:36 AM
For Sale NIB Dynamax ducted fan propulsion system for OS .91 DF engine WARBIRDMAN Aircraft - Fuel - Airplanes (FS/W) 1 Jun 14, 2005 05:30 PM
