Old Jul 21, 2010, 12:21 PM
Joined Jul 2010
wasp V3 6 ch throttle not working
Hi just got my new wasp V3 6 ch heli, took it out of the box charged it, and read the manual. It binds fine, all functions work but when I apply throttle, it does not spin. All other stick movement works though just not the throttle. The control is in mode 2. Any ideas what I could be doing wrong?
newbey1 is offline Find More Posts by newbey1
Old Jul 21, 2010, 11:37 PM
Pontiac/Auburn Hills, Michigan USA
Joined Dec 2008
The top left Silver switch, marked GEAR should be in the up position. The top right Silver switch, marked FLIGHT MODE should also be pointing up or at the N position. - this switch is for normal or inverted flight; inverted or Idle up may not be configured at the factory. ALWAYS make sure this right switch is in up position before you power up the helicopter.
The left switch can be used as a power off switch or flameout or motor off switch.
You did not mention if you have a Sky 701 or a Sky 702 or a Sky 703 Transmitter.
You did not list your country or the dealer you got this from. Most dealers will be more than happy to help you with questions; if not you can contact us for USA Based Factory Authorized Distributor Support.
If this fails to startup the throttle/motor. then you may have to reset the ESC so the ESC recognizes the settings on the receiver and transmitter.
To reset the ESC so it knows the top end and bottom end
of the throttle control.
These steps are easy.
Leave the throttle trim tab at bottom like you normally use it.
Throttle range setting:
1. Switch on transmitter, move throttle stick to top
2. Connect battery pack to ESC, and wait for about 2 seconds
"Beep-Beep-" tone should be emitted, means throttle range highest point has been correctly confirmed
3. Move throttle stick to the bottom, several "beep-" tones should be emitted, presenting the number of battery cells
A long "Beep-" tone should be emitted, means throttle range lowest point has been correctly confirmed
4. You should be ready to test fly
Hope this helps
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Jul 29, 2010, 09:47 PM
Joined Jul 2010
It helped after resetting.
Old Jul 29, 2010, 10:58 PM
Joined Dec 2008
Great! Glad that we could be of some help reseting your Skyartec V3 WASP.
Max
Site Sponsor
Old Mar 06, 2011, 02:53 PM
Joined Jul 2010
recently crashed and rebuilt head but now throttle is backwards
I recently crashed the heli and rebuilt the head and made it match the factory measurements. However, now when I apply throttle the servos move down instead of up. I tried the ESC reset procedure but it doesn't work.
I also ordered the metal upgrade from your e-store and read that I have to change the pinion as well?
Old Mar 10, 2011, 05:24 AM
Joined Dec 2008
emailed directly to provide support and will post the solutions when the problems are resolved
Max
Site Sponsor
Discussion Skyartec Wasp V3 does not respond to throttle newbey1 3D Electric Heli Flying 1 Jul 22, 2010 03:46 AM
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Discussion E Logger V3 RPM with CSM Revlock 10 sensor not working sg sailing Eagle Tree Systems 5 Jan 08, 2010 04:13 PM
Help! Hitec receiver 6s on bat/ch. 6 No throttle on ESC bruceweight Hitec/Multiplex USA 4 Oct 05, 2009 02:51 PM
Question wasp v3 6 channel waspman 3 Micro Helis 4 Apr 12, 2009 12:50 PM
