Old Jul 21, 2010, 06:11 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Build Log
Building the ultimate Ritewing Zephyr
I love my current Zephyr. It does about 130km/h (80mph) in the straight and up to 250km/h (150mph) in a vertical dive. It has quite a few flight hours on its back and is still going strong. In the past I noticed that I wanted to go further and faster than the current Zephyr could take me. Using thermals I was able to achieve that, but it's pretty hard to thermal something as heavy as my Zephyr - this brings us to this build thread, where I'll be going through the basics of building the ultimate Zephyr in terms of stability, weight and power.
The old build was done using the "Riteweave" method that most people here are already familiar with: 3M90 glue and thin fiberglass weave appropriately named "Riteweave" to stiffen the wing. While it adds insane amounts of strength, the weight gain is about 700g for the whole wing, or 500g when being very stingy with the glue and riteweave here and there. Still, the build takes quite a bit of time to complete (~4-5 evenings)
Moving on to the present. The new way the ritewings will be built from here on is using a laminating film. Consider it a monocote on steroids (stiffer, more durable). it is glued and then ironed onto the wing, giving it a lighter yet stronger finish - and the build time is reduced considerably. When everything is laid out properly, the wing should be built in 2 evenings.
Initially I wanted to build something that is light for thermals and with lots of batteries. Having seen the Zephyr from my buddy Chris84, however, I'll build this one here for the ultimate in speed and range and leave the thermaling to the Supra.
I've just ordered all the gear:
Equipment
Plane: Ritewing Zephyr 60" & 3mil laminate, available from RCG user klique
Propulsion: Hacker A-30 L (~1100kV) and Hacker ESC, 10x6 folding prop, ~600W
R/C: EzUHF 8ch diversity RX with active-robot 433 antennas.
FPV: 2.4GHz 500mW lawmate, EzOSD, L1D vario
Battery: 2x 4S 3300mAh Flightmaxx
Servos: 2x Turnigy 380 MAX digital servos, 4.1kg. I will probably need to upgrade to 6-8kg at some point
Expected specs:
Weight: aiming for 2kg, will probably end up at 2.2kg
Flight time: between 25 and 40 minutes
Flight distance: between 20km and 30km.
Max altitude: 3000 - 4500m
Cruise speed: 60km/h
WOT level flight speed: 150km/h
Summary
The new Zephyr will be a bit heavier than my existing one, but it will have twice the power and almost twice the endurance. this will allow me to go further, higher and faster. a plane like this should not be built by someone new to FPV or R/C in general, especially not with the kind of power and weight. if you're getting started, the build technique used here combined with the power setup of my old zephyr will give you an awesome plane for moderate speeds and winds. this bird is primarily for long range flights, something I really want to get into now (10km+). the old zephyr is comfortable with 5-8km distances.
So, this is it for now. I'm in Switzerland this week but should be able to get started on the weekend. Hope there'll be some discussion going on the new build technique. Since this is the first build-thread using the laminate technique, I'll post instructions how to properly build using this method in case some of you want to follow with their own ultimate Zeph
trappy is offline Find More Posts by trappy
Old Jul 21, 2010, 06:21 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Nice Trappy, I can't wait, I am looking for a wing design that can handle the wind without getting the beat out of it.
Tarro is offline Find More Posts by Tarro
Old Jul 21, 2010, 06:29 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
So does the ritewing come with this laminate film already installed, or do they provide it and you install it?
Or do you purchase it elsewhere? I am not familiar with this product.
Derek_S is offline Find More Posts by Derek_S
Old Jul 21, 2010, 06:31 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
edit, nvm.
Kev.au is offline Find More Posts by Kev.au
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
the ritewing needs to be ordered with the laminate film, it's available starting now. both the plane and the laminate is available from klique. if you're interested in ordering, just tell chris you want the same as I have, he will help you with putting the purchase together.
the laminate is like transparent monokote but much stronger. You need to install all the gear first, then add glue & paint, then iron on the laminate. more details on how it's done as my build progresses.
Old Jul 21, 2010, 06:57 AM
TerrorTrooper is offline
Find More Posts by TerrorTrooper
TerrorTrooping
South Wales, UK
Joined May 2010
i will be following this build with great interest!
TerrorTrooper is offline Find More Posts by TerrorTrooper
Old Jul 21, 2010, 07:03 AM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
How heavy is the old Zephyr if you don't mind me asking?
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jul 21, 2010, 07:07 AM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
Could you give a price indication of the products u use.
hugy is offline Find More Posts by hugy
Old Jul 21, 2010, 07:10 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
hugy: a bit over $1'000 all up. obviously I'm not paying full price on the L1D and I wouldn't add one if I had to I haven't done the math exactly as I've got most of the components lying around already. prices are completely out of my head and may or may not be accurate (exchange currency etc). keep in mind this is no longer a toy plane, so while the price may seem steep you couldn't build anything even remotely as performant with much less money. if I went for cheap stuff all the way I could maybe shave $200 off the total, but the chance of crashing increases dramatically.
Zephyr + laminate: ~$200
Engine/ESC: ~$200
Battery: ~$100
RX: ~$150
TX + cam + Vreg: $~150
Servos + Prop: $50
EzOSD: $230
L1D: $130
CrashMeUp: ~1.7kg. using the laminate build technique you should be able to get it down to 1.4kg with the same power setup and 3S2P 2200mAh
Old Jul 21, 2010, 07:43 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Tall order my friend, tall order, ultimate does get my expectations up
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Old Jul 21, 2010, 07:46 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
I think I sent you the vid already from chris84 flying at the meetup. this thing rips!! most important, however, is the added endurance. flight behavior is roughly the same, and the speed range is a bit bigger. btw sander, have you done any measurements with the VSN505 and the EzUHF? the EzUHF antennas will be on the wingtip, but one can't be too careful these days
Old Jul 21, 2010, 08:21 AM
hugy is offline
hugy's Avatar
Joined Apr 2010
What will happen with the old Zephyr. It deserves a worthy place
Old Jul 21, 2010, 08:23 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
the old zephyr will still remain fully operational
Old Jul 21, 2010, 08:32 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
1.4kg?
Old Jul 21, 2010, 08:45 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
yeah. 1.4kg is very possible. keep in mind the zephyr benefits greatly from being heavier, but it's easier to fly when lighter.
Discussion Mats 54" Zephyr RiteWing Build matwelli Flying Wings 47 Nov 25, 2011 07:24 PM
Discussion Another Ritewing Zephyr build thread trappy FPV Talk 136 Jan 11, 2011 04:25 AM
Build Log My little folding Ritewing Zephyr jimbob00 Flying Wings 10 Sep 19, 2010 07:05 AM
Discussion Great FPV plane - Ritewing Zephyr (flying wing) trappy FPV Aircraft 27 Dec 22, 2009 07:03 AM
Discussion Ritewing Zephyr 1st FPV flight Matt Gunn FPV Talk 13 Sep 18, 2009 09:25 PM
