Old Jul 20, 2010, 03:47 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
New Product
FY-20A + Quadcopter
After hearing about the FY-20A auto stabilizer for planes, I wanted to see if it could add the autoleveling feature that my KapteinKuk based quadcopter lacked. Since installing it, I won't be going back to heading hold only mode again.
I was worried that the stabilizer would neuter my quad's flight behavior, but was glad to see that it still lets me zip around with reckless abandon, but with the knowledge that it'll quickly level out if I release the controls. Ever get that feeling (like falling backward in a chair) when you lose orientation or bank too hard because you just know your copter's gonna flip unless you act quick? Now I can let go of the controls, the copter will level out, and I can take time to work out which stick direction brings it home.
The FY-20A is designed to sit between your receiver and flight control board, so it only works with microprocesor controlled tri, quad, or hexa copters that use standard aileron, elevator, rudder inputs. If your's uses discrete gyros and requires 120° or other swashplate mixing, then you'd also need a CCPM mixer on-board.
Be sure to watch in 480p:
FY-20A + Quadcopter (4 min 44 sec)
patricklupo is offline Find More Posts by patricklupo
Old Jul 20, 2010, 04:30 AM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
Wow ! Impressive !!!
Heli stabilizer is also in test...
http://v.youku.com/v_show/id_XMTMwMDAzNDky.html
http://v.youku.com/v_show/id_XMTI5ODMzMDEy.html
http://v.youku.com/v_show/id_XMTI5ODQ1Nzky.html
Maximus
maximus-rc is offline Find More Posts by maximus-rc
Old Jul 20, 2010, 05:11 AM
dcaspi is offline
Find More Posts by dcaspi
destructive testing expert
dcaspi's Avatar
Kiryat Yam, Israel
Joined Apr 2009
Impressive... but then, a good quad controller board should be able to do this on its own. Maybe you should check out one of the boards that support "stable mode", e.g., AeroQuad.
dcaspi is offline Find More Posts by dcaspi
Old Jul 20, 2010, 10:57 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
This would be commercial way to add self leveling to the inexpensive quad and tricopter builds that do not have an accelerometer like Simon's build: http://www.rcgroups.com/forums/showthread.php?t=1219598 or SignGuy's Tircopter: http://www.rcgroups.com/forums/showthread.php?t=1142429 or KapteinKuk's build: http://www.rcgroups.com/forums/showthread.php?t=1143569 It does however, triple the cost and gets closer to the cost of a DIY board as the BaronPilot and Aeroquad and ArduCopter.
Cheers,
Jim
Your project added to the Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jul 20, 2010, 11:54 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by patricklupo View Post
After hearing about the FY-20A auto stabilizer for planes, I wanted to see if it could add the autoleveling feature that my KapteinKuk based quadcopter lacked. Since installing it, I won't be going back to heading hold only mode again....
Good idea, thank you
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Jul 20, 2010, 12:00 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Be interesting to see one of these on the Gaui 330x.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jul 20, 2010, 02:43 PM
Joined Jul 2009
If the Gaui 330X doesn't require any swashplate mixing on your radio then the stabilizer should work fine. FY-20A uses 3 accelerometers and 3 gyros to apply aileron/elevator/rudder to keep itself (and your copter) level so it's going to stabilize anything with standard airplane controls. The specs say it's able to track 1200 degrees/sec, so even if your quad is flipping at a rate of 3x a second, it should still be able to accurately determine pitch, roll and yaw position, and correct for it.
One advantage of an FY-20A on a heading hold based copter vs. one with self-leveling built in, is that I can toggle between HH and auto-leveling modes in-flight. From what I've seen, a lot of copters that have autoleveling, either cannot be switched to HH mode or must be re-programmed on the ground. Several I've seen with built-in stabilization also look to have very docile flight characteristics, but I may be mistaken. I wanted something that essentially offers a saftey net without compromising flight characteristics or agility.
Old Jul 20, 2010, 02:55 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
So the modes can be switch in flight via one of the radio channels correct? Does it just connect to the Rx channel to handle this? How many different "modes" does it have that can be toggled in flight?
Site Sponsor
Old Jul 20, 2010, 03:10 PM
Joined Jul 2009
Yes, exactly. I use my radio's ch5 2-way switch to toggle between off and stabilization modes, but if you have a 3-way switch, the center position sets 3D mode. In a quadcopter, 3D mode is essentially the same as HH so it's not useful, but on a plane it will keep it pointed in the same direction (even vertically).
*If you leave the mode select servo wire disconnected, the FY-20A defaults to stabilization on.
Old Jul 20, 2010, 03:11 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Yes, I use my radio's ch5 2-way switch to toggle between off and stabilization modes, but if you have a 3-way switch, the center position sets 3D mode. In a quadcopter, this mode is essentially the same as HH mode so it's not useful, but on a plane it will keep it pointed in the same direction (even vertically).
Thanks so for the quad it really only needs a 2 way switch as you stated.
So far do you feel it was a good investment, ie worth adding to a quad?
Sssume it works with any Tx/Rx setup such as Spektrum and so on, ie it doesn't require any special Rx or servos or related wiring?
Site Sponsor
Old Jul 20, 2010, 03:39 PM
Joined Jul 2009
Hi Schooner,
I'm the first to test the stabilizer on a quadcopter so I received a sample unit for testing. It exceeded my expectations and I wouldn't have anything to demo had it not worked. In the $100 range the price it's a good value, if you have a quadcopter without auto-stabilization. Before being contacted to the demo the unit, I'd already asked my wife to put it on my Christmas list.
I'd previously ordered an FMA CPD4 but cancelled it when I realized that a quad flys too low and moves too quickly to work properly with horizon sensors. Then I saw this accellerometer based unit knew it was my best option, but had wanted to wait a bit until someone could verify it really worked on a quad first. Turns out that someone ended up being me.
I built my QC almost exclusively for FPV but didn't want to go the very expensive (and heavy) route involving GPS position hold, waypoints, etc. I did want something lightweight to auto-level my small scale copter if I lost video (FPV folks know that's it not an if but a when video goes out), and the FY-20A did the trick. I'll be moving my camera and VTx from my heli to quad this week and will be posting a video of the results in this thread.
I don't have a Spektrum Rx to test it with but as long as it outputs PPM then I see no reason it wouldn't work. The specs list PPM and SPCM (Spektrum PCM?). I think the radio being used in the first demo on the webpage is a Futaba FAAST.
Old Jul 20, 2010, 05:57 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Thanks again for the info. Once I get my 330X going I may have to look at this as a possible upgrade.
Site Sponsor
Old Jul 20, 2010, 06:38 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
thats very cool
do you know if the one that comes with an OSD works with quads
does RTH work for quads?
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Jul 20, 2010, 06:44 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by mkmkmk13 View Post
thats very cool
The OSD would work but RTH would not work.
Sid3ways is offline Find More Posts by Sid3ways
Old Jul 20, 2010, 09:31 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Patrick,
could you please be so kind as to post the basic connection diagramme for your quad with the FY20A in?
I think it will help lots of guys who want to go down your path.
Cheers,
BB
borneobear is offline Find More Posts by borneobear
How to "Axi-fy" your Accel Pitts 28 ES TailTwister 3D Flying 13 Nov 18, 2006 11:40 AM
Fly-In Chilliwack, B.C. "Red Barn" indoor Fy-in dangerspey Electric Flight Events 24 Feb 19, 2006 02:30 PM
Red Barons Pilots Challenge and Fun Fy July 22 Plane_De4mer Electric Flight Events 81 Aug 08, 2005 01:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
